Generating electrical power from moisture?
  • Thread starter Thread starter wvt
Recent discussions highlight the emerging technology of moisture-enabled electric generators (MEGs) for generating electrical power from moisture. Key mechanisms involve charge separation and distribution in water drops, influenced by a hygroscopic layer on nanomaterials. Questions arise regarding the specifics of charge interaction with nanomaterials and the significance of drop size. The conversation also touches on related electrokinetic phenomena, such as ion diffusion and triboelectric effects, which could enhance understanding of this energy-harvesting method. Continued exploration and research into these processes are encouraged as interest in alternative energy sources grows.
wvt
hello
recently there was a report about generation of electrical power from moisture. Does someone have some details of this process? Would be interessant to try.
Key points: hygroscopic layer on nanomaterial; charge separation; charge distribution in water drops;
Thank you for this interesting question. It seems beyond my experience with this emerging energy-harvesting technology called a moisture-enabled electric generator (MEG). This publication seems to cover a diverse range of 3 types of voltaic cells and self-powered sensors. Feel free to ask for more info here with your level of interest.
hello, thanks for inviting to further inquiries. honestly, I myself didn't understand the paper in the point, how charge separation exactly works in the special setup. Which kind of charge is carried by the water drops. How do they interact with the walls of the nano material. Does drop size matter?
So a lot of questions. We'll see whether more details will be reported and discussed in the time to come. For me this news is a trigger to occupy bit more with questions of different forms of electro kinetics in general: capillarity, nano generators, triboelectricity - questions that should be pursued with renewed interest within the framework of the debate about new energy resources.
I am reading : Ion Diffusion: There is a difference in ion concentration between the moist environment and the solid material, ions will naturally migrate across the material. This migration creates an electrical potential that can be harvested to generate electricity. I suspect the solid must change the pH of the water from 7 acidic or base but then that means degradation to me.
Streaming potential: This could be the triboelectric effects with friction.
Surface charge potential: Chemical reactions? Double Electric Layer effect increases capacitance. High energy 1.5V alkaline to Li Ion cells often have 10 kFarads per cell = These batteries will be far less.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
