MHB Geometric Sequence find the 23rd term.
The function for the geometric sequence is defined as a_n = a_1•r^(n-1), where a_1 is the initial value of 25 and r is the common ratio of 1.8. To find the 23rd term, the calculation is a_23 = 25•(1.8)^(22), resulting in a_23 = 10326071.3. The answer is confirmed to be correct when rounded to one decimal place. The discussion also touches on the rationale for presenting the answer to one decimal place.
mathdad
A geometric sequence has an initial value of 25 and a common ratio of 1.8. Write a function to represent this sequence . Find the 23rd term.
My Effort:
The needed function is
a_n = a_1•r^(n-1), n is the 23rd term, r is the common ratio and a_1 is the initial value.
a_23 = 25•(1.8)^(23 - 1)
Is this correct?
Mathematics news on Phys.org
yes
a_23 = 25 * 1.8(23-1)
a_23 = 25 * (1.8)^(22)
a_23 = 10326071.3
Correct?
To one decimal place, yes. Do you have a reason for choosing to write the answer to one decimal place?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
