Given order for every element in a symmetric group
In summary, to compute the order of each element in the symmetric group ##S_4##, one can decompose the group and take one representative from each conjugacy class. Alternatively, one can write out each element's cycle decomposition.
Mr Davis 97
1,462
44
Compute the order of each of the elements in the symmetric group ##S_4##.
Is the best way to do this just to write out each element's cycle decomposition, or is there a more efficient way?
Since the order of the elements are the same within each conjugacy class, I would just take one representative of each conjugacy class. But yes, I would do it by looking at the cycles of that representative.
Likes Mr Davis 97
You can decompose the group:
$$S_4 \cong A_4 \rtimes \mathbb{Z}_2 \cong (V_4 \rtimes \mathbb{Z_3}) \rtimes \mathbb{Z}_2 \cong (\mathbb{Z}_2^2 \rtimes \mathbb{Z_3}) \rtimes \mathbb{Z}_2$$
Related to Given order for every element in a symmetric group
1. What is a symmetric group?
A symmetric group is a mathematical group that consists of all possible permutations of a finite set. In other words, it is a group of symmetries that can be applied to a set without changing its structure.
2. How do you determine the order of a symmetric group?
The order of a symmetric group is equal to the number of elements in the group, which can be calculated using a formula: n!, where n is the number of elements in the set. For example, the order of a symmetric group with 4 elements would be 4! = 24.
3. What is the significance of the order in a symmetric group?
The order of a symmetric group is important because it determines the number of possible permutations or symmetries that can be applied to a set. It also helps in understanding the structure and properties of the group.
4. Can the order of a symmetric group be infinite?
No, the order of a symmetric group can only be finite since it consists of a finite set. However, the order can be very large depending on the number of elements in the set.
5. How is the order of a symmetric group related to its subgroups?
The order of a symmetric group is always divisible by the order of its subgroups. In fact, the order of a subgroup must be a divisor of the order of the symmetric group. This relationship is known as Lagrange's theorem.
  • Linear and Abstract Algebra
