Getting a newspaper page to stick to a wall using wooden pencil
  • B
  • Thread starter johann1301h
  • Tags
    Wall
In summary, the conversation was about an experiment involving using a wooden pencil to stick a newspaper page to a wall. The method involves producing an electrostatic charge between the paper and the wall, but it is not working well due to the surface material of the wall and the humidity in the summer. Ideas were discussed, such as using A/C or moistening the paper or wall, and a suggestion was made to try driving the pencil through the paper into a soft area of drywall. However, this method may require patching the wall after the experiment and does not demonstrate electrostatics. Another suggestion was to apply force to cause plastic deformation, which should be more robust to environmental variations. A small piece of newspaper was tried on a glass door
johann1301h
71
Hi!
Im trying out an experiment, where a newspaper page is supposed to stick to a wall using a wooden pencil, by rubbing the pencils long side on the newspaper page while its on the wall.
But its not really working.
I have checked the pencil, and there is no coating on it, just wood. It is summertime so it may be moist air? Or perhaps it is the wall?
Any ideas?
I'm guessing the method of sticking is to produce an electrostatic charge between the paper and the wall.
Two factors would affect this:
1) The material on the surface of the wall. It should be different than paper.
2) The ambient humidity. Summer would be the worse time to do this experiment - unless you are using air conditioning.
Wiki: Triboelectric effect
Likes davenn and Klystron
The wall(s) I have tried are painted. So I'm guessing its the humidity then...
Is it a dumb idea to try drying the wall, the pen and the paper with a blowdryer?
If the air is humid, you haven't a chance.
Move to a room with A/C.
Thanks!
Likes Klystron
Friction between the wall and paper prevents the paper sliding down to the floor. Maximise friction, do not polish the wall.
Air is displaced from the space between the paper and the wall as triboelectric surface charge is created by the pencil.
The paper needs to remain flat and against the wall so electrostatic 1/r2 over the paper surface is maximised and preserved.
The paper needs to be dry, so surface charges will not quickly dissipate.
You could double down on humidity. If rules allow, moisten the paper (or the wall) slightly with your hand, a sponge or a sprayer. Use the pencil as a roller from the top of the paper or from the center outward to the edges.
Similar to papier-mache technique or wall-paper hanging without mucilage.
Last idea if the above dry and the wet methods fail: drive the sharp end of the pencil through the paper into a soft area of drywall deep enough to mount pencil and paper.
Warnings: Requires patching wall after experiment. Does not demonstrate electrostatics.
  • Haha
Likes johann1301h
Depending on the modulus of elasticity and the yield strength of the wall and the pencil you could orient the pencil normal to the surface of the wall and the paper, and apply sufficient force to cause plastic deformation. This method of attachment should be robust to typical environmental variations.
Likes Klystron
I tried a small piece of newspaper (8x3 inch) on a glass door and it works - paper stayed there for 2 seconds, and then straight down hugging the glass.
Related to Getting a newspaper page to stick to a wall using wooden pencil
1. How do I get a newspaper page to stick to a wall using a wooden pencil?
To get a newspaper page to stick to a wall using a wooden pencil, you will need to use static electricity. This can be achieved by rubbing the wooden pencil on a piece of fabric, such as a shirt or a towel, to create a static charge.
2. Why does rubbing the wooden pencil on fabric create static electricity?
When you rub the wooden pencil on fabric, friction is created between the two surfaces. This friction causes electrons to transfer from one surface to the other, creating a build-up of static electricity on the wooden pencil.
3. Can any type of fabric be used to create static electricity?
Yes, any type of fabric can be used to create static electricity. However, materials that are more likely to generate static electricity include wool, silk, and polyester.
4. How long will the newspaper page stay stuck to the wall using this method?
The newspaper page will stay stuck to the wall for a short period of time, as the static charge will eventually dissipate. However, you can repeat the rubbing process on the wooden pencil to create more static electricity and make the page stick for a longer period of time.
5. Is this method safe for all types of walls?
Yes, this method is safe for all types of walls. The rubbing of the wooden pencil on fabric does not cause any damage to the wall surface. However, it is always a good idea to test a small area first before using this method on a larger scale.
  • Materials and Chemical Engineering
  • Classical Physics
  • General Engineering
  • General Discussion
  • Beyond the Standard Models
  • Chemistry
