rynlee
- 45
I've had this problem many times in the past, and haven't thought of a way to fix it.
Sometimes when I plot a function that requires quite a bit of effort on mathematica's part, (for example, one time the function was a sum of about a thousand terms, each of which was multiplied complex terms with my independent variable dependence (in this case time)), when it plots it the plot is correct but for some reason doesn't take enough points, it's not nicely curved as it should be but instead looks like connected line segments. When I have a particularly high frequency plot this is particularly troublesome, as features get washed out sometimes and curves are straightened.
Most recently I am plotting a contour plot where there are oscillations in each of the variables, and mathematica is turning the contour basically into polygons.
Is there a way to get mathematica to use more points when constructing a plot? Is that the source of this grievance?
Thanks for any Advice
