I Generators of Galois group of ## X^n - \theta ##
kmitza
TL;DR Summary
If we have a polynomial ##x^p - \theta## for some prime p. Then we can show that it's Galois group has order p(p-1) then I want to prove what the group looks like described by generators and relations between them
As the summary says we have ## f(x) = x^n - \theta \in \mathbb{Q}[x] ##. We will call the pth primitive root ## \omega ## and we denote ##[\mathbb{Q}(\omega) : \mathbb{Q}] = j##. We want to show that the Galois group is generated by ##\sigma, \tau## such that
$$ \sigma^j = \tau^p = 1, \sigma^k\tau = \tau\sigma$$.
I know that the splitting field of ## f ## is going to be ##Q(t,\omega)## and that the degree of this extension is going to be ##[Q(t,\omega): :Q(\omega)][Q(\omega : Q)] ## where ## t^p = \theta ##, further as minimal polynomial of ## \omega ## is going to be ## p^{th} ## cyclotomic I have the second multiple being (p-1) and I can prove that the whole extension will have degree p(p-1). Now my idea is to define the morphisms as:
$$\sigma(t) = t, \sigma(\omega) = \omega^2$$ and $$\tau(t) = t\omega, \tau(\omega) = \omega$$
I can show that order of these two groups are p-1 and p but I don't know how to show that they generate my group.
I suspect that I am meant to construct the group as a semidirect product of ##<\tau>## and ##<\omega>## but I can't figure it out completely.
The order of the Galois group divides the degree of the extension, which you say you know is p(p-1). Do you know any numbers that must divide the order of the galois group?
Knowing the order of the Galois group helps a lot in figuring out what it is, because you can often rule out relationships existing between elements that you wouldn't have immediately guessed.
Maybe I am mistaken but if I know the degree of the extension and I know it is Galois, don't I know that group is going to be of the order exactly the same as the degree? So I know that the order of the whole Galois group is p(p-1)? Now I know that I have a subgroup of order p which is immediately cyclic and I have a subgroup of order p-1 generated by ## \sigma ## and as the two groups are of coprime order their intersection is the identity? Now from here I don't know what to do
You say the subgroup of order p-1 is generated by a single element ##\sigma##, so that it's also cyclic?
Edit: Because if you're correct, and both are cyclic, so is their direct product, and then you won't have the relations you described.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
