Given a success rate of 1% and 100 tries....
In summary, the probability of no success is 36.6%, the probability of 1 success is 37.97%, and the probability of 2 successes depends on the formula used for 1 success. When calculating the probability of success on one particular throw and failure on every following throw, the formula would be P(1 success) = (0.01) * (0.99)^99 * 100 combinations, and the probability of success on any particular throw out of 100 throws and failure on the other 99 throws would be 100 times the previous answer. The probability of 2 specific wins out of 100 throws would be 0
llatosz
62
What is the probability of no success? 1 success? 2 successes?
No success: 0.99^100 = 36.6% chance?
1 success: (0.99^99) + 0.01 = 37.97% chance? or (0.99^99) * (0.01)^1 = 0.369% chance ? You would think it would be fairly likely
2 successes: ? -Depends on formula for 1 success
Can someone show me how to calculate? This is to show a friend how you won't be guaranteed to get an item with a 1% drop rate if you buy 100 drops for a video game, but I want to explore it a bit further.
What would you say the chances of success on throw 1 and failure on every following throw?
And the chance of fail at throw 1, success at throw 2 and fail on the rest?
Etc.
WHY do you think that? There's a reason!
Etc.
Yes that is kinda what I'm asking lol. I'm aware that for 1 success there are 100 different combinations, and that for 2 successes there are like 998 or 999 combinations.
So the chance of success on throw 1 is 1%, and failure on every following throw is .99^99 = 36.97%, so the chance of 1 success would be 37.97% like I said?
Would this be the chance of 1 success out of 100?
You'd think that, because you have 100 chances of getting it, despite the low chance each time.
If you state it non-mathematically, I think it is easier:
What's the chance of winning on one particular throw? 0.01
What's the chance of winning on one particular throw and losing on the other 99 throws? 0.01 x 0.9999
Whats the chance of winning on ANY particular throw out of the 100 throws and losing on the other 99? 100 times previous answer.
P(1 success) is p1q(100-1) x (combinations: 1 from 100)
Which comes to 0.370 (3sf) or 0.3697 (4sf)
For 2 wins, you are going to say p2q(100-2)
and that is, say, P(WWLLLL...) , but it is also P(LLLWLLWLLL...) or P(WLLLLLLLLLWLLLL...) etc.
So you need to count how many ways you can get 2 wins out of 100 throws, 100C2 and add up all those probabilities.
Or more simply, just multiply P(2 specific wins) by 100C2
Ah okay! Thanks! So p is probability of success and q is probability of fail from what I infer.
So, going forward "1 win" just means any 1 win, so,
P(1 win) = (0.01) * (0.99)99 * 100combos = 0.3697 = 36.97%
But then
P(2 wins) = (0.01)2 * (0.99)98 * (99*99)combos = 0.366 = 36.6% ... which doesn't make sense.
Also allow me to check my understanding if i may:
P(0 win) + P(1 win) + P(2 wins) + P(3 wins) ~=~ 0.95 to 1 because that covers nearly all possibilities since 4+ wins at 1% win rate should be incredibly rare
note the probability of zero successes is
##\binom{n}{0} (\frac{1}{n})^0 (1-\frac{1}{n})^n = (1-\frac{1}{n})^n \approx e^{-1}## for large n
Oops! Sorry that slipped through without my noticing. Yes. And q = 1-p
But then
0.3660 + 0.3697 + 0.1849 = 0.9206 so, yes, there's not much chance left now
But your calculation for 2 combinations is not right.
P(2 specific wins) = 0.012 x 0.9998 is ok, but any 2 from 100 combinations is not 99 * 99
There are 100 positions for one win and 99 remaining positions for the other win, = 9900 permutations
But that counts every pair of wins twice - eg. WWLLL... or WWLLL... / WLLWLLL... or WLLWLLL... etc
So the number of combinations (when we ignore the order of selection) is 9900 / 2 = 4950
So P(exactly 2 wins in any positions) = 0.012 x 0.9998 x 4950 = 0.000037346 x 4950 = 0.1849
When you get on to 3 wins, there are 100 x 99 x 98 permutations, but each set of 3 wins gets counted 6 times (3 x 2 x 1)
and for 4 wins, there are 100 x 99 x 98 x 97 permutations, with each set of 4 wins getting counted 24 times (4 x 3 x 2 x 1 )
So the C(N,r) formula = ## \frac {N!} {(N-r)! \times r!}##
so, eg. ## C(100,4) = \frac {100!} { (100 - 4 )! \times 4!} = \frac {100!} {96! \times 4!} = \frac {100.99.98.97} {4.3.2.1} = 3,921,225 ##
Likes llatosz
Oh wow, youre right, that's pretty neat!
Oh okay, this totally makes sense now!
And yes, I am getting the same result as you for 3 wins too! Makes sense, thank you! :D
Now I can formulate some numbers for my friend's loot drop gambling in a video game we play! There's an item he wants with a 1% drop rate and his idea was that he can buy 100 chances ($1 each) to guarantee himself the item lol.
Thank you very much for all your help, you are kind and it is fully appreciated :)
You're welcome.
So what is your conclusion, or your friend's? Does he think 100 tickets is enough to be certain of winning?
I was a little surprised when I worked out how many tickets I'd need, to have more chance of winning than not winning.
With a 1% chance on each try, the chance of not winning on anyone try is 99%. The chance of not winning on either of 2 tries is 99% of 99%, or 0.99^2, which is 98.01%. For 100 tries, the chance of not winning at least once is 0.99^100, which is 0.366032, or 36.6032%. The chance of winning at least once is 100% minus the chance of not winning at least once, which for 100 tries with 1% chance of winning on each try, is 100% - 36.6032%, which is 63.3968%.
Related to Given a success rate of 1% and 100 tries....
1. What is the probability of success with a success rate of 1% and 100 tries?
The probability of success is always equal to the success rate, so in this case it would be 1%. However, with 100 tries, the chances of at least one success increases to approximately 63%.
2. Is a 1% success rate considered high or low?
A 1% success rate is considered low in most scientific studies. It means that for every 100 attempts, only 1 will be successful.
3. How does increasing the number of tries affect the overall success rate?
The overall success rate will stay the same regardless of the number of tries. However, with more tries, the chances of at least one success increases.
4. Can the success rate be improved by changing the number of tries?
The success rate cannot be improved by changing the number of tries. The success rate is a fixed value and can only be improved by changing other factors such as the method or conditions of the experiment.
5. What is the significance of a 1% success rate in scientific studies?
A 1% success rate may still be significant in certain scientific studies, depending on the nature of the experiment and the expected success rate. However, it is generally considered low and may require further investigation or improvement of methods.
