Geothermal heat extraction math problem
In summary, efficiency in thermodynamics is the fraction of energy that makes it through into the output of a process. It can be calculated by dividing the power output by the power input. In some cases, this efficiency can exceed 100%.
courtneywetts
80
The actual efficiency of a geothermal power plant using a 200 C geothermal resource is only about 7%. Take this value as typical of California's Geysers geothermal field, which produces 900 MW of electric power.
a) Find the actual rate of geothermal heat extraction at Geysers
b) it's estimated that 35EJ of energy could be extracted from the Geysers before the temperature dropped from 250 C to 150 C minimum for a vapor-dominated geothermal plant. Given your answer in (a) how long will the Geysers geothermal resource last before the temperature reaches 150 C
I am not sure what equation to use
Starting at part A I know I have to find the rate of geothermal heat extraction but do not know the formula to do so.
Does this have something to do with change in temperature? It's the only thing I can think to do but am not sure if this is right
You are given the amount of electric power produced by the plant along with the efficiency. How many Joules per second are required to give this power? (Hint: 1 watt = 1 Joule / second)
Gnaw on this first before tackling part b.
I don't see the relevance of that. The question can be answered in MW, surely.
Courtneywetts, there's nothing special about heat extraction for part a. You have power input, a conversion system that's 7% efficient, and power output of 900MW. So how much power is input?
Part b doesn't have much to do with temperature either. We can replace the references to temperatures with references to states and still make a sensible question: the resource will change from state A to state B when 35EJ have been extracted; we know from part a the rate of energy extraction; how long will it take to change from state A to state B?
What formula would I be using for part A? Is there a specific formula to use? I am not sure how to find how much power is in input.
Part a of the problem asks for the rate of energy extraction. I thought that it was important for the user to understand that power is equivalent to the rate of energy production from the source, especially in light of part b.
If the power input is P and the power output is P', what would the efficiency be?
I am confused what this means. If the power plant is 7% efficient and 900 MW then am I trying to find the power input? If so how do I do this?
What's the definition of efficiency?
Achieving maximum productivity with minimal effort.
Is this what I am looking for?
Does that statement apply to your problem, or is it a personal ideal?
Have you looked at your textbook for a definition of efficiency (the thermal kind, not the personal actuation kind)?
You can always Google the term, if that helps.
The efficiency of a process is the fraction of energy (or other resource) which is makes it through into the output. If P in and P' out the efficiency is P'/P.
In thermodynamics the concept of efficiency can get a little strange. Since there is a theoretical limit on conversion of heat to work, based on the temperatures involved, the process will have a theoretical maximum efficiency as well as an actual eficiency, so in asessing the process it is ressonable to think in terms of the ratio of those two efficiencies rather than the actual efficiency.
Conversely, a heat pump can produce more heat out than work in, so this normal definition of efficiency can result in values over 100%.
Then in the problem the efficiency is 7% and the output is 900 MW. Am I right on this? So I would then use these numbers to find the rate of heat extraction?
Yes, just using the Eff = Pout/Pin formula.
Okay so then would this be .07 * 900= 63?
No, 900 MW is what comes out of this process.
So then 900 MW is the pout
How do I arrange this equation.
I am using .07 right?
I think I figured it out7% * (Total Wattage) = 900 MW
Total Wattage = 900 MW / (7/100) = 12,857.14 MW = 12.9 GW
Is this right?
Is this right?
Yes.
haruspex said:
Yes.
I am confused how to do part B.
What formula would I be using?
Where am I using this 12.9 GW?
See my post #3.
Related to Geothermal heat extraction math problem
What is geothermal heat extraction and why is it important?
Geothermal heat extraction is a process that involves extracting heat from the Earth's core and using it to generate energy. It is important because it is a renewable and sustainable source of energy that does not produce greenhouse gas emissions.
How does geothermal heat extraction work?
Geothermal heat extraction involves drilling deep into the Earth's crust to access hot water or steam. This hot water or steam is then brought to the surface and used to power turbines, which generate electricity. The cooled water is then returned to the Earth to be reheated, creating a continuous cycle.
What factors affect the efficiency of geothermal heat extraction?
The efficiency of geothermal heat extraction can be affected by the temperature and flow rate of the geothermal resource, the design and capacity of the heat extraction system, and the geological characteristics of the site.
How is math used in geothermal heat extraction?
Math is used in geothermal heat extraction to calculate the heat transfer rate, the amount of energy that can be extracted from the geothermal resource, and the cost-effectiveness of the project. It is also used in the design and optimization of the heat extraction system.
What are some potential challenges or limitations of geothermal heat extraction?
Some potential challenges or limitations of geothermal heat extraction include the high upfront costs, the need for specialized equipment and expertise, and the potential for seismic activity or contamination of the geothermal resource. Additionally, not all areas have access to viable geothermal resources, limiting its potential for widespread use.
  • General Engineering
