Geometry (circles and triangles) proofs
In summary, the problem asks for the similarity of triangles ABD and CDE. The orig. poster (Beam Me Down) thought that BC and CD were parallel, but this is incorrect. The tangent chord property can be used to prove the similarity.
Beam me down
47
I'm having some trouble with one particular geometry proof:
From a point A outside a circle, a secant ABC is drawn cutting the circle at B and C, and a tangent AD touching at D. A chord DE is drawn equal in length to chord DB. Prove that triangles ABD and CDE are similar.
From that I've drawn the following:
http://img96.imageshack.us/img96/139/circle9we.gif
[tex]\angle ADB = \angle CED[/tex] (as [tex]\angle ADB[/tex] and [tex]\angle CED[/tex] are alternant sements)
[tex]\angle CBD = 180 - \angle CED [/tex] (1) (as they are opposite angles in a cyclic quadrilateral)
[tex]180 - \angle CBD = \angle DBA[/tex] (2) as CBA is a straight line
[tex]\therefore \angle CED = \angle DBA[/tex] substitute (1) into (2) This indicates that [tex]\angle BDA = \angle DBA[/tex]. Is that right? And is that enough to prove that [tex]\bigtriangleup ABD \sim \bigtriangleup CDE[/tex] ?
Nah, this is wrong.
[tex]\angle ADB \neq \angle CED[/tex]
It should read:
[tex]\angle ADB = \angle ECD[/tex]
(notice that the 2 chords DE = DB).
Can you see why? :)
VietDao29 said:
Nah, this is wrong.
It should read:
Can you see why? :)
Is it because [tex]\angle ECB = \angle CDA = 90[/tex] which would make EC and DB parrelel in turn making [tex]\angle ADB[/tex] and [tex]\angle ECD[/tex] alternate angles?
I don't know how to prove this, but if [tex]\angle CDA = 90[/tex] that means CD is the diameter. No that has to be true as the radius (of which the diameter is an extension) meets any tangent at right angles, therefore the converse must be true.
If CD is the diameter could someone set me on the right track as to how to prove it?
Nah, it's wrong, since the problem does not state that EC and DB are parallel. You cannot assume that...
You should note that:
[tex]\angle ADB = \angle BCD[/tex] (Tangent chord property)
[tex]\angle BCD = \angle ECD[/tex] (DE = DB)
Can you go from here? :)
One more little hint if you need it...There is a segment on that circle that subtends an angle that you can find fairly easily...it also subtends a different angle :wink:
*edit* additionally, why is it assumed that the diameter of the circle connects the points D and C??...if you put C somewhere else you still get a secant ABC.
Who assumed that CD is a diameter ? It isn't in general.
That it isn't a diameter was also my thought...hence my reason for asking why it was assumed
Ah, I see. The orig. poster (Beam Me Down) was the only one who thought that (it's not correct).
I was actually unfamiliar with the tangent chord property that VietDao brought up (till he mentioned it and I googled for it).
The way I did this was in observing that
angle DEC = 180 - angle DBC (cyc quad) = angle ABD (supplementary angles).
Let's extend AD further and call a point on it F (A, D and F are collinear and D lies in between A and F). It should be obvious from the symmetry of DE = DB that angle EDF = angle BDA = theta (say). Then angle BDE = 180 - 2*theta. Angle BCE = 2*theta (opp angles, cyclic quad).
Now observe that angle DCE = angle DCB (equal chords ED and DB subtend equal angles). Therefore angle DCE = theta = angle BDA.
Since we've proven two corresponding angle pairs are equal (DEC = ABD & DCE = BDA), we're done.
In the process of doing this, one can also prove the tangent chord property. :smile:
I thought for a second that that I'd proved that [tex]\angle ADC[/tex] was a right angle. But its definitely not in all cases.
You see how to do the problem now ? :smile:
Related to Geometry (circles and triangles) proofs
1. What is a proof in geometry?
A proof in geometry is a logical argument that shows the validity of a geometric statement or theorem. It involves using previously established definitions, axioms, postulates, and theorems to justify each step and ultimately arrive at a conclusion.
2. Why are proofs important in geometry?
Proofs are important in geometry because they allow us to verify the truth of geometric statements and theorems. They also help us to understand the underlying concepts and relationships between different geometric figures and properties.
3. How do I begin a proof?
To begin a proof, you should carefully read and understand the given statement or theorem. Then, identify any relevant definitions, axioms, or theorems that can be used to support your argument. It is also helpful to draw a diagram and label any given information.
4. What are some common strategies for proving geometric theorems?
Some common strategies for proving geometric theorems include using deductive reasoning, drawing diagrams, using algebraic equations, and using logical arguments to show the relationships between different geometric figures.
5. How can I check if my proof is correct?
To check if your proof is correct, you can go through each step and make sure that it follows logically from the previous step. You can also check if your conclusion is supported by the evidence and if it aligns with the given statement or theorem.
