MHB Geometry Problem: Find Shaded Area Given Triangle & Inner Circle
  • Thread starter Thread starter Nono713
    Fun Geometry
The geometry problem involves finding the shaded area within a triangle given the lengths of its sides and the distances from the vertices to the circumcenter. There is some confusion regarding the diagram, particularly about the point labeled "x," which is clarified to be the circumcenter O of the circles rather than the center of the inner circle. The assumption that the inner and outer circles are concentric is crucial for solving the problem, as it simplifies the calculations. If the circles are not concentric, the solution would become significantly more complex. The discussion emphasizes the importance of accurately interpreting the diagram and the relationships between the triangle and the circles.
Nono713
MHB
Here's a nice geometry problem, not hard at all if you can see what's really going on.
You are given the lengths AB, AC and BC of the triangle, as well as the distances of all three of the vertices to the triangle's circumcenter O. The inner circle is tangent to (AB). Find the shaded area.
https://lh3.googleusercontent.com/-qqF-3y81rvI/UQjt7jishKI/AAAAAAAAAII/gP8G0dgKCmc/w497-h373/cercles.gif
Solution (don't click if you want to work it out yourself!):
Let M be the midpoint of [AB]. Then (OM) is perpendicular to (AB). We know |OA|, so by Pythagoras we have:
$$|OA|^2 = |OM|^2 + |AM|^2 = |OM|^2 + \left ( \frac{1}{2} |AB| \right )^2$$
Because the inner circle is tangent to (AB) at M (as $|OA| = |OB|$) its area is:
$$A_\text{inner} = \pi |OM|^2 = \pi \left [ |OA|^2 - \left ( \frac{1}{2} |AB| \right )^2 \right ]$$
And the area of the outer circle is just:
$$A_\text{outer} = \pi |OA|^2$$
Thus the area of the shaded region is:
$$A_\text{shaded} = A_\text{outer} - A_\text{inner} = \pi |OA|^2 - \pi \left [ |OA|^2 - \left ( \frac{1}{2} |AB| \right )^2 \right ] = \pi \left ( \frac{1}{2} |AB|\right )^2 = \frac{\pi}{4} |AB|^2$$
The maximum value for $|AB|$ is clearly $2 |OA|$ when [AB] is a diameter of the circumcircle, thus $A_\text{shaded} \leqslant A_\text{outer}$.
Mathematics news on Phys.org
What is the meaning of "x" ,in your diagram ?
people will misunderstand that x is the center of the small
circle .
I think your solution is based on the assumption that the
two circles are concentric circles
(but your problem did not reveal this fact )
If they are not concentric circles,the solution will be much
more complicated,
(in this case point M is not on the small circle)
How do you think ?
circle .
more complicated,
How do you think ?
There is no "x", it's indeed just a cross indicating the centre O of the inner and outer circles. I thought that was clear enough (and the diagram is not mine). The two circles must be concentric, it follows from the fact that the outer circle is the circumcircle of the triangle (stated in the problem) and that the inner circle is clearly tangent to the midpoint of AB, by |OA| = |OB|.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
