davidorn
- 2
- 1
- TL;DR Summary
- Need help with a recent friendly debate: does increased mass of stones in a sauna heater make it easier to get to a higher temperature?
We've been discussing what it takes to get a sauna to heat to 240F. Most sauna heaters will have some stones to provide mass to hold heat. The question is whether lots of stone mass will make it easier to reach higher temperatures.
My argument is that it does. Imagine heating a room using a heater with no stones. Let's say that to raise the temperature in the room from 100 to 110 is going to require X units of energy. Then consider how much energy would be required to raise it from 110 to 120. My argument is that when you're trying to go from 110 to 120 you will require less energy if you have stone mass than if you don't because without stones the heater is the only thing transferring heat to the air but with the stones they help raise the temperature because they are hotter than the air. (While this example talks about stones versus no stones, it applies to more stones versus fewer stones, too).
It's not a closed system -- there will be some amount of cooling through the walls, etc. And because the cooling is at a relatively constant rate, the ability to hold the heat up higher because of the stones seems relevant.
Am I thinking about this correctly? I'm wondering if I'm missing some factors that mean this doesn't make any sense.
