Generating the formula for the coefficients of an alternating series
In summary: Then 2^\frac{1}{n-1} \, at n=2 creates the cosine series coefficients. And 2^n-2 at n=2 is very interesting. It's the balancing point of all numbers (somehow associated with the balancing point of all complex numbers).In summary, the conversation discusses a mathematical function that generates constants such as pi, where x and n are real numbers greater than 1 and k represents the number of radicals. The function is denoted as Q_{x,n,k} and as k approaches infinity, it produces a constant value determined by x and n. The specific case of x
Matt Benesi
134
ETA. Read the bottom post first. Well, and..
Obviously mathematicians know this identity.
At the x=b=c=n=2 point, pi exists. There are also connections to the Wallis product (pi/2).
Anyway, I simplified it to the n=2 case. And re-remembered my fascination with the Pidentity, where x=n=b=c=2. The leverage point in the whole function system. Where all primes are included in order, on the same side of the coefficient quotient (all on one side).
n=2 (simplified equation)
k= number of radicals
b= [itex]\sqrt{2x}[/itex]
c= x^2-x
[tex]\\
Q_{x,k} = b^k \, \times \, \sqrt{x - \sqrt {c+\sqrt {c +...}}} \\
\\[/tex]
k-->infinity, with x and n of 2:
b= [itex]\sqrt{4}[/itex] =2
c= 2^2 -2 =2
Re-iterated: I'd like the coefficients for series associated with constants generated by the following function at the limit k-->infinity.
At x=2,n=2, the point at which the following function generates pi, the series are sine and cosine series (I know these coefficients, a_m = m!/2).
First, here is the cosine series I refer to, for k radicals:
[tex] 2 \times [\, 1- \frac {\pi^2}{2! \, 4^{1k}} + \frac {\pi^4}{4! 4^{2k}} -\frac {\pi^6}{6! \, 4^{3k}}+ \frac {\pi^8}{8!\, 4^{4k}} \,\, ...] =
\sqrt{2 +\sqrt{2+...}}[/tex]Here is the function to generate constants (such as pi) with inputs x, n, and k as the number of radicals, x and n are reals>1:
[tex]Q_{x,n,k} =\sqrt[n] { \left( nx^{n-1} \right)^k \, \times \left[x - \sqrt[n]{x^n-x + \sqrt[n]{x^n-x + \sqrt[n]{x^n-x+...}}} \right]}[/tex]
Above function explained:
k=2, or 2 radicals:
[tex]Q_{x,n,2} =\sqrt[n] { \left( nx^{n-1} \right)^2 \, \times \left[x - \sqrt[n]{x^n-x} \right]}[/tex]
k=3, or 3 radicals:
[tex]Q_{x,n,3} =\sqrt[n] { \left( nx^{n-1} \right)^3 \, \times \left[x - \sqrt[n]{x^n-x+ \sqrt[n]{x^n-x}} \right]}[/tex]
As k approaches infinity, you get some value determined by x and n.
[tex]\gamma= q_{x,n} = Q_{x,n,k \to \infty}[/tex]
One of the values is pi at n=2, x=2:
[tex]\gamma= \pi \, = \, q_{2,2} \, = \, Q_{2,2,k \to \infty} =\sqrt { 4^k \, \times \left[2 - \sqrt[2]{2^2-2 + \sqrt{4-2 + \sqrt{2+\sqrt{2+...}}}} \right]}[/tex] All of the constants have associated functions that allow "fractional iteration" of radical addition.
They provide continuity between iterative addition of radicals:
[itex]\sqrt[n] {x^n-x} [/itex] continuous to
[itex]\sqrt[n] {x^n-x + \sqrt[n]{x^n-x}} [/itex] to
[itex]\sqrt[n] {x^n-x + \sqrt[n]{x^n-x+ \sqrt[n]{x^n-x}}} [/itex].
There are exact formulas for the coefficients of terms in the functions that allow smooth iteration in this case. In the x=2, n=2 case, the coefficients are directly related to sine/cosine coefficients.
[itex]a_m[/itex] coefficients of specific terms in the expansions
[itex]b= nx^{n-1}[/itex]
[itex]\gamma= q_{x,n}[/itex]
one form of "Cosine like" function (k radicals):
[tex]x- \frac {(Q_{x,n,k})^n}{b^k} \, = \,x- \frac {\gamma^2}{a_2 \, b^{1k}} + \frac {\gamma^4}{a_4 \, b^{2k}}-\frac {\gamma^6}{a_6 \, b^{3k}}+ \frac {\gamma^8}{a_8 \, b^{4k}} \,\, ... =
\sqrt[n]{x^n-x +\sqrt[n]{x^n-x+...}}[/tex]
The above reduces to 2*cos(pi/4^(k-1)) in the x=2, n=2 case. a form if the "sine like" function with gamma/2 (used with coefficients in spoiler below):
[tex]\frac {(Q_{x,n,k})^n}{b^k} \, = \, \frac {(\frac{\gamma}{2})}{a_1 \, b^{1k}} - \frac {(\frac{\gamma}{2})^3}{a_3 \, b^{2k}} + \frac {(\frac{\gamma}{2})^5}{a_5 \, b^{3k}} -\frac {(\frac{\gamma}{2})^7}{a_7 \, b^{4k}}+ \frac {(\frac{\gamma}{2})^9}{a_9 \, b^{5k}} \,\, ...
