Geometric Sequence and Recursive Definition
In summary, to find t10 in a geometric sequence given t3 = 4 and t6 = 4/27, you can use the formula tn = t1(r)^(n-1) and work your way up to t10. For the recursive definition, the pattern is to add 3 to the previous term and then raise it to a power equal to the term number minus 1.
rought
34
In a Geometric Sequence find t10. t3 = 4 and t6= 4/27
Give a recursive definition for the sequence: 1, 4, 13, 40...
I know that a Geometric sequence is: tn=t1(r)n-1
And that a recursive formula starts off with tn-1
I'm not sure where to go from here...
A geometric sequence has terms that look like this: {a, ar, ar2, ar3, ...}, where each term is r time the previous term. In your first problem, you have t3 = 4, so t4 = rt3 = 4r, t5 = 4t4 = ? Just work your way up to the ones you want to find.
In your second problem, you have {1, 4, 13, 40, ...}
The 2nd term is the first plus 3. The 3rd term is 9 plus the 2nd. The 4th term is 27 + the 3rd. Do you see a pattern?
To find t10 in a geometric sequence, we can use the formula tn = t1(r)^(n-1). In this case, we are given t3 = 4 and t6 = 4/27. We can use these values to find the common ratio, r.
First, we can rewrite t3 = 4 as t1(r)^2 = 4, and t6 = 4/27 as t1(r)^5 = 4/27.
Dividing the second equation by the first, we get (r)^3 = 1/27.
Taking the cube root of both sides, we get r = 1/3.
Now, we can plug in this value to the original formula, tn = t1(r)^(n-1), to find t10.
t10 = t1(1/3)^9.
Without knowing the value of t1, we cannot find the exact value of t10, but we can express it in terms of t1 as t10 = t1(1/3)^9.
A recursive definition for the sequence 1, 4, 13, 40... can be written as:
t1 = 1
tn = 3tn-1 + 1, for n > 1
This means that the first term, t1, is equal to 1, and each subsequent term is found by multiplying the previous term by 3 and adding 1. This recursive definition can also be written as tn = 3^(n-1) + 1.
FAQ: Geometric Sequence and Recursive Definition
What is a geometric sequence?
A geometric sequence is a sequence of numbers where each term is found by multiplying the previous term by a constant ratio, called the common ratio. For example, the sequence 2, 6, 18, 54, ... is a geometric sequence with a common ratio of 3.
What is the formula for finding the nth term of a geometric sequence?
The formula for finding the nth term of a geometric sequence is:
an = a1 * rn-1, where a1 is the first term and r is the common ratio.
Can you give an example of a real-life application of geometric sequences?
Geometric sequences can be found in many natural phenomena, such as population growth, compound interest, and radioactive decay. For example, the growth of a bacteria colony can be modeled using a geometric sequence, where each generation is a multiple of the previous one.
What is a recursive definition?
A recursive definition is a way of describing a sequence or function using previous terms or values. In other words, the definition of each term depends on the previous term. In a geometric sequence, the recursive definition is an = an-1 * r.
How can you determine if a sequence is geometric?
To determine if a sequence is geometric, you can check if the ratio between consecutive terms is constant. If the ratio is the same for all terms, then the sequence is geometric. Additionally, you can use the formula an = a1 * rn-1 to find the common ratio and see if it applies to all terms in the sequence.
