MHB Generating an inverse function from the given one
The discussion revolves around finding the inverse function of a given relationship involving a quintic polynomial. The polynomial derived is y^5 + (P/K2)^2 y + (P/K1)^2 = 0, where y = ρ^(2/3), and it is noted that there is no general solution for quintic equations as proven by Abel and Ruffini. Participants suggest numerical methods for solving the equation, including using specific values for constants K1 and K2 and plotting results. A Taylor expansion approach is also discussed, along with the differentiation of the equation with respect to P to derive a numerical solution for y(P). The conversation emphasizes the complexity of finding a closed form and suggests using software like Mathematica or MATLAB for numerical solutions.
clumps tim
Hi, I have a relationship
$$P \cong \Bigg[\Big(K_1\rho^{\frac{5}{3}}\Big)^{-2}+ \Big(K_2\rho^{\frac{4}{3}}\Big)^{-2}\Bigg]^{-\frac{1}{2}}$$I need to find the inverse as $$\rho= \rho(P)$$.
I made a detailed calculation and came up to this
$$y^5+\Big(\frac{P}{K_2}\Big)^2 y+ \Big(\frac{P}{K_1}\Big)^2=0$$
here $$ y= \rho^{\frac{2}{3}}$$
Now I am stuck, I need a general solution for 5th order polynomail or is there aany other suggested method to solve, plaes help
Mathematics news on Phys.org
Hmm. Using your substitution $y=\rho^{2/3}$, I get
$$y^5-\left(\frac{P}{K_1}\right)^{\! 2}-\left(\frac{P}{K_2}\right)^{\!2}y=0.$$
There is no general solution to the quintic, as Abel and Ruffini proved.
If you have numerical values for the constants, you could solve this numerically. If the coefficients are all real, then you're guaranteed at least one real solution.
Thanks a lot. Now I have never done any numerical solution. if I assume k1 and k2 to be 1 and then take different values for P to get different values for y, and plot a graph, will it be a reasonable solution.
can you please guide how to get a numerical solution for this quintic equation?
A standard way to get a numeric solution is to use the Taylor expansion. Let
$$x^5 + ax + b = 0$$
Be your quintic. Applying the affine transformation $x = \sqrt[4]{a} \cdot z$ gives
$$\sqrt[4]{a^5} \cdot z^5 + \sqrt[4]{a^5} \cdot z + b = 0$$
Dividing out by $\sqrt[4]{a^5}$ and setting $t = b \cdot a^{-5/4}$ result the one-parameter Bring-Jerrard form
$$z^5 + z = -t \tag{+}$$
Write $z = z(-t)$ for one of the 5 solutions of the quintic dependent on parameter $t$. Clearly, if $t = 0$ then $z(t)$ must satisfy $z(z^4 + 1) = 0$ the real solution of which is $z = 0$. Thus, $z(0) = 0$. For calculating $z'(0)$, differentiate $(+)$ with respect to $t$ to get
$$5z(t)^4 \cdot z'(t) + z'(t) + 1 = 0 \Rightarrow z'(t) = \frac1{1 + 5z(t)^4}$$
Substituting $t = 0$ above and noting that $z(0) = 0$, we get $z'(0) = 1$. One can in this way derive the higher derivatives at $t = 0$. First few values of the derivatives are $z(0) = 0, z'(0) = 1, z''(0) = 0, z'''(0) = 0, z^\text{IV}(0) = 0, z^\text{V}(0) = -1$ etc. The nonzero derivatives are $z'(0) = 1, z^\text{V}(0) = -1, z^\text{IX}(0) = 5, z^\text{XIII}(0) = -35$ etc.
Finding a closed form for this is a pain in the neck. Of course, we can cheat. The first entry is precisely the sequence involved (see Sloan's comment on the formula section). Thus, our desired Maclaurin series is
$$z(t) = \sum_{k = 0}^\infty \binom{5k}{k} \frac{(-1)^{k+1} t^{1+4k}}{1+4k}$$
This is not entirely convergent outside the radius $|t| = 4 \cdot 5^{-5/4}$, so you have to be careful. Let's try out formula for $t = 1/2$ :
Using the PARI/GP snippet $\colorbox{LightGray}{$\texttt{solve(x=0,-1,x^5+x+1)}$}$ one gets the approximate solution of $-0.47565274353960478548185664$. Whereas using the snippet $\colorbox{LightGray}{$\texttt{sum(k=0,10,binomial(5*k,k)*(-1)^(k+1)*(1/2)^(1+4*k)/(1+4*k)}$}$, one gets $-0.47569803996611881302669644$ which is correct upto 4 decimal digits. This is not really THAT efficient, however one can use some series accelerations to get an rapid convergence of the series.
[PS : We can actually prove the above formula rigorously without any cheating whatsoever, but that'd require a fair bit of complex analysis. Google "Lagrange-Burmann inversion"]
Another method is the following: differentiate the equation w.r.t. $P$, treating $y=y(P)$ thus:
\begin{align*}
y^5-\frac{P^2}{K_2^2}y-\frac{P^2}{K_1^2}&=0 \\
5y^4 y'-\frac{1}{K_2^2}\left(2Py+P^2 y'\right)-\frac{2P}{K_1^2}&=0 \\
5y^4 y'-\frac{P^2}{K_2^2} y'&=\frac{2P}{K_1^2}+\frac{2Py}{K_2^2}=2P\left[ \frac{1}{K_1^2}+\frac{y}{K_2^2}\right] \\
y'&=\frac{2P\left[ \frac{1}{K_1^2}+\frac{y}{K_2^2}\right]}{5y^4-\frac{P^2}{K_2^2}}.
\end{align*}
Now solve this differential equation numerically for $y(P)$, and plot the solution. I know that Mathematica will do this. I would guess MATLAB could do it as well.
That reminded me of the Cockle-Harley type methods of the mid 19s! [this and this]
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