= \, x- \sqrt[n]{x^n-x +\sqrt[n]{x^n-x+...}}[/tex]Using the functions, one can increase k with non-integer values, and traverse smoothly between iterations of radicals- it allows one to smoothly connect addition of radicals in a naturally arising way: infinitely nested radicals smoothly connect all radical addition.
[tex]{Q_{2,2,3}}^2 = \,\,\ \frac{ pi^2}{ 4^{0}} - \frac{pi^4}{12 \times 4^{3}} +\frac{ pi^6}{360 \times 4^{6}} - \frac{ pi^8}{20160 \times 4^{9}}\,\,\, \dots = \,\,\, 4^3 \, \times \left[2 - \sqrt{2 + \sqrt{2}} \right] [/tex]
so
[tex]\frac{{Q_{2,2,3}}^2}{4^3} = \,\,\ \frac{ pi^2}{ 4^{3}} - \frac{pi^4}{12 \times 4^{6}} +\frac{ pi^6}{360 \times 4^{9}} - \frac{ pi^8}{20160 \times 4^{12}}\,\,\, \dots = \,\,\,2 - \sqrt{2 + \sqrt{2}} [/tex]
so
[tex]2 - \,\,\ \frac{ pi^2}{ 4^{3}} - \frac{pi^4}{12 \times 4^{6}} +\frac{ pi^6}{360 \times 4^{9}} - \frac{ pi^8}{20160 \times 4^{12}}\,\,\, \dots = \sqrt{2 + \sqrt{2}} [/tex]
In the x=1.5, n=2 case we have [itex]\gamma = 6.42675515[/itex] b=3, for k roots of .75:
[tex]x-
\frac{\gamma}{3^k} + \frac {\gamma^2}{6 \, \times \, 3^{2k} }
- \frac {\gamma^3}{72 \, \times \, 3^{3k}} + \frac {\gamma^4}{1404\, \times \, 3^{4k} }-
\frac {\gamma^4}{(673920/17 \, \times \, 3^{5k} } \\
+\frac {\gamma^6}{1510080 \, \times \, 3^{6k} }
-\frac {\gamma^7}{\frac{178092794880}{2407} \, \times \, 3^{7k} }
+\frac {\gamma^8}{\frac{18248946075360}{4051} \, \times \, 3^{8k} } \\
-\frac {\gamma^9}{ \frac{112670561875981824}{8887225} \, \times \, 3^{9k} } = \\
k roots
\sqrt{.75+\sqrt{.75+...}}
[/tex]
These are at first glance, continuous functions for addition of radicals.
They are also periodic functions at n=2, x=2 for k<0.
I am interested in the semiperiodic properties of the other infinitely nested radical constants ([itex]\gamma = q_{x,n}[/itex]) and functions at x and n other than 2.
For which, I require a generating function for a_m-- or a function f(x,n,k) that multiplied by cosine( g(x,n,k) ) gives the values I need. I'd prefer both (because I want to check the a_m expansions against what I am given).
Thanks for any actual help. Anyone who suggests groots instead of kroots will be grooted.
for n=2:
a_1 is 1
a_2 is (2x)(2x-1)/2
a_3 is (2x)(2x-1)
a_4 is [itex] \frac{\left( 2 x-1\right) \, \left( 2 x\right) \, \left( 2 x-1\right) \, \left( 2 x\right) \, \left( 2 x+1\right) }{2} [/itex]
General cases n=2, in "order":x=2 : ... yup
x=2.5 : 1, 10, 20, 600, 1200, 62000/3, 148800, 58032000/131, 32240000...
x= 3: 1, 15, 30, 3150, 50400, 812700/11, 2889600...
Mathematics news on Phys.org
Matt Benesi said:
One of the constants is Pi, at n=2, x=2.
Why? If ##\displaystyle \pi = q_{2,2} = \lim_{k \to \infty} Q_{2,2,k}## then ##\displaystyle \pi^2 = q_{2,2}^2 = \lim_{k \to \infty} Q_{2,2,k} = \lim_{k \to \infty} \left( 2\right)^k \, \times \left[x - \sqrt[n]{x^n-x + \sqrt[n]{x^n-x + \sqrt[n]{x^n-x+...}}} \right]## but that limit does not exist. In general you need ##|nx^{n-1}| \leq 1## for the limit to exist. If it is smaller than 1 then the limit will always be zero, if it is exactly one then things are interesting.
No. I think you made an error somewhere, but I have to reply quickly.
As k -->infinity, [itex] \sqrt[n]{x^n-x+\sqrt[n]{x^n-x+...}} \to x[/itex]. You can look up various works involving nested roots/radicals in Dixon Jones' Chronology of Nested Roots. https://arxiv.org/pdf/1707.06139.pdf
2 is actually a pretty cool case here. It's the balancing point of all numbers (gives you the exponential function coefficients if you dissect its cosine and sine functions, because [itex]q_{2,2} =\pi[/itex]). It's the only number 2^2-2=2... Technically... [itex] 2^\frac{n}{n-1}-2^\frac{1}{n-1} = 2^ \frac{1}{n-1}[/itex], but it's the only integer case...
