Geometrical interpretation of Ricci and Riemann tensors?
In summary, the Riemann tensor contains all the information about the shape and volume of a space, while the Ricci tensor is a simplified version of the Riemann tensor that only contains information about the volume. If the Riemann tensor is zero, the space is flat, and if the Ricci tensor is zero, the space is empty. The Ricci scalar is a measure of scalar curvature and is directly proportional to the difference in volume or surface area of a small geodesic ball in a space compared to a reference ball in flat space. Mathematical proof of these statements can be found in the Einstein equations and the equation of geodesic deviation.
Victor Alencar
I do not get the conceptual difference between Riemann and Ricci tensors. It's obvious for me that Riemann have more information that Ricci, but what information?
The Riemann tensor contains all the informations about your space.
Riemann tensor appears when you compare the change of the sabe vector(or other tensor) when it takes two different paths. You can see it comutanting two differents cov. derivatives of a vector ou computing the parallel displacement.
Studying general relativity I saw : "If Riemann tensor is zero, the space is flat; if the Ricci tensor is zero the space is empty". Someone knows some mathematical proof of this affirmation?
And what the Ricci scalar say to us? It's always directly proporcional to curvature?
Ricci can be taken as the trace of the Riemann tensor, hence it is of lower rank, and has fewer components. If you have a small geodesic ball in free fall, then ( ignoring shear and vorticity ) the Ricci tensor tells you the rate at which the volume of that ball begins to change, whereas the Riemann tensor contains information not only about its volume, but also about its shape.
If the Riemann tensor is zero, then the equation of geodesic deviation reduces to the equation of a straight line, meaning that the separation vector between geodesics is constant. Hence, initially parallel lines will remain parallel everywhere - you are dealing with a flat manifold.
As for empty space, this is just a consequence of the Einstein equations. If you write them in trace-reversed form, and set T=0 ( empty space ), you get a vanishing Ricci tensor. Hence, empty space implies Ricci flatness.
The Ricci scalar is the trace of the Ricci tensor, and it is a measure of scalar curvature. It can be taken as a way to quantify how the volume of a small geodesic ball ( or alternatively its surface area ) is different from that of a reference ball in flat space.
Perhaps you might find this helpful :
http://arxiv.org/pdf/gr-qc/0401099.pdf
Likes Diferansiyel and Victor Alencar
Related to Geometrical interpretation of Ricci and Riemann tensors?
1. What is the geometrical interpretation of Ricci and Riemann tensors?
The Ricci and Riemann tensors are mathematical objects used in the field of differential geometry to describe the curvature of a space. The Ricci tensor represents the local curvature of a space, while the Riemann tensor represents the overall curvature of a space. Together, they provide a complete geometrical description of a space and its curvature.
2. How are the Ricci and Riemann tensors related?
The Ricci tensor is derived from the Riemann tensor through contraction, which is a mathematical operation that reduces the number of indices in a tensor. Specifically, the Ricci tensor is obtained by contracting the Riemann tensor along two indices, while the Riemann tensor has four indices.
3. What do the components of the Ricci and Riemann tensors represent?
The components of the Ricci and Riemann tensors represent the curvature of a space in different directions. In general, the larger the values of the components, the more curved the space is in that direction. However, the interpretation of these values can vary depending on the specific application and context.
4. How do the Ricci and Riemann tensors relate to Einstein's field equations?
The Ricci tensor is a key component in Einstein's field equations, which describe how matter and energy interact with space and time to produce gravitational effects. The Riemann tensor is also involved in these equations, but through its contraction to the Ricci tensor. In essence, the Ricci and Riemann tensors provide the mathematical framework for understanding the relationship between matter and the curvature of space.
5. Can the Ricci and Riemann tensors be visualized?
While the Ricci and Riemann tensors themselves cannot be visualized in the traditional sense, their effects on space can be visualized through various techniques such as curvature plots, geodesic deviation, and tidal forces. These techniques use the values of the Ricci and Riemann tensors to generate visual representations of the curvature of a space.
  • Differential Geometry
