I Geometry of Cherenkov radiation
  • I
  • Thread starter Thread starter AndreasC
    Geometry
The discussion centers on understanding the Cherenkov angle θ and the role of wavefronts in its propagation. It emphasizes the need to assume that wavefronts are tangent to circles to establish the right angle between the direction of propagation and observed wavefronts. The confusion arises around the application of Huygens's Principle, particularly regarding the emission of radiation by a charge moving faster than the phase velocity in a medium. The participant grapples with why points along the tangent line represent a wavefront with the same phase, leading to a moment of clarity about the nature of radiation emitted from the electron. Ultimately, the discussion highlights the complexities of wave behavior in the context of Cherenkov radiation.
AndreasC
As an explanation to the Cherenkov angle, images such as this are offered:
Huygens-construction-of-a-conical-Cherenkov-wavefront-a-charged-particle-traveling-in-a.png
This is used to explain the Cherenkov angle θ at which the Cherenkov radiation appears to be propagating. To figure this angle out however one has to assume that the wavefronts are tangent to each of these circles, so that then the direction of propagation and the observed wavefronts have a right angle between them. I don't really get why. I think I'm missing something very obvious, and it probably has to do with interference, but I can't quite explain it.
To be more specific, take a point where that first circle meets the wavefront. If you wait just a little bit, won't the emitted radiation from the second circle reach that point? Won't it then appear to be coming from a different angle?
This is using the Huygens's Principle for emission of waves with velocity ##c_{\text{mat}}=c/n## by a charge moving with a velocity larger than ##c_{\text{mat}}##.
I'm not entirely sure how this applies to answer what I said in the end though... I'm also not entirely sure why all the points in that tangent line have the same phase. Perhaps that's why I'm confused.
Wait I see what you mean now about Huygens' principle, but where I'm stuck I guess is why these points are a wavefront, as in why do these points along this line have the same phase, but not some other ones? I think I've misunderstood the nature of radiation being emitted from the electron...
Oof nevermind, I was saying nonsense because I was confused. I see what you mean now, thanks!
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