And it leads to exponential function coefficients a_m (well, maybe a_m*2... are exponential function coefficients...a_m = m!/2 I think.. for cosine at least)
google... 2^5 *sqrt(2-sqrt(2+sqrt(2+sqrt(2+sqrt(2)))))) keep adding terms...
Ah, I misunderstood "and k being the number of radicals". Okay, then the limit can be interesting.
Likes Matt Benesi
removing extra replies:
How would I phrase it so people aren't confused?[tex]Q_{x,n,k} =\sqrt[n] { \left( nx^{n-1} \right)^k \, \times \left[x - \sqrt[n]{x^n-x + \sqrt[n]{x^n-x + \sqrt[n]{x^n-x+...}}} \right]}[/tex]
k=1
[tex]Q_{x,n,1} =\sqrt[n] { \left( nx^{n-1} \right)^1 \, \times \left[x \right]}[/tex]
k=2
etc.?? I think I messed up the math in the OP anyway. The one part should not be:
[tex]Q_{2,2,3} = \,\,\ \frac{ pi^2}{ 4^{0}} - \frac{pi^4}{12 \times 4^{3}} +\frac{ pi^6}{360 \times 4^{6}} - \frac{ pi^8}{20160 \times 4^{9}}\,\,\, \dots = \,\,\, 4^3 \, \times \left[2 - \sqrt{2 + \sqrt{2}} \right] [/tex]
so
[tex]Q_{2,2,3} = \,\,\ \frac{ pi^2}{ 4^{3}} - \frac{pi^4}{12 \times 4^{6}} +\frac{ pi^6}{360 \times 4^{9}} - \frac{ pi^8}{20160 \times 4^{12}}\,\,\, \dots = \,\,\,2 - \sqrt{2 + \sqrt{2}} [/tex]
It should be:
so
[tex]{Q_{2,2,3}}^2 = \,\,\ \frac{ pi^2}{ 4^{3}} - \frac{pi^4}{12 \times 4^{6}} +\frac{ pi^6}{360 \times 4^{9}} - \frac{ pi^8}{20160 \times 4^{12}}\,\,\, \dots = \,\,\,2 - \sqrt{2 + \sqrt{2}} [/tex]
ETA to fix question:
Anyone? Am I asking the question incorrectly?
Basically, I'm looking for coefficients of alternating series that allow one to smoothly iterate roots.
[itex]\sqrt[n] {x^n-x}[/itex] to whatever depth of roots you want [itex]\sqrt[n] {x^n-x+\sqrt[n] {x^n-x+\sqrt[n] {x^n-x}}}[/itex].
I am still stuck on this. I would appreciate some input (wikipedia page, or whatever), as I'd like to use the results.
//// post 1 :
Re-explained (maybe better):
k is the number of radicals, x and n are reals>1:
[tex]Q_{x,n,k} =\sqrt[n] { \left( nx^{n-1} \right)^k \, \times \left[x - \sqrt[n]{x^n-x + \sqrt[n]{x^n-x + \sqrt[n]{x^n-x+...}}} \right]}[/tex]In other words:
As k approaches infinity, you get some value determined by x and n:
[tex]q_{x,n} = Q_{x,n,k \to \infty}[/tex]
One of the values is p at n=2, x=2: [itex]q_{2,2} \,=\, \pi[/itex] All of the constants have associated functions that allow us to smoothly iterate radicals. By smoothly iterate, I mean they provide continuity between iterations of radicals [itex]\sqrt[n] {x^n-x} [/itex] to [itex]\sqrt[n] {x^n-x + \sqrt[n]{x^n-x}} [/itex] to [itex]\sqrt[n] {x^n-x + \sqrt[n]{x^n-x+ \sqrt[n]{x^n-x}}} [/itex].
There are exact formulas for the coefficients of terms in the functions that allow smooth iterations between radicals. In the x=2, n=2 case, the coefficients are directly related to sine/cosine.
[tex]\frac {(Q_{x,n,k})^n}{b^k} \, = \, \frac {\gamma^2}{a_2 \, b^{1k}} - \frac {\gamma^4}{a_4 \, b^{2k}} +\frac {\gamma^6}{a_6 \, b^{3k}}- \frac {\gamma^8}{a_8 \, b^{4k}} \,\, ... =
so
so
I am interested in the semiperiodic properties of the other infinitely nested radical constants and functions at x and n other than 2. For which, I require a generating function for a_m-- or a function f(x,n,k) that multiplied by cosine( g(x,n,k) ) gives the values I need. I'd prefer both (because I want to check the a_m expansions against what I am given).
for n=2:
a_1 is 1
a_2 is (2x)(2x-1)/2
a_3 is (2x)(2x-1)
x= 1.5: 1, 3, 6, 18, 72, 234, 1404, 42120/11, 637820/17, (2^3*3^5*5*11^2*13)/223...
x=2 : 1,6,12,120,360,5040,20160... == 1, 3!, 4!/2, 5!, 6!/2, 7!, 8!/2, 9!, 10!/2, 11!... (the only decomposition functions with all primes distributed in monotonic order appear to be along the x=2, n=2 divide- intuitively, it makes sense that the pi function has all primes encoded within it...)
Thanks for any help.
