Given an NLO reduce it to unconstrained optimization problem
  • Thread starter Thread starter ver_mathstats
    Optimization
ver_mathstats
We are required to reduce an unconstrained optimization problem. Problem is written below.
reduce to an unconstrained optimization problem
We are given the problem min x3-x42 such that (1): x12 + x3 = 2 and (2): (x2-x4)(x2+x4)=1.
What I did was solve for x3 in (1) and then solve for x4 in (2). I substituted those equations into min x3-x42 and I obtain the solution: 2-x12-x22+1, would this be the correct approach to this problem?
Thank you!
You wrote ##x_{4^2}## in a couple of places, is that supposed to be ##x_4^2##?
I think you solved the problem just fine, but I would note literally solving for. ##x_4## requires writing down a ##\pm## which you have to carefully observe goes away when you square it, whereas solving for ##x_4^2## and substituting that does not.
Are you supposed to solve this? It's kind of weird, I think maybe they wanted you to maximize the function?
Likes ver_mathstats and jim mcnamara
Yes I meant it to be the second one my apologies. No no, I just needed to reduce it and was making sure I was on the right track, we do not have to maximize it, the next part is to do DFP on the problem.
@ver_mathstats, please don't write acronyms without explaining what they mean. For example, I guess that NLO stands for nonlinear optimization, but I have no idea what DFP stands for.
Sorry I'm just so used to that, it's the David Fletcher Powell method.
I'd be surprised if anyone at this site has heard of this guy, let alone would know what DFP stands for.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
