Gilbert Damping Ratio in Ferromagnets
In summary, the highest alpha (Gilbert damping ratio) typically seen in ferromagnets is around 0.2, with some rare cases reaching as high as 0.5.
sokrates
483
Does anyone know the highest alpha (Gilbert damping ratio) you could get on ferromagnets?
People for various reasons aim for the lowest alpha and it is around 0.008 these days (dimensionless). But I need to know whether higher values are possible or not.
A brief reminder on what alpha is: It is the phenomenological damping parameter that enters the Landau-Lifgarbagez-Gilbert equation which is usually used to model magnetization dynamics of a magnet in the 'macrospin' approximation; where all the individual spins (that are locked into the magnet) are assumed to rotate in unison (hence the name, macrospin)
How large can alpha be? Can it be as high as 0.5 for instance?
It is possible to have an alpha as high as 0.5 in ferromagnets, however, this is not typical. The highest alpha values typically seen in ferromagnets are around 0.2. High alpha values tend to lead to higher energy dissipation and increased coercivity, which is why they are not often used.
I can provide some information on the Gilbert damping ratio in ferromagnets. The Gilbert damping ratio, also known as the phenomenological damping parameter, is a measure of how quickly a magnetic system loses energy during its dynamic motion. It is an important parameter in understanding the behavior of ferromagnetic materials.
To answer the question of the highest alpha that can be achieved in ferromagnets, it is important to note that the value of alpha is dependent on various factors such as material properties, temperature, and external magnetic field. In general, the lowest alpha values are desirable as they indicate minimal energy loss and better stability of the magnetic system.
Currently, the lowest alpha values achieved in ferromagnets are around 0.008, as mentioned in the content. However, it is possible to achieve higher values of alpha, up to 0.5, in certain materials and conditions. For instance, some studies have reported alpha values as high as 0.4 in iron-nickel alloys at low temperatures and in the presence of strong magnetic fields.
It is worth noting that higher values of alpha are usually associated with materials that have a high degree of disorder or defects, such as amorphous ferromagnets or nanoparticles. In these materials, the damping is dominated by spin scattering at the interfaces between different grains or phases, resulting in higher alpha values.
In summary, the highest alpha that can be achieved in ferromagnets depends on various factors and can reach values as high as 0.5 in certain materials and conditions. However, the current trend is to aim for lower alpha values for better stability and energy efficiency in magnetic systems.
Related to Gilbert Damping Ratio in Ferromagnets
What is the Gilbert Damping Ratio?
The Gilbert Damping Ratio is a dimensionless parameter that describes the rate at which a ferromagnet loses energy during the process of magnetization reversal.
How is the Gilbert Damping Ratio measured?
The Gilbert Damping Ratio can be measured by analyzing the dynamics of a ferromagnet as it undergoes magnetization reversal. This can be done experimentally by using techniques such as ferromagnetic resonance or spin-torque ferromagnetic resonance.
What is the significance of the Gilbert Damping Ratio in ferromagnets?
The Gilbert Damping Ratio is an important parameter for understanding the behavior of ferromagnets, as it affects the speed and efficiency of magnetization reversal. A higher damping ratio leads to slower magnetization dynamics and increased energy dissipation, while a lower damping ratio results in faster dynamics and less energy loss.
How does the Gilbert Damping Ratio vary between different ferromagnetic materials?
The Gilbert Damping Ratio can vary significantly between different ferromagnetic materials, depending on their composition and microstructure. For example, materials with a high concentration of impurities or defects tend to have higher damping ratios, while those with a more ordered structure have lower damping ratios.
Can the Gilbert Damping Ratio be controlled or manipulated?
Yes, the Gilbert Damping Ratio can be controlled and manipulated by changing the properties of the ferromagnetic material. For example, by adjusting the composition, microstructure, or magnetic anisotropy of the material, the damping ratio can be altered. This has important implications for applications such as magnetic data storage and spintronic devices.