So I’ve read this thread again, which was tiresome to decipher. It sounds like you are essentially looking for a formula for fractional iterates of ##f_x(c)=\sqrt{x^n-x+c}## about the fixed point ##c=x##. The approach to this would be to solve Schroder’s equation for that fixed point, then use the solution to calculate the Taylor series with respect to the iterate parameter. See this Wikipedia article for more information.
That doesn't help- except that I learned I could edit posts and clean up the thread... which is sort of useful. If I get good answers to my questions. Can you explain how to use Schröder's equation? Can you write out an example of its use, since you are familiar with its use, and this is the first time I've heard of it? To others: Isn't there some general solution out there? There is for every other piece of simplistic math.
Why not this specific one?
Sure. Schröder's equation says, given ##h(x)##, find a function ##\Psi(x)## and a number ##s## such that ##\Psi(h(x)) = s\Psi(x)##. Then we have ##h^t(x)=\Psi^{-1}(s^t\Psi(x))##. This gives you a power series in ##s^t##, which you could analyze with some sort of integral transform to extract information about its growth rate. From there you could work out some equations for ##q_{x,n}## and ##Q_{x,n,k}##.
Solutions to Schröder's equation can be calculated to however many terms you like, using a thing called a Carleman matrix, but the procedure is complicated and ugly. I refer you to this paper I found, which shows how to calculate the terms.
Another thing I'd like to mention is that the expression in OP doesn't make sense when ##n\neq 2##. You seem to have extrapolated the term ##b=nx^{n-1}##, which coincides with the correct value for ##n=2##, but the correct expression is ##nx##. This amounts to the inverse of the derivative of ##f(c)=\sqrt[n]{x^n-x+c}##, which represents the ratio by which ##f## tends to contract space around ##x##. If ##b## were any other value, the expression would vanish or diverge.
Furthermore, ##q_{x,n}## is not uniquely defined because it depends on the initial value for the sequence of iterates. If I take ##\lim_{k\rightarrow\infty}\sqrt[n]{(nx)^k(x-f^k(c))}## at ##c=x##, the term is zero for all values of k, and therefore the limit is zero. If I take the limit at ##c=0##, I get a different number; when ##x=2## and ##n=2##, this happens to be ##\pi##. In between ##c=0## and ##c=x## the limit varies smoothly between the two values. When ##x=2## and ##n=2##, it is closely approximated by an arccosine curve, within a few thousandths. You should plot it yourself and see the results, it's pretty interesting.
If only! There are many, many extremely simple functions which give rise to extremely complicated behavior under iteration, for example the logistic map. Even functions which aren't chaotic often lack a closed form solution for the nth iterate. Because what you're dealing with is fundamentally related to iterated functions, you shouldn't expect a general solution for much of anything.
Edit: upon looking at OP again, it looks as if you stumbled upon the solution to Schröder’s equation for the special case ##x=n=2##. If you replace ##\gamma## with ##2\cos^{-1}(c)##, you get something very close to Schröder’s equation. It doesn’t match exactly, which makes me think I did something wrong, but I’m too tired to look at it more. I will look at it again later.
Likes Matt Benesi
I was hoping to see you post a working example of Schröder’s equation- I know the wikipedia rehash is... the easiest thing to throw out there, but.
Maybe something a bit more like the example I posted for x=1.5: explanations leading up to it, then it in use, results being in line with goals (or serendipitous), so I can question parts of it. Get a good understanding of what you're doing.
I'll look at the paper more. I was just hoping for a live walkthrough, so I could ask questions about various points.
Remember we're doing (x-...)/( x-...) to get the inner derivative, not .../...
For certain continuous nested inverse functions that approach a fixed point, you get something that approaches the "inner function derivative". Stephen Tashi showed it is true with a Taylor approximation years ago, after I found it in my mathematical ramblings.
For example: If b and n are within domain in which n=output of function at infinite iterates and number of iterates approaches infinity/(infinity+1): [itex]\frac{n-log_b [b^n-n +log_b [b^n-n+...}{n-log_b [b^n-n +log_b [b^n-n+log_b [b^n-n+... }\, \to \, b^n \, Ln(b)[/itex]. In this case, the "inner function" is b^n.
Same thing with the [itex]x= \sqrt[n]{x^n-x + \sqrt[n]{x^n-x + ...}}[/itex] functions: the ratio of successive iterations of (x-function) approaches the derivative of x^n ([itex]nx^{n-1}[/itex]) as the number of iterations approaches infinity.
The initial value is x^n-x. Double check where I said "Above function explained". Is it clear that radical k=2 has x^n-x as a seed value?
I'm not getting how you did this. Sounds interesting though. Maybe I could plot all of them for various x and n and compare the results to other functions. Visual math search! Wow.. I am easily excited.
But there is. In fact, I think I figured out a way of extracting specific enough results to find the exact pattern for various cases (especially n=2). I just wanted the already existing solution, because I was going to use it for fractal artwork. You know "the Bernoulli Gouldfarb equation for termination coefficients of nested functions" or something like that.
I'm still plodding through this. Making charts. Since I'm pretty much certain the formulas exist out there somewhere, I'd really like the general coefficient formulas for something I'd like to make in GLSL. Might be a pipe dream, but I think smooth variable strength "cosine" and "sine" functions would look cool for certain applications.
