Given a fixed volume of pressurized air, calculate the flow rate
In summary, the question is how to calculate the flow rate over time through an orifice of known size in a fixed volume air tank filled with pressurized air. The provided information includes the air tank volume, orifice diameter, maximum and minimum air pressure, maximum time for pressure drop, gas constant of air, and air density. The temperature is assumed to be fixed at 20C. The solution involves understanding the concepts of choked flow and choked mass flow rate, which can be found in entry-level textbooks on gas dynamics and compressible flow. No additional publications are necessary.
dpeff
I have a work related question. Although it seems like a relatively simple question, I am having difficulties finding the correct equation(s) to calculate the answer.
Question: Given a fixed volume air tank filled with pressurized air, how does one calculate the flow rate over time through an orifice of known size? An example flow rate calculation at maximum pressure would be appreciated.
Where:
Air tank volume is 3.277 cubic liters = 0.003277413 cubic meters
Orifice diameter = 0.0013208 m
Air pressure max P1 = 1073.485776 kpa abs
Air pressure min P2 = 101.325 kpa abs
Max time for pressure drop from P1 to P2 = 60 sec
R = gas constant of air = 287 J/kg K = 0.287 kJ.m3/kgK
air density –ρ = 1.225 kg/m3
*Temperature = 20C
*For now, the temperature is assumed to be fixed at 20C even though there will be a reduction in temperature resulting from the reduction in pressure.
This is actually a fairly simple problem to do analytically (and the assumptions required to make this true are fairly reasonable). You should look up the concepts of choked flow and choked mass flow rate.
Thank you. I will research choked mass flow rate concepts as you have advised. If you have knowledge of publications that are relevant to my specific question, that would be greatly appreciated. Thanks again!
You shouldn't even need publications, per se. Any entry-level textbook on gas dynamics/compressible flow should cover it.
FAQ: Given a fixed volume of pressurized air, calculate the flow rate
1. What is the formula for calculating flow rate with a fixed volume of pressurized air?
The formula for calculating flow rate with a fixed volume of pressurized air is Flow Rate = Volume / Time. This means that flow rate is equal to the volume of air divided by the time it takes for the air to pass through a specific point.
2. How do you measure the volume of pressurized air?
The volume of pressurized air can be measured using a variety of instruments such as a flow meter, a manometer, or a volumetric cylinder. These instruments measure the volume of air passing through a specific point in a given amount of time.
3. What units are typically used to measure flow rate?
The most common units used to measure flow rate are cubic feet per minute (CFM) or cubic meters per hour (m3/h). These units represent the volume of air passing through a specific point in a given amount of time.
4. How does the pressure of the air affect the flow rate?
The pressure of the air has a direct impact on the flow rate. The higher the pressure, the faster the air will flow through a given volume. This is because higher pressure means more force pushing the air through the system, resulting in a higher flow rate.
5. Can the temperature of the air affect the flow rate?
Yes, the temperature of the air can have an effect on the flow rate. Warmer air is less dense than colder air, so it will have a lower flow rate for a given volume. This is because the molecules in warmer air are more spread out and have less force pushing them through the system, resulting in a slower flow rate.
