{Geometry} Find the Area of the quadrilateral
In summary, a quadrilateral is a polygon with four sides and four angles. The area of a quadrilateral can be found using the formula A = bh and can also be found by multiplying the length and width of the shape for some types of quadrilaterals. There are various types of quadrilaterals, each with their own properties and area formulas. The area of a quadrilateral cannot be negative as it is a measure of the space inside the shape. Perimeter is the distance around the outside of a shape, while area is the measure of the space inside the shape and is typically measured in units squared.
youngstudent16
59
http://i.imgur.com/lzTN7If.png
Excuse the bad drawing
Point E lies on the side AC of the square ACBD. The segment EB is broken up into 4 equal parts as well as the segment ED. If JK = 3 find the area of the quadrilateral FGKJ[/B]
Trapezoid equation to find the height and the area. As well as pythagoras equation
My attempt was I know that quadrilateral is a isosceles trapezoid because you have opposite parallel sides and two sides equal. I assumed since the segment JK was 3 FG was 1 and the side BD was 4. I also assumed E split AC in half. I tried to calculate the entire segment EB using 4^2+2^2=sqrt(20) I divided that by 4 to find length of one of the 4 equal segments. Then multiplied that by 2 to get sqrt(5). Used the formula for finding H of an isosceles trapezoid and got 2. Area then would be 1/2(4)(2)=4
My geometry is weak so don't have confidence in the approach. Thanks for any help
[/B]
I do not know if the diagram you provide is your interpretation of a problem or the diagram given in a problem. However, as drawn, ACBD would not be a square, since the name implies that its sides are AC, CB, BD, and DA. Also, do you mean that you need the area of FGKJ?
Yes picture is not drawn to reality this is error in my free hand ability. Yes I'm sorry that was a typo you are right FGKJ I'll fix that
You really don't need much geometry to solve this problem except similar triangles.
Applying the Pythagorean Theorem is nice, but unnecessary.
Likes youngstudent16
The sides not being equal are not what I meant. When labeling a shape, the order in which you label describes the sides that are present. Usually, you want to label the shape clockwise or counterclockwise. So for ex. ABCD has sides AB, BC, CD, and DA. I was pointing out that your image, as drawn, shows a square ACDB, not ACBD. Your method seems to be correct, as the area is 4 as far as I can see. If it is an simpler for you, the question could be solved entirely with the pythagorean theorem, just splitting the trapezoid into 2 equal triangles and a rectangle. Also, can you justify your assumptions of E being the midpoint of AC, and that FG has length 1?
Ah thank you sorry for the confusion.
Your hint helped me also with similar triangles
EJK is similar to EBD
SO EJ/EB=EK/ED Therefore BD=EB/EJ *JK =4 Therefore area of EBD=8 then the area of EJK would be (3/4)^2 *8 and EFG would then be (1/4)^2 * 8 So then you take the difference of those to get the area of the quadrilateral which is 4.
Exactly, similar triangles can be used to find the areas, which I believe was a hint from SteamKing and not myself. Also, as far as I can see, E does not need to be the midpoint of AC.
Related to {Geometry} Find the Area of the quadrilateral
1. What is a quadrilateral?
A quadrilateral is a polygon with four sides and four angles. Some common examples of quadrilaterals include squares, rectangles, parallelograms, and trapezoids.
2. How do you find the area of a quadrilateral?
The area of a quadrilateral can be found by using the formula A = bh, where A is the area, b is the base, and h is the height. For some quadrilaterals, such as squares and rectangles, the area can also be found by multiplying the length and width of the shape.
3. What are the different types of quadrilaterals?
There are many different types of quadrilaterals, including squares, rectangles, parallelograms, rhombuses, and trapezoids. Each type has different properties and formulas for finding the area.
4. Can the area of a quadrilateral be negative?
No, the area of a quadrilateral cannot be negative. It is a measure of the space inside the shape and therefore cannot have a negative value.
5. What is the difference between perimeter and area?
Perimeter is the distance around the outside of a shape, while area is the measure of the space inside the shape. Perimeter is usually measured in units of length, while area is measured in units squared.