I worked from here:
241939
to here:
For cosine like series (q_x,n)^2:
coefficient 1= [itex]\frac{n\, {{x}^{n}}-x}{n-1}[/itex]
coefficient 2= [itex]\frac{\left( n\, {{x}^{n}}-x\right) 3 \left( n\, {{x}^{n-1}}+1\right) }{\left( n-2\right) \, \left( n\, {{x}^{n-1}}+1\right) +n+1}[/itex]
coefficient 3 top part = [itex]4 x\, \left( {{n}^{3}}\, {{x}^{3 \left( n-1\right) }}-1\right) \, \left( \left( n-2\right) \, \left( n\, {{x}^{n-1}}+1\right) +n+1\right) [/itex]
[tex]
\begin{array}{|c|c|c|c|}
\hline &a_2=\frac{x(x^{n-1}-1}{n-1} & a_4 = \frac{3x (x^{n-1}-1)(x^{n-1}+1)}{(n-2)n x^{n-1} + 2n-1}& a_6 = \frac{ 4x (n^4x^{n+1} -1) ((n-2)n x^{n-1} + 2n-1)}{?} & a_8&\dots\\
\hline n=2 & \frac{x (2x-1)}{1} & \frac{3x(2x-1)(2x+1)}{0x^1 +3} & \frac{ 4x(8x^3-1) (0x^1+3)}{3(2x+5)} & \dots\\
\hline n=3 & \frac{x (3x^2-1)}{2} & \frac{3x(3x^2-1)(3x^2+1)}{3x^2 +5} & \frac{ 4x(27x^6-1)(3x^2+5)}{?} & \dots\\
\hline n=4 & \frac{x (4x^3-1)}{3} & \frac{3x(4x^3-1)(4x^3+1)}{8x^3 +7} & \frac{ 4x(64x^9-1)(8x^3+7)}{?} & \dots\\
\hline \dots &\dots & \dots&\dots &\dots&\dots&\dots\\
\hline
\end{array}
[/tex]
To where I'm at now:
TLDR
Seeing some basic patterns in the coefficients emerging. I only really need the n=2 case, but... maybe it would be better to develop and all encompassing formula and leave it out there.
Anyways, these coefficients, in my mind, aren't only for smooth iteration of radical addition with specific constants associated. They are for smooth oscillating functions that I hope will make some interesting artwork. The point? The same thing as a nicely mowed lawn. Make something nice. Maybe make something really cool to look at, in between meals, talking, farming, working, and creation of artistic narratives to tie us together. That's why I'd like the general formula. It's a good enough reason to motivate me, when I expect nothing from life.. but finishing this one project.
[tex]
\hline &a_2=\frac{2x(x^{n-1}-1)}{2(n-1)} & a_4 = \frac{3x (x^{2(n-1)}-1)}{(n-2)n x^{n-1} + 2n-1}& a_6 = \frac{ 4x (x^{3(n-1)}-1)\,\, ((n-2)n x^{n-1} + 2n-1)}{?} & a_8&\dots\\
\hline n=2 & \frac{2x (2x-1)}{2} & \frac{3x(4x^2-1)}{0x^1 +3} & \frac{ 4x(8x^3-1) (0x^1+3)}{6x+15} &
\frac{ x(16x^4-1) (2x^1+5)}{8x^2+6x+7} & \dots\\
\hline n=3 & \frac{2x (3x^2-1)}{4} & \frac{3x(9x^4-1)}{3x^2 +5} & \frac{ 4x(27x^6-1)(3x^2+5)}{4(27x^4+15x^2+10) } & \dots\\
\hline n=4 & \frac{2x (4x^3-1)}{6} & \frac{3x(16x^6-1)}{8x^3 +7} & \frac{ 4x(64x^9-1)(8x^3+7)}{?} & \dots\\
\hline
\end{array}
[/tex]
Coefficients for n=2 case, up to coefficient 5. Once again, any general form would be appreciated. If you recognize the pattern, let me know. At x=2, this reduces to cosine.
And yeah, it's something simple you learned in high school. If you ever decide to stop messing with me and leading me down wrong paths, it would be appreciated, if unexpected.
a2: 2x (2x-1)
a4 : x (4x^2-1)
a6: 4x (8x^3-1) / (2x +5)
a8: x(16x^4-1) (2x+5) /(8x^2+6x+7)
a10: 2x (32x^5-1) (8x^2+6x+7) / (48x^4+64x^3+56x^2 +28x +21)
I think about 8 more terms might be enough for what I want to try, but maybe not.
