Geometric series and its derivatives
In summary, the conversation discusses a person's explanation for why 1-2+3-4+5... towards infinity equals 1/4. The person's explanation involves taking a derivative and plugging in for x=-1, which does not follow the requirement for convergence. This result is used in physics, such as in String Theory.
thepatient
164
I was browsing online and stumbled upon someone's explanation as to why 1 -2 +3 -4 + 5... towards infinity= 1/4. His explanation didn't make sense to me. He starts with a geometric series, takes a derivative, and plugs in for x = -1, and gets a finite value of 1 -2 + 3 - 4 +... = 1/4. It doesn't make sense to me that he would plug in for x = 1, since the series equals 1/(1-x) only for |x|< 1 and converges when |x| <1. So I wanted to know what you guys think.
0xn = 1/(1-x), |x| < 1
This is how the work is shown. He wants to show that 1-2+3-4+5-...=1/4. He begins with:
1 + x + x2 + x3 +... = 1/(1-x)
Takes a derivative of both sides:
1 + 2x + 3x2 + 4x3 + ... = 1/(1-x)2
plugs in for x = -1
1 -2 +3 -4 + 5... = 1/4
Are these operations valid?
No, because the requirement for the infinite sum to converge was |x|<1, which is not obeyed by setting x=-1.
That is what I thought as well. But apparently, this result is used to prove that 1 + 2 + 3 + 4 +5... = -1/12, and apparently that result is used in physics like String Theory.
FAQ: Geometric series and its derivatives
1. What is a geometric series?
A geometric series is a series of numbers where each term is found by multiplying the previous term by a constant number, called the common ratio. The general form of a geometric series is a + ar + ar² + ar³ + ..., where a is the first term and r is the common ratio.
2. How do you find the sum of a geometric series?
The sum of a geometric series can be found using the formula Sn = a(1 - rn) / (1 - r), where Sn is the sum of the first n terms, a is the first term, and r is the common ratio. If r is greater than 1, the series will diverge (not have a finite sum).
3. What are the applications of geometric series?
Geometric series have many applications in mathematics, science, and finance. They can be used to model population growth, compound interest, and exponential functions. They are also used in calculus to find the area under a curve.
4. What is the derivative of a geometric series?
The derivative of a geometric series is another geometric series with a common ratio of r. This means that the derivative of a geometric series is also a geometric series. The first term of the derivative series is ra and the common ratio is r.
5. How is a geometric series related to the geometric mean?
The geometric mean of a set of numbers is the nth root of their product, where n is the number of terms in the set. In a geometric series, the product of the terms is equal to the sum of the first term and the sum of all subsequent terms. Therefore, the geometric mean of a geometric series is equal to the common ratio. In other words, the geometric mean is the constant multiplier between each term in a geometric series.
