MHB Geometric Series: Find Sum of Infinity - 9-32-n
To find the sum of the infinite geometric series given by the expression 9 - 32^(-n), the appropriate formula is S∞ = a / (1 - r), where 'a' is the first term and 'r' is the common ratio. The discussion raises questions about whether the series is indeed geometric and clarifies that limits may not be necessary for this problem. It is emphasized that if the common ratio 'r' is less than 1, the sum converges to a finite value, while if 'r' is 1 or greater, the sum does not exist. The final conclusion is that the sum of the infinite series can be calculated using the geometric series formula under the right conditions.
ChelseaL
Given that the sum of the first n terms of series, s, is 9-32-n
Find the sum of infinity of s.
Do I use the formula S\infty = \frac{a}{1-r}?
I can't tell what your geometric terms are. Are they supposed to be $9 - 3^{2-n}\;for\;n\in \mathbb{N}$? Are you SURE that's a geometric sequence?
I'm not exactly sure what the topic is, but this is the part before it.
https://mathhelpboards.com/discrete-mathematics-set-theory-logic-15/geometric-series-24025.html
What you can do is:
$$S_{\infty}=\lim_{n\to\infty}S_n$$
How do I work it out from there?
Have you worked with limits before?
This is my first time hearing this term. I don't think my lecturer expects us to use that method since we never covered it in class.
Okay, then the formula you first cited works in this case:
$$S_{\infty}=\sum_{k=0}^{\infty}a_n=\frac{a}{1-r}$$
It is my understanding your sum is:
$$\sum_{k=1}^{\infty}a_n$$
In this case, you would need to write:
$$S_{\infty}=\frac{a}{1-r}-a=\frac{ar}{1-r}$$
Consider the finite geometric series [math]S= a+ at+ at^2+ at^3+ \cdot\cdot\cdot+ at^n[/math]. Subtract a from both sides: [math]S- a=at+ at^2+ at^3+ \cdot\cdot\cdot+ at^n[/math]. Factor "t" out of the right side: [math]S- a= t(a+ at+ at^2+ \cdot\cdot\cdot+ at^{n- 1})[/math]. The sum on the right is almost the same as the original sum- it is only missing the "[math]at^n[/math]" term. Add and subtract [math]at^n[/math] inside the parentheses:
[math]S- a= t(a+ at+ at^2+ \cdot\cdot\cdot+ at^{n- 1}+ at^n- at^n)= t(a+ at+ at^2+ \cdot\cdot\cdot+ at^{n- 1}+ at^n)- at^{n+1}= tS- at^{n+1}[/math]
Add [math]at^{n+1}[/math] to both sides:
[math]S- a+ at^{n+ 1}= tS[/math]
[math]S- tS= (1- t)S= a- at^{n+1}= a(1- t^{n+1})[/math]
Finally, divide both sides by 1- t:
[math]S= \frac{a(1- t^{n+1})}{1- t}[/math]
The sum of the infinite series, [math]\sum_{n=0}^\infty at^n[/math] is the limit of that as n goes to infinity. If [math]t\ge 1[/math], that limit, so that sum, does not exist. If [math]t<1[/math], [math]t^{n+ 1}[/math] goes to 0 so
[math]\sum_{n=0}^\infty at^n= \frac{a}{1- t}[/math].
  • · Replies 17 ·