I find it incredible that you're attacking me, but since you are so skeptical, I wrote a program in Mathematica to generate your next 8 terms using the method I described:
k = 15; x =.; n = 2; f[y_] := (x^n - x + y)^(1/n); g[y_] := f[y + x] - x; M = Table[ D[g[y]^(i - 1), {y, j - 1}]/((j - 1)!), {i, 1, k}, {j, 1, k}] /. y -> 0; M = Simplify[M, Element[x, Reals] && x > 0 && Element[n, Integers]]; L = M[[2, 2]] V = IdentityMatrix[k]; For[i = 1, i <= k, i++, For[j = i + 1, j <= k, j++, V[[i, j]] = Sum[V[[i, l]]*M[[l, j]], {l, i, j - 1}]/(L^(i - 1) - L^(j - 1)); ] ] V = Simplify[V]; Psi = V[[2]] PsiInv = Simplify[Inverse[V]][[2]]
Here's 15 terms (the first two being trivial of course):
0 \\
1 \\
-\frac{1}{2 x-4 x^2} \\
\frac{1}{2 (1-2 x)^2 x^2 (1+2 x)} \\
\frac{5+2 x}{8 x^3 (-1+2 x)^3 \left(1+4 x+8 x^2+8 x^3\right)} \\
\frac{7+6 x+8 x^2}{8 (1-2 x)^4 x^4 (1+2 x)^2 \left(1+4 x^2\right) \left(1+2 x+4 x^2\right)} \\
\frac{21+28 x+56 x^2+64 x^3+48 x^4}{16 x^5 (-1+2 x)^5 (1+2 x)^2 \left(1+4 x^2\right) \left(1+2 x+4 x^2\right) \left(1+2 x+4 x^2+8 x^3+16 x^4\right)}
\frac{33+60 x+148 x^2+256 x^3+432 x^4+384 x^5+512 x^6+128 x^7}{16 (1-2 x)^6 x^6 (1+2 x)^3 \left(1+2 x+4 x^2\right)^2 \left(1+8 x^2+8 x^3+32 x^4+32
x^5+128 x^6+256 x^8\right)} \\
\frac{429+990 x+2820 x^2+6048 x^3+12976 x^4+21120 x^5+34304 x^6+41856 x^7+52224 x^8+45568 x^9+27648 x^{10}+2048 x^{11}}{128 x^7 (-1+2 x)^7 (1+2
x)^3 \left(1+4 x^2\right) \left(1-2 x+4 x^2\right) \left(1+2 x+4 x^2\right)^2 \left(1+2 x+4 x^2+8 x^3+16 x^4\right) \left(1+2 x+4 x^2+8 x^3+16 x^4+32
x^5+64 x^6\right)} \\
\frac{715+2002 x+6380 x^2+15840 x^3+38960 x^4+79808 x^5+164480 x^6+276352 x^7+474624 x^8+695808 x^9+986112 x^{10}+1099776 x^{11}+1335296 x^{12}+1032192
x^{13}+688128 x^{14}+131072 x^{15}}{128 (1-2 x)^8 x^8 (1+2 x)^4 \left(1+4 x^2\right)^2 \left(1-2 x+4 x^2\right) \left(1+2 x+4 x^2\right)^2 \left(1+16
x^4\right) \left(1+2 x+4 x^2+8 x^3+16 x^4\right) \left(1+2 x+4 x^2+8 x^3+16 x^4+32 x^5+64 x^6\right)} \\
\frac{2431+8008 x+28028 x^2+77880 x^3+211200 x^4+496320 x^5+1160192 x^6+2393984 x^7+4811264 x^8+8904704 x^9+15927296 x^{10}+25892864 x^{11}+41525248
x^{12}+59195392 x^{13}+80183296 x^{14}+100237312 x^{15}+114229248 x^{16}+107479040 x^{17}+92536832 x^{18}+48234496 x^{19}+14680064 x^{20}}{256 x^9
(-1+2 x)^9 (1+2 x)^4 \left(1+4 x^2\right)^2 \left(1-2 x+4 x^2\right) \left(1+2 x+4 x^2\right)^3 \left(1+16 x^4\right) \left(1+2 x+4 x^2+8 x^3+16
x^4\right) \left(1+8 x^3+64 x^6\right) \left(1+2 x+4 x^2+8 x^3+16 x^4+32 x^5+64 x^6\right)} \\
\frac{4199+15912 x+60424 x^2+184184 x^3+539968 x^4+1400352 x^5+3569024 x^6+8298240 x^7+18809088 x^8+39772160 x^9+81849344 x^{10}+158185472 x^{11}+299859968
x^{12}+532553728 x^{13}+920403968 x^{14}+1500348416 x^{15}+2370502656 x^{16}+3493462016 x^{17}+4992532480 x^{18}+6505889792 x^{19}+8226078720 x^{20}+9206497280
x^{21}+9709813760 x^{22}+8321499136 x^{23}+6408896512 x^{24}+3053453312 x^{25}+939524096 x^{26}}{256 (1-2 x)^{10} x^{10} (1+2 x)^5 \left(1+4 x^2\right)^2
\left(1-2 x+4 x^2\right) \left(1+2 x+4 x^2\right)^3 \left(1+16 x^4\right) \left(1-2 x+4 x^2-8 x^3+16 x^4\right) \left(1+2 x+4 x^2+8 x^3+16 x^4\right)^2
\frac{29393+125970 x+514488 x^2+1697696 x^3+5317312 x^4+14906528 x^5+40650688 x^6+102775296 x^7+252708608 x^8+588984320 x^9+1331216384 x^{10}+2874906624
x^{11}+6064906240 x^{12}+12258697216 x^{13}+24152276992 x^{14}+45857964032 x^{15}+84758429696 x^{16}+150767009792 x^{17}+261238030336 x^{18}+434696617984
x^{19}+702951718912 x^{20}+1090808446976 x^{21}+1632393756672 x^{22}+2326160998400 x^{23}+3195891875840 x^{24}+4132261855232 x^{25}+5062558482432
