Geophysics: Fluid Dynamics Problem
In summary, the conversation discusses the velocity field and vorticity of a flow with uniform rotation. A small perturbation is added to the state of uniform rotation, and the nonlinear terms in the momentum equation are compared to the linear ones. The dispersion relation for the perturbed flow is derived and the polarisation of the inertial waves is determined. The waves are found to be dispersive and anisotropic, with a group velocity that is not necessarily aligned with the wavenumber vector. The problem also mentions the possibility of the fluid being incompressible.
Angelo Pascal
New poster has been reminded to show their work on schoolwork problems
Consider an inviscid fluid in a uniformly rotating frame of reference. The effect of
gravity is neglected. In the frame rotating with an angular velocity Ω, the momentum
equation governing the fluid flow is given by:
du/dt = ∂u/∂t + (u · ∇) u = −1/ρ (∇pr) − 2Ω × u
where u is the velocity field, ρ is the density of the fluid and pr= p − ((|Ω| |x⊥|)^2)/2
is the reduced pressure, where p is pressure and x⊥ is the perpendicular distance from
the position vector x to the rotation axis.
We consider the dynamics of inertial waves, i.e. small perturbations to the state of
uniform rotation.
The questions are below.
(a) Write down an expression for the velocity field corresponding to uniform
rotation. Find the vorticity corresponding to this flow.
(b) Consider a small perturbation u' to the state of uniform rotation with angular
velocity Ω, which has the form of a plane harmonic wave
u'= A exp i(k·x−ω t) + A*exp -i(k·x−ω t)
where k is the wavenumber vector, ω is the frequency, A is the complex
amplitude and A* is its complex conjugate.
How small does the amplitude A need to be for the nonlinear (with respect to A) terms to be much smaller than the linear ones in the momentum equation?
(c) Consider the linearised momentum equation and derive the dispersion relation
ω = ω (k). (Hint: Take the curl of the momentum equation and use the identity
∇ × (Ω × u) = − (Ω · ∇) u.)
(d) What is the polarisation of the inertial waves?
(e) Are these waves dispersive or non-dispersive? Isotropic or anisotropic? Explain why. Find the group velocity for the inertial waves and comment on its
relative direction with respect to the wavenumber vector.
Please show us what you've done on this so far.
Did the original problem say anything about the fluid being incompressible?
Related to Geophysics: Fluid Dynamics Problem
1. What is geophysics?
Geophysics is a branch of science that studies the physical properties and processes of the Earth and other planets through the use of various methods and technologies.
2. What is fluid dynamics?
Fluid dynamics is a subfield of physics that deals with the study of fluids (liquids and gases) in motion and the forces that act upon them.
3. How does geophysics use fluid dynamics?
Geophysics uses fluid dynamics to study the movement and behavior of fluids within the Earth, such as the flow of water in rivers and oceans, and the movement of magma in volcanoes. It also helps in understanding atmospheric and oceanic circulation patterns.
4. What are some common problems in geophysics related to fluid dynamics?
Some common problems in geophysics related to fluid dynamics include the prediction of natural hazards such as floods, landslides, and tsunamis, as well as the understanding of climate change and its impact on the Earth's systems.
5. What are some techniques used in geophysics to study fluid dynamics?
Some techniques used in geophysics to study fluid dynamics include remote sensing, seismic imaging, and numerical modeling. These methods allow scientists to collect data and create models to better understand the behavior of fluids in the Earth.
  • Classical Physics
  • Atomic and Condensed Matter
  • Mechanical Engineering
  • STEM Academic Advising
