Python Getting all files under a folder and subfolders in a recursive manner
  • Thread starter Thread starter Arman777
    files
To list all files under a folder and its subfolders recursively, Python's `os` module can be utilized effectively. The provided code snippet demonstrates how to use `os.walk()` to traverse directories and collect full file paths. The function `get_all_filePaths(folderPATH)` compiles these paths into a list, ensuring only file paths are returned, excluding subfolder paths. This method allows for scalability with any level of nested folders. The discussion emphasizes the need for a recursive approach to achieve comprehensive file listing.
Arman777
Insights Author
I want to list all the full path of the files under a folder and all its subfolders recursively. Is there a way to do it? It seems that if the files go into 2 levels, the code can be written like is,
Code:
    import os
    folderPATH = r'C:\Users\Arman\Desktop\Cosmology\Articles'
    filePATHS = [x[2] for x in os.walk(folderPATH)]
    for i in filePATHS:
        for j in i:
            print(j)
prints
Code:
    Astrophysical Constants And Parameters.pdf
    desktop.ini
    Physics Latex Manuel.pdf
    Spactimes.pdf
    A parametric reconstruction of the cosmological jerk from diverse observational data.pdf
    A Thousand Problems in Cosmology Horizons.pdf
    An Almost Isotropic CM Temperature Does Not Imply An Almost Isotropic Universe.pdf
    Big Bang Cosmology - Review.pdf
    desktop.ini
    Expanding Confusion common misconceptions of cosmological horizons and the superluminal expansion of the universe.pdf
    Hubble Radius.pdf
    Is the Universe homogeneous.pdf
    LCDM and Mond.pdf
    Near galaxy clusters.pdf
    The Cosmological Constant and Dark Energy.pdf
    The mass of the Milky Way from satellite dynamic.pdf
    The Status of Cosmic Topology after Planck Data.pdf
    An upper limit to the central density of dark matter haloes from consistency with the presence of massive central black holes.pdf
    Dark Matter - Review.pdf
    Dark Matter Accretion into Supermassive Black Holes.pdf
    desktop.ini
    Andrew H. Jaffe - Cosmology - Imperial College Lecture Notes - Thermodynamics and Particle Physics.pdf
    Big Bang Nucleosynthesis.pdf
    Claus Grupen - Astroparticle Physics - The Early Universe.pdf
    Daniel Baumann - Cosmology - Mathematical Tripos III - Thermal History.pdf
    desktop.ini
    James Rich - Fundamentals of Cosmology - The Thermal History of the Universe.pdf
    Lars Bergström, Ariel Goobar - Cosmology and Particle Astrophysics -  Thermodynamics in the Early Universe.pdf
    Steven Weinberg - Cosmology - The Early Universe.pdf
    Andrei Linde - On the problem of initial conditions for inflation.pdf
I want a function that produces the same results but with recursive logic and with the full paths. So that for `n` nested folders, I can find the paths. I need something like this,
Code:
    import os
    def get_all_filePATHs(folderPATH):
        return get_all_filePATHs()
    print(get_all_filePATHs(folderPATH))
Note that I am only interested in the full path of the files and not the path of the subfolders, as you can see from the example above.
Technology news on Phys.org
Okay this works,
Code:
import os
def get_all_filePaths(folderPATH):
    result = []
    for dirpath, dirnames, filenames in os.walk(folderPATH):
        result.extend([os.path.join(dirpath, filename) for filename in filenames])
    return result
I seem to remember writing something like that years ago - ah, here it is (in Pascal):
Code:
procedure TForm1.DoDirectory;
var
  sRec: TSearchRec;
  sRslt: Integer;
  specDir, First: Boolean;
  currFN, altFN: String;
Begin
  First := True;
  sRslt := FindFirst ('*.*',faReadOnly    Or faHidden    Or faSysFile Or faDirectory, sRec);
  While (sRslt = 0) Do Begin
    altFN := sRec.FindData.cAlternateFileName;
    currFN := sRec.FindData.cFileName;
    If (altFN<>'') and (altFN<>currFN) Then Begin
      If First Then Begin
        Writeln(resF);
        Writeln(resF,'[Directory]');
        Writeln(resF,GetCurrentDir);
        First := False;
        End;
      WriteLn(resF, altFN, ' "', currFN,'"');
      End;
    sRslt := FindNext(sRec);
    End;
  sRslt := FindFirst ('*.*', faDirectory, sRec);
    specDir := (currFN = '.') Or (currFN = '..') Or ((sRec.Attr And faDirectory)=0);
    If (not specDir) and (testCnt<32) Then Begin
      Inc(testCnt);
      ChDir(currFN);
      DoDirectory;
      Chdir('..');
      End;
    End;
End;
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
I am trying to run an .ipynb file and have installed Miniconda as well as created an environment as such -conda create -n <env_name> python=3.7 ipykernel jupyter I am assuming this is successful as I can activate this environment via the anaconda prompt and following command -conda activate <env_name> Then I downloaded and installed VS code and I am trying to edit an .ipynb file. I want to select a kernel, via VS Code but when I press the button on the upper right corner I am greeted...