x^{26}+5744921411584 x^{27}+6039529324544 x^{28}+5567351357440 x^{29}+4554812817408 x^{30}+2847563317248 x^{31}+1352914698240 x^{32}+300647710720
x^{33}}{1024 x^{11} (-1+2 x)^{11} (1+2 x)^5 \left(1+4 x^2\right)^2 \left(1-2 x+4 x^2\right) \left(1+2 x+4 x^2\right)^3 \left(1+16 x^4\right) \left(1-2
x+4 x^2-8 x^3+16 x^4\right) \left(1+2 x+4 x^2+8 x^3+16 x^4\right)^2 \left(1+8 x^3+64 x^6\right) \left(1+2 x+4 x^2+8 x^3+16 x^4+32 x^5+64 x^6\right)
\left(1+2 x+4 x^2+8 x^3+16 x^4+32 x^5+64 x^6+128 x^7+256 x^8+512 x^9+1024 x^{10}\right)} \\
\frac{52003+248710 x+1085280 x^2+3840096 x^3+12748112 x^4+38142720 x^5+110096448 x^6+297174528 x^7+777740544 x^8+1944133120 x^9+4721329152 x^{10}+11024812032
x^{11}+25149571072 x^{12}+55451041792 x^{13}+119471800320 x^{14}+249982550016 x^{15}+511600623616 x^{16}+1017703170048 x^{17}+1982365171712 x^{18}+3755020910592
x^{19}+6962182881280 x^{20}+12564811481088 x^{21}+22168922488832 x^{22}+38002432671744 x^{23}+63695237414912 x^{24}+103517201104896 x^{25}+163980442075136
x^{26}+251246594228224 x^{27}+374255397109760 x^{28}+535713418313728 x^{29}+743357907206144 x^{30}+982007765008384 x^{31}+1247374466875392 x^{32}+1491977149349888
x^{33}+1689554234900480 x^{34}+1743997240344576 x^{35}+1680603523055616 x^{36}+1391706842857472 x^{37}+1001655092903936 x^{38}+550305569701888 x^{39}+223200860438528
x^{40}+30786325577728 x^{41}}{1024 (1-2 x)^{12} x^{12} (1+2 x)^6 \left(1+4 x^2\right)^3 \left(1+2 x+4 x^2\right)^4 \left(1+16 x^4\right) \left(1-4
x^2+16 x^4\right) \left(1-2 x+4 x^2-8 x^3+16 x^4\right) \left(1+8 x^3+64 x^6\right) \left(1+4 x^2+8 x^3+16 x^4+64 x^6\right)^2 \left(1+2 x+4 x^2+8
x^3+16 x^4+32 x^5+64 x^6\right) \left(1+2 x+4 x^2+8 x^3+16 x^4+32 x^5+64 x^6+128 x^7+256 x^8+512 x^9+1024 x^{10}\right)} \\
\frac{185725+980628 x+4547840 x^2+17131920 x^3+59935200 x^4+189751552 x^5+575619200 x^6+1640694528 x^7+4521121536 x^8+11944266752 x^9+30661671936
x^{10}+76064624640 x^{11}+184211517440 x^{12}+433407426560 x^{13}+997415403520 x^{14}+2239325929472 x^{15}+4926191370240 x^{16}+10592819347456 x^{17}+22349943668736
x^{18}+46156451151872 x^{19}+93583849816064 x^{20}+185928505098240 x^{21}+362715675623424 x^{22}+693542057934848 x^{23}+1302440980774912 x^{24}+2397203851116544
x^{25}+4331031465295872 x^{26}+7666432603062272 x^{27}+13311279397601280 x^{28}+22620266676879360 x^{29}+37669500295839744 x^{30}+61302111165480960
x^{31}+97592729390809088 x^{32}+151511757414727680 x^{33}+229489585913069568 x^{34}+337937372698116096 x^{35}+483941659189444608 x^{36}+670474219158503424
x^{37}+898528598799941632 x^{38}+1156986399094734848 x^{39}+1429159507434405888 x^{40}+1675607342219001856 x^{41}+1860545198010925056 x^{42}+1919043614655119360
x^{43}+1830484550107529216 x^{44}+1561763908279074816 x^{45}+1172413646744059904 x^{46}+716072340751908864 x^{47}+348466021167792128 x^{48}+99079191802150912
x^{49}+7881299347898368 x^{50}}{2048 x^{13} (-1+2 x)^{13} (1+2 x)^6 \left(1+4 x^2\right)^3 \left(1+2 x+4 x^2\right)^4 \left(1+16 x^4\right) \left(1-4
x^3+16 x^4+32 x^5+64 x^6\right) \left(1+2 x+4 x^2+8 x^3+16 x^4+32 x^5+64 x^6+128 x^7+256 x^8+512 x^9+1024 x^{10}\right) \left(1+2 x+4 x^2+8 x^3+16
x^4+32 x^5+64 x^6+128 x^7+256 x^8+512 x^9+1024 x^{10}+2048 x^{11}+4096 x^{12}\right)} \\
I'll be damned if there's a general formula for that.
I can't use that code, don't have mathematica. I can use the coefficients though. That will help (assuming they are correct). I do like the way I organized them better (in the post a couple up). It makes their growth more apparent (only keeping in the last part of the coefficient, so one can see what is added to the coefficient each time).Wish I could test your code.
