Getting an infinite loop in Nelder-Mead code, help please
In summary, the conversation discusses the speaker's attempt at writing the Nelder-Mead optimization method in MATLAB. They are encountering an issue with the code looping infinitely and suspect it may be due to a mistake in their sorting function. However, they have made some changes and believe they have solved the issue.
Godric
I've been making a go at writing out algorithms myself in MATLAB rather than using pre-existing code. I've just attempted to write the Nelder-Mead optimization method and I have hit a stumbling block where the code is now looping infinitely. It seems to have something to do with sorting the vertices again after reflecting/expanding/contracting/shrinking. As whenever I cancel the operation this is where it has gotten to. Perhaps I made a mistake in my sorting function? It's probably an obvious mistake. A huge thank you to anyone who can help me!
Here's my code:
Matlab:
function [solution] = NMS()
clc
%Initialize Simplex
N = 15; %number of vertices
dim = 30; %dimensions
LB = -100; %lower bounds
UB = 100; %upper bounds
errorgoal = 0.01;
goal = 0;
imax = 200; %maximum iterations
objective_function = @(x) sum(x.^2); %this is just a test function
vertices=zeros(N,dim);
vert_eval=zeros(N,1);
%intializing vertices
for i=1:N
    for j=1:dim
     vertices(i,j)=LB+(UB-LB).*rand(1);
    end
    vert_eval(i)=objective_function(vertices(i,:));
end
%Simplex manipulation constants
RE=1; %reflection coefficient
EX=2; %expansion coefficient
CO=0.5; %outside contraction coefficient
CI=-0.5; %inside contraction coefficient
%Sort the simplex
SortVertices = SortEm(vertices,vert_eval,objective_function,N);
for j=1:N
vert_eval(j)=objective_function(SortVertices(j,:));
endwhile(abs(vert_eval(1)-goal) > errorgoal)
%set fcount
fcount = N;
%Find centroid
centroid = CalcCentroid(SortVertices,dim,N);
cent_eval = objective_function(centroid);
%Calculate Reflection
SortVertices(N,:);
ref = (1+RE).*centroid - RE.*SortVertices(N,:);
ref_eval = objective_function(ref);
fcount = fcount + 1;
if vert_eval(1) <= ref_eval < vert_eval(N) %Reflect
     if fcount==imax
         break;
     end
     SortVertices(N,:)=ref;
elseif ref_eval < vert_eval(1) %Expand
      if fcount==imax
         break;
      end
     exp = (1+EX).*centroid - EX.*SortVertices(N,:);
     ex_eval = objective_function(exp);
     f_count = f_count+1;
     if ex_eval < ref_eval
         SortVertices(N,:)=exp;
     else
     end
elseif vert_eval(N-1) <= ref_eval < vert_eval(N) %Outside contrac
     if fcount==imax
         break;
     end
     con = (1+CO).*centroid - CO.*SortVertices(N,:);
     co_eval = objective_function(con);
     f_count = f_count + 1;
     if co_eval < ref_eval
         SortVertices(N,:)=con;
     else %shrink
         if fcount >= imax - N-1
             break;
         else
             for j=2:N
                 SortVertices(j,:) = SortVertices(1)-(SortVertices(j) - SortVertices(1))./2;
             end
         end
     end
elseif ref_eval > vert_eval(N) %Inside contrac
     if fcount==imax
         break;
     end
     coi = (1+CI).*centroid - CI.*SortVertices(N,:);
     co_eval = objective_function(coi);
         SortVertices(N,:)=coi;
     else %shrink
             break
         else
             for j=2:N
             end
         end
     end
end
  vertices = SortVertices;
  for j=1:N
  end
end
solution = vert_eval
end
%Vertex sorting
function [SortVertices] = SortEm(vertices,vert_eval,objective_function,N)
for m=1:N
        for i=1:N-1
            if(vert_eval(i)>vert_eval(i+1))
                temp=vertices(i,:);
                vertices(i,:)= vertices(i+1,:);
                vertices(i+1,:)= temp;
            else
                continue;
            end
        end
      for k=1:N
       vert_eval(k)=objective_function(vertices(k,:));
      end
end
   SortVertices=vertices;
end
%Calculate the centroid
function [centroid] = CalcCentroid(SortVertices,dim,N)
SumVert=zeros(1,dim);
i=1:dim;
for k=1:N-1
  SumVert=SumVert+SortVertices(k,i);
end
centroid=SumVert./(N-1);
end
Maybe add some debug output statements to show you what it is doing?
Likes Godric
So it appears the worst value just switches between two values every loop and never gets better. I am not certain what could be causing this effect.
The infinite looping was a dumb mistake where the f_count was getting reset, but the actual algorithm is still not working because of the constant back and forth.
Edit: I think I solved my issues.
Likes berkeman
Related to Getting an infinite loop in Nelder-Mead code, help please
1. What is an infinite loop in Nelder-Mead code?
An infinite loop in Nelder-Mead code refers to a situation where the algorithm continuously repeats the same steps without reaching a solution. This can happen due to various reasons, such as incorrect initial values, incorrect coding, or a poorly chosen objective function.
2. How can I detect an infinite loop in Nelder-Mead code?
One way to detect an infinite loop in Nelder-Mead code is to monitor the number of iterations the algorithm has gone through. If the number of iterations keeps increasing without reaching a solution, it is likely that an infinite loop has occurred. You can also add print statements or debugging tools to track the algorithm's progress and identify where it is getting stuck.
3. What are some common causes of infinite loops in Nelder-Mead code?
Some common causes of infinite loops in Nelder-Mead code include incorrect coding, poorly chosen initial values, or a poorly defined objective function. It is also possible for the algorithm to get stuck in a local minimum, resulting in an infinite loop.
4. How can I fix an infinite loop in Nelder-Mead code?
Fixing an infinite loop in Nelder-Mead code may require some trial and error. You can try changing the initial values, adjusting the objective function, or checking for any coding errors. It may also be helpful to consult with other researchers or experts in the field for advice and guidance.
5. Are there any resources or tools that can help with debugging an infinite loop in Nelder-Mead code?
Yes, there are various resources and tools that can assist with debugging an infinite loop in Nelder-Mead code. These include print statements, debugging tools, and online forums where you can seek advice from other researchers and experts. Additionally, some software packages may have built-in debugging features specifically for Nelder-Mead code.
