Geometry of Time Dilation
In summary, the formulas for gravitational time dilation and velocity time dilation both result in the same dilated time.
mcjosep
35
I was recently exploring time dilation from Gravity and from velocity and I came up with an interesting derivation that I have not seen before. I was wondering if there is a paper published showing these relationships like this before and where I could find it?
First you start with the gravitational time dilation formula where:
T_1=Tsqrt(1-((2GM)/rc^2))
and rather than entering r for the radius we replace r with the Schwarzschild radius formula ##((2GM)/C^2)x##
with an ##x## at the end representing how many Schwarzschild radii you are away from the center. This brings the formula to look like:
T_1=Tsqrt(1-(2GM)/((((2GM)/c^2)x)c^2))
Which when simplified breaks down to:
T_1=Tsqrt(1-1/x)
and if you make ##T=1## then you just get
=sqrt(1-1/x)
This is very similar to the one in many physics books ##=sqrt(1-r_0/r)## where ##r_0## is equal to the Schwarzschild radius and then r equals the radius from the center. The formula above it just makes it slightly simpler due to making ##r_0## equal to 1 and x equal to how many radii a point you are observing is from the center of the mass.
That is the gravitational time dilation side portion of this relationship. Now for the Velocity time dilation side we use a similar methodology and start with:
T_0=Tsqrt(1-v^2/c^2)
Now we make ##T## equal to 1, ##v## equal to 1, and ##c## to ##y## because now we are going to make ##c## a variable.
T_0=sqrt(1-1/y^2)
What you see now "##1/y^2##" is showing the velocity as a constant 1 and ##y## represents how much faster light is going than the velocity constant of 1. If the above were to show the fraction as ##1/5^2## then this would be the same as saying an object is going at a velocity 1/5th the velocity of light.
So now if we solve the velocity and gravitational time dilation formulas so that we can see how they dilate time to come up with the same result:
sqrt(1-1/x)=sqrt(1-1/y^2)
We can simplify this to
x=y^2
So let's say your radius from the center of the mass ##x## is equal to 4 Schwarzschild radii then the speed an object must move to get the same dilation due to velocity must be equal to half the speed of light since ##y## equals 2 and represents the speed of light going two times faster than the moving object.
I was pretty happy to see a seemingly simple yet complex set of formulas breakdown into one of the simplest algebraic formulas.
This can also be constructed geometrically as seen below:
[1]: http://i.stack.imgur.com/nSC7Y.jpg
The edge of the black circle represents the Schwarzschild radius and each point on the x-axis is another radii away from the center. The Y axis has points that are the square root of x.
Let me know what you think. Please check my math.
You can use the same methodology to break down other formulas as well.
Circular Orbit Velocity
v=sqrt((GM)/r)
Then add in the Schwarzschild radius formula for ##r## and get
v=sqrt((GM)/(((2GM)/c^2)x)
Which then simplifies to
c/(sqrt(2)*sqrt(x))
and again you can replace ##c## with 1 and now the formula will split out what percent the speed of light you are going.
This also works with orbital energy:
E=c^2/4x
Critical or escape velocity:
v=c/sqrt(x)
and that formula comes out with the same answer as ##y## in ##x=y^2## from the formulas above.
There are a few mistakes.
mcjosep said:
we are going to make c a variable
c is a constant, not a variable.
You cannot set those two equations equal to each other since they cannot both be valid equations at the same time.
mcjosep said:
you can replace c with 1
You cannot do that since you already set v to 1 and v<c.
well you can make C a "variable" when the changing number still represents c. Its just a different way of looking at the formula.
and per your "cannot since you already set v to 1 and v<c" comment. I actually took v out of the question and replaced it with % of c.
You cannot have gravitational time dilation and time dilation from velocity at the same time?
Sure you can, but not using those formulas. The first formula applies to a clock which is stationary in the standard coordinates in Schwarzschild spacetime. The second formula applies to a clock which is moving in the standard coordinates in Minkowski spacetime.
If you want to consider both together then you need a formula which applies to a clock which is moving in Schwarzschild spacetime. See here: http://en.wikipedia.org/wiki/Time_dilation#Time_dilation_due_to_gravitation_and_motion_together
Thats interesting that they do not work together yet the critical escape velocity formula works using the same logic from that derivative of x=y^2
Related to Geometry of Time Dilation
1. What is the concept of time dilation in the geometry of space-time?
Time dilation is the phenomenon where time appears to pass at different rates for observers in different frames of reference. In the geometry of space-time, this is explained by the curvature of space caused by massive objects, which can affect the flow of time.
2. How does the theory of relativity explain time dilation?
The theory of relativity, specifically the special theory of relativity, explains time dilation by stating that the laws of physics are the same for all observers in uniform motion. This means that the perception of time passing at different rates is relative to an observer's frame of reference and their relative speed to other objects.
3. What is the difference between gravitational time dilation and velocity time dilation?
Gravitational time dilation is caused by the curvature of space due to the presence of massive objects, while velocity time dilation is caused by the relative speed between two objects. In gravitational time dilation, time appears to pass slower in a stronger gravitational field, while in velocity time dilation, time appears to pass slower for objects moving at high speeds.
4. How does the geometry of space-time affect the measurement of time?
The geometry of space-time, specifically the curvature caused by massive objects, can affect the measurement of time by causing time to pass at different rates for different observers. This means that time is not a fixed, universal concept but is relative to an observer's frame of reference.
5. Can time dilation be observed in everyday life?
Yes, time dilation can be observed in everyday life, although the effects are very small. For example, due to the Earth's gravitational field, time passes slightly slower at the surface compared to higher altitudes. Additionally, the effects of velocity time dilation can be observed in high-speed travel, such as in airplanes and satellites.
