Getting the wrong multipole for 1st acoustic peak
In summary, there is something wrong with the calculation of the wavelength corresponding to the first acoustic peak of the CMB.
DoobleD
259
I'm trying to do a simple calculation, but there must be something wrong.
The wavelength ##\lambda_1## corresponding to first acoustic peak of the CMB is related to the sound horizon at last scattering, ##d_{hs}##, by :
## \lambda_1 = 2d_{hs} ## (see for instance slide 14 on Wayne Hu PDF slides).
Now, the multipole ##l## of the first acoustic peak can be related to its wavelength and to the distance to last scattering surface, ##D##, by :
##l_1 = \frac{2 \pi}{\lambda_1} D## (see slide 15)
From that I deduce the following equation :
##l_1 = \frac{\pi}{d_{hs}}D##
I find in the litterature that ##D \approx 14000 Mpc##, and ##d_{hs} \approx 150 Mpc##. I plug those values into the previous equation, and I find ##l_1 \approx 293##, which is quite far from the ##l_1 \approx 200## I should get for the first peak. What's wrong ?
Space news on Phys.org
I get the values for distance to last scattering surface and sound horizon here. I wonder however if 150 Mpc for the sound horizon is not in comoving coordinates, while I should use the physical distance instead (which I don't know) ?
EDIT : I just realized that at the very end of that WMAP values document, they basically give the exact same formula, ##l = \frac{\pi}{d_{hs}}D##. And with the values they gives, I get ##l = 299##. Why am I not getting 200 ?
I just found the exact same question asked by someone else on physics.stackexchange : https://physics.stackexchange.com/questions/222993/how-is-the-first-acoustic-peak-calculated-in-cmb
The guy also finds ##l \approx 300## instead of 200.
I'm back on this issue.
Same problem with again another source. We know that ##\theta_s = 0.0104## (slide 4), and ## l = \pi / \theta_s## (slide 18), so we get ##l = 302## instead of around 200. Exactly the same issue as in the https://redirect.viglink.com/?format=go&jsonp=vglnk_152494367988315&key=6afc78eea2339e9c047ab6748b0d37e7&libId=jgjovf9v010009we000DLcrw2gf0c&loc=https%3A%2F%2Fwww.physicsforums.com%2Fthreads%2Fgetting-the-wrong-multipole-for-1st-acoustic-peak.923207%2F&v=1&out=https%3A%2F%2Fphysics.stackexchange.com%2Fquestions%2F222993%2Fhow-is-the-first-acoustic-peak-calculated-in-cmb&ref=https%3A%2F%2Fwww.physicsforums.com%2Fsearch%2F81044411%2F&title=Getting%20the%20wrong%20multipole%20for%201st%20acoustic%20peak%20%7C%20Physics%20Forums&txt=https%3A%2F%2Fphysics.stackexchange.com%2Fquestions%2F222993%2Fhow-is-the-first-acoustic-peak-calculated-in-cmb post I linked earlier actually.
Nevermind, this very question has been already answered here. Thanks to @George Jones.
Related to Getting the wrong multipole for 1st acoustic peak
What does "getting the wrong multipole for 1st acoustic peak" mean?
The first acoustic peak refers to the peak in the power spectrum of the cosmic microwave background (CMB) radiation. It is an important feature that provides information about the structure and evolution of the universe. Getting the wrong multipole for the 1st acoustic peak means that the measured values for this peak do not match with the expected values based on theoretical models.
Why is it important to accurately measure the first acoustic peak?
The first acoustic peak is a key feature in the CMB power spectrum and provides valuable information about the composition, geometry, and evolution of the universe. Accurate measurement of this peak helps us understand the origin and evolution of the universe, as well as test and refine current cosmological models.
What factors can lead to getting the wrong multipole for the 1st acoustic peak?
There are several factors that can contribute to getting the wrong multipole for the 1st acoustic peak. Some of these include instrumental or observational errors, foreground contamination, and theoretical assumptions or uncertainties in the models used to interpret the data.
How can scientists ensure accurate measurement of the first acoustic peak?
To ensure accurate measurement of the first acoustic peak, scientists use sophisticated instruments and techniques to minimize observational errors. They also carefully account for and remove any foreground contamination from other sources, and continuously refine and improve theoretical models to reduce uncertainties.
What implications does getting the wrong multipole for the 1st acoustic peak have for our understanding of the universe?
Getting the wrong multipole for the 1st acoustic peak can have significant implications for our understanding of the universe. It could indicate the need for revisions to current cosmological models, or even suggest the presence of new physics that we have yet to discover. Accurate measurement of this peak is crucial in advancing our understanding of the universe and its evolution.
  • Astronomy and Astrophysics
