MHB Geometry problem midpoint theorem
  • Thread starter Thread starter mathlearn
    Geometry Theorem
The discussion revolves around proving the midpoint theorem in a triangle, specifically focusing on triangle ABM where E is the midpoint of AB and EO is parallel to OM. Participants highlight that triangles ODC and MDB are congruent by SAA, leading to the conclusion that BMCO forms a parallelogram. The midpoint theorem states that a line through the midpoint of one side of a triangle, parallel to another side, will bisect the third side. The conversation also touches on proving relationships such as AO=OM and the congruence of triangles BOC and BMC. Overall, the midpoint theorem is effectively applied to solve the geometry problem presented.
mathlearn
A problem on geometry proof
Hi (Smile),
When considering the $$\triangle$$ ABM E is the midpoint of AB
& EO //OM (given).I think this is the way to tell AO=OM , Help .Many Thanks (Smile)
Mathematics news on Phys.org
There are a lot of details to consider but the key fact needed is $$\triangle ODC \cong \triangle MDB$$ by SAA.
Many Thanks (Smile)
But I don't think there's a need to do so :)
I Think It has got something to do with
When considering the $$\triangle ABM$$ E is the midpoint of AB
& EO //OM (given)
Can you figure it out?Help.
Many Thanks (Smile)
mathlearn said:
Many Thanks (Smile)
& EO //OM (given)
Many Thanks (Smile)
I didn't mean to imply that my approach was the only way to do the problem. I just thought it would be straightforward. After you get the triangles I mentioned congruent, it is trivial that BMCO is a parallelogram and the rest of the problem follows.
The theorem that you are thinking of is a standard high school result:
In a plane, if a line goes through the midpoint of one side of a triangle and is parallel to a second side of the triangle, then it goes through the midpoint of the third side of the triangle.
A nice approach by saying the two triangles $$ODC \cong MBA$$ :)
By considering $$\triangle ABM$$
It is given that 'E' is the midpoint of AB. According to mrtwhs
"In a plane, if a line goes through the midpoint of one side of a triangle and is parallel to a second side of the triangle, then it goes through the midpoint of the third side of the triangle"
Line EO meets the side AM of the $$\triangle ABM$$
and it is also given that EC//BM $$\therefore EO//BM$$
And using the converse of the midpoint theorem
The straight line through the midpoint of one side of a triangle and parallel to another side,bisects the third side.
It can be proved that AO=OM;(Smile)
And can you help me tell that MC//BF and 2AD=3AO
Many Thanks :)
i) and ii) can be proved using the midpoint theorem. Using the fact that BM || EC and MC || BF, show that triangles BOC, BMC are congruent and triangles CMO and BMO are congruent. From that it follows that BMCO is a parallelogram (each diagonal of a parallelogram divides the parallelogram into two congruent triangles). To prove iv), use the fact that the diagonals of a parallelogram bisect each other.
Many Thanks :)
When considering the $$ \triangle AMC$$
O is the midpoint of AM (AO=OM)
F is the midpoint of AC (AF=FC)
$$\therefore OF//MC $$
$$\therefore MC//BF$$
And I now see
Help me to proceed
Many Thanks :)
Concerning $2AD=3AO$: We have proved that $AO=OM$ and that $BMCO$ is a parallelogram. Diagonals in a parallelogram are divided in half; therefore, $OD=DM$. Thus, $2AD=2(AO+OD)=2(OM+OD)=2(2OD+OD)=6OD$ and $3AO=3OM=3\cdot2OD=6OD$.
Thank you very much ! (Smile)