<< Mentor Note -- Post has been edited >>
Thread closed for Moderation...
Thread re-opened after edits. Thanks for everybody's patience.
Thanks berkeman.
The x=n=b=c=2 case is probably well known, like Euler's identity, because it's one of those math leverage points associated with pi, and prime number distribution. It's like something one of those math popularizers would mention.
b=[itex]\sqrt[n]{nx^{n-1}}[/itex]
c=[itex] x^n-x [/itex]
k= # of radicals
[tex] b^k \, \sqrt[n]{x-\sqrt[n]{c+\sqrt[n]{c+\sqrt[n]{c+...}}}}[/tex]
So for k=2, we have... [itex] b^2 \, \sqrt[n]{x-\sqrt[n]{c}}[/itex]
and for k=3, we have... [itex] b^3 \, \sqrt[n]{x-\sqrt[n]{c+\sqrt[n]{c}}}[/itex]
@ x=2, n=2:
b=[itex] \sqrt[2]{2 \cdot 2 ^{2-1}} = 2[/itex]
c= [itex] 2^2-2 =2[/itex]
[tex] \pi \, = \,\, \lim\limits_{k \to \infty} \, b^k \sqrt{2-\sqrt{2+\sqrt{2+\sqrt{2...}}}} [/tex]
Coefficients for smooth iteration from point at infinity are [itex] a_m = \frac{2}{(2m)!}[/itex] for the 2 cosine function. Sort of perfect. Following wrote general form, then with coefficients at x,n=2 point.
[tex] {\frac {Q_{2,2,k}^2}{b^{2k}}} = \frac {{q_{x,n}}^2}{a_1 \, b^{2k}} + \frac {{q_{x,n}}^4}{a_2 \, b^{4k}} -\frac {{q_{x,n}}^6}{a_3 \, b^{6k}}+ \frac {{q_{x,n}}^8}{a_4 \, b^{8k}} -\,\, ... = x- \sqrt{c+\sqrt{c+...}} [/tex][tex]2- {\frac {Q_{2,2,k}^2}{b^{2k}}} =2- \frac {2{\pi}^2}{2! \, b^{2k}} + \frac {2{\pi}^4}{4! \, b^{4k}} -\frac {2{\pi}^6}{6! \, b^{6k}}+ \frac {2{\pi}^8}{8! \, b^{8k}} -\,\, ... = \sqrt{2+\sqrt{2+...}} [/tex]
Basically it's the 2*cosine Schroder's equation solution you (sm) mentioned. Which I still have to work through more to gain understanding. Wish I wasn't constrained to library hours to do stuff.
People apparently weren't focusing on this thing, with the x=n=b=c=2 case with coefficients [itex]\frac{2}{(2m)!}[/itex] being the only coefficients with all primes on one side of the coefficient quotient in order. I mean, literally, those humongous equations you (suremarc) were spitting out? They reduce to 2/(2m)! at the x=n=b=c=2 line. Everywhere else, it looks (to me) like primes are on both sides of the coefficient quotients (and primes are skipped). The coefficient equations are even more complex when you don't constrain to n=2. But is there even one case, other than n=2,x=2, in which all primes are on only one side of the coefficient quotients in order? Can you find a non trivial coefficient for n>1, n and x both do not equal 2, that contains all primes less than the highest prime in the coefficient, in order, on the same side of the coefficient quotient (denominator), for [itex]a_1 [/itex] and for [itex] a_1 \, \times \, a_2[/itex]?
[itex]a_1 = 2 \frac{nx^n- x}{n-1}[/itex]
[itex]a_2 = \,\frac {3x (nx^{n-1}-1)\, \times \, (n x^{n-1}+1) }{ (n-2) \, \times \, (nx^{n-1}+1) \, +n+1}[/itex]
Maybe I'm missing some glaringly obvious bit of math. I've done it before. For what n and x does both a1 = ℕ/(ℕm)! and a1*a2 = ℕ/(ℕm)!
How about an x and n >1, that contains all primes, in order, on one side of the coefficient quotient, for the first 3 coefficients? First 4?
Related to Generating the formula for the coefficients of an alternating series
1. What is an alternating series?
An alternating series is a series in which the signs of the terms alternate between positive and negative.
2. How do you generate the formula for the coefficients of an alternating series?
The formula for the coefficients of an alternating series is generated by using the alternating series test, which states that if the absolute values of the terms in the series decrease and approach 0, then the series converges. The formula is given by (-1)^n, where n is the index of the term in the series.
3. What is the purpose of finding the formula for the coefficients of an alternating series?
The purpose of finding the formula for the coefficients of an alternating series is to determine whether the series converges or diverges. This is important in mathematical analysis and can be used to solve various problems in physics, engineering, and other fields.
4. Can the formula for the coefficients of an alternating series be applied to all alternating series?
No, the formula for the coefficients of an alternating series can only be applied to alternating series that satisfy the conditions of the alternating series test. If the absolute values of the terms do not decrease and approach 0, then the formula cannot be used to determine convergence or divergence.
5. Are there any other methods for determining the convergence of an alternating series?
Yes, there are other methods such as the ratio test and the root test that can also be used to determine the convergence of an alternating series. However, the alternating series test and its formula for the coefficients is often the most efficient and straightforward method to use.
  • General Math
  • General Math
  • General Math
