MHB Geometric Series with Complex Numbers
The discussion revolves around finding the real numbers n and m in a geometric series represented by the elements m-3i, 8+i, and n+17i. The user initially attempted to use the conjugate method to compare the ratios but encountered complex algebraic expressions. A suggestion was made to derive two expressions for the common ratio, leading to the equations r = (8+i)/(m-3i) and r = (n+17i)/(8+i). Solving the resulting system of equations, it was found that one solution is m=2 and n=6, with a note that another solution may exist. The conversation highlights the importance of finding equivalent expressions for the common ratio in geometric series involving complex numbers.
Yankel
Hello all,
Three consecutive elements of a geometric series are:
m-3i, 8+i, n+17i
where n and m are real numbers. I need to find n and m.
I have tried using the conjugate in order to find (8+i)/(m-3i) and (n+17i)/(8+i), and was hopeful that at the end I will be able to compare the real and imaginary parts of the ratio, but I got difficult algebraic expressions, so I figure out it's not the way. Can you assist please ?
Thanks !
Mathematics news on Phys.org
Yankel said:
Hello all,
m-3i, 8+i, n+17i
Thanks !
Rather than the conjugate think about the sequence side of it instead - can you find a pair of expressions for the common ratio (and therefore equal to each other)?
That's what I was trying to do, to find two expressions for the ratio. I need two equations somehow.
$r= \dfrac{8+i}{m-3i} = \dfrac{n+17i}{8+i}$
$63+16i = (mn+51)+(17m-3n)i$
$mn=12$
$17m-3n=16$
one solution for the system is $m=2$, $n=6$
there is another possible, but I'm too lazy to check.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
