Geosynchronous vs geo-stable orbit?
  • Thread starter jnorman
  • Tags
    Orbit
In summary, these two orbits are the same: they are both in a geosynchronous orbit with an orbital height of 26,000 miles. The only difference is that the orbit for the 22,000 mile orbit is inclined by 7.3 degrees, which makes it more stable than the 26,000 mile orbit.
jnorman
316
simple question - can someone please clarify the difference between these two orbits? i recall arthur c clarke's original concept for communication satellites in what i believe he called geosynchronous orbit such that the satellite(s) would remain over a single fixed point on Earth's surface, which in his discussion indicated an orbital height of 22,000 miles.
yesterday, i looked up geosynchronous orbit, and found that it was at an orbital height of 26,000 miles and was apparently some type of elliptical orbit. the article then went on to differentiate geosynchronous from geo-stable, which was a circular orbit at 22,000 miles.
now i am a tad confused - can you please clarify? thanks.
Astronomy news on Phys.org
About the 22,000 versus 26,000 miles (or more precisely, 22,236 versus 26,199 miles): They are really the same number. The first is altitude, which is the distance above the surface of the Earth. The second is orbital radius, which is the distance from the center of the Earth. The Earth's equatorial radius is 3,963 miles, so the orbital altitude will be 3,963 miles smaller than the orbital radius.About the other terms:
Any satellite's orbit whose period is one sidereal day is in a geosynchronous orbit. The will orbit the equator if the orbital inclination is zero. In that case, the satellite will appear to be stationary from the perspective of an Earth-based observer. These are geostationary orbits. A satellite that is in a geosynchronous orbit with a non-zero inclination will appear to move in a figure-8 pattern when viewed from the surface of the Earth.
A huge advantage results from satellites that are in a geostationary orbit. All that is needed to receive a transmission from that satellite is a very simple antenna pointed at the right fixed direction. There is also a huge disadvantage to those geostationary orbits. There aren't stable. Perturbations due to gravity from the Sun and Moon, the Earth's non-spherical shape, and radiation pressure from sunlight act to push the vehicle into a different orbit. Satellites in a geostationary orbit must occasionally fire thrusters to put themselves back into the right geostationary orbit.
There is one set of geosynchronous (but not geostationary) orbits that are stable. A geosynchronous orbit that is inclined by 7.3° will have the perturbations due to Earth J2 (the first term that describes Earth's non-spherical shape) cancel the perturbations to solar gravity, lunar gravity, and solar radiation pressure. This is the GEO (all caps, do note) stable plane. (GEO here means geostationary equatorial orbit. Calling this orbital plane that is not equatorial the GEO stable plane is a bit of a misnomer, but that's what it is called; were stuck with it.)
Even in that supposedly stable plane orbits are not necessarily stable. There are two points that are: above 75°E and 105°W longitude. The stable plane only accounts for Earth J2. There are a lot more terms than J2 that describe the Earth's non-spherical shape. J2 is just the biggest of these; it describes how an oblate spheroid model of the Earth differs from a spherical model. Orbits with an inclication of 7.3° degrees and a location of 75°E or 105°W longitude are stable, even after accounting for those higher order terms. Dead geostationary satellites tend to accumulate at those two spots in the GEO stable plane.
danke.
Related to Geosynchronous vs geo-stable orbit?
1. What is the difference between a geosynchronous and a geo-stable orbit?
A geosynchronous orbit is a type of orbit where a satellite orbits the Earth at the same rate that the Earth rotates, allowing the satellite to appear stationary in the sky. A geo-stable orbit is a type of orbit where a satellite maintains a fixed position relative to a point on the Earth's surface.
2. How are geosynchronous and geo-stable orbits useful?
Geosynchronous orbits are useful for communication and navigation satellites, as they can maintain constant contact with a specific location on Earth. Geo-stable orbits are useful for Earth observation and remote sensing satellites, as they can continuously monitor a specific area on Earth.
3. What are the key factors that determine the stability of a geosynchronous or geo-stable orbit?
The key factors that determine the stability of these orbits are the altitude, inclination, and eccentricity of the orbit. A higher altitude and lower inclination and eccentricity contribute to a more stable orbit.
4. How long does it take for a satellite to complete one orbit in a geosynchronous or geo-stable orbit?
In a geosynchronous orbit, it takes a satellite 24 hours to complete one orbit, as it is synchronized with the Earth's rotation. In a geo-stable orbit, the time to complete one orbit can vary, depending on the altitude and other factors, but it is typically between 12-24 hours.
5. Can satellites in geosynchronous or geo-stable orbits experience any disruptions or changes in orbit?
Yes, these orbits are not completely immune to disruptions. Factors such as solar radiation, atmospheric drag, and gravitational influences from other objects can affect the stability of the orbits. Satellites in these orbits may also need occasional adjustments to maintain their desired positions.
