Given p and q are positve real numbers and 1/p +1/q = 1..
In summary, the relationship between p and q is that they are reciprocals of each other, and this equation can be solved using algebraic manipulation. This equation, known as the harmonic mean, has significance in mathematics and can be generalized for more than two variables. It also has implications in solving real world problems, such as finding average speed or calculating equivalent resistance.
rsa58
85
hey i can't figure this out:
if p and q are positve real numbers and
1/p +1/q = 1
show that if u and v are greater than or equal to zero then
uv=< (u^p)/p +(v^q)/q.
Mathematics news on Phys.org
To show that uv is less than or equal to (u^p)/p + (v^q)/q, we will use the AM-GM inequality. The AM-GM inequality states that for any two positive real numbers a and b, the arithmetic mean (a+b)/2 is always greater than or equal to the geometric mean √(ab). This means that (a+b)/2 ≥ √(ab).
Using this inequality, we can rewrite the left side of the given equation as:
1/p + 1/q = (1/2)(1/p + 1/q) + (1/2)(1/p + 1/q)
= (1/2)(1/p + 1/p) + (1/2)(1/q + 1/q)
= (2/p) + (2/q)
= 2(1/p + 1/q)
= 2(1)
= 2
Now, let's look at the right side of the given equation:
(u^p)/p + (v^q)/q = (1/p)(u^p) + (1/q)(v^q)
Using the AM-GM inequality, we can rewrite this as:
(1/p)(u^p) + (1/q)(v^q) ≥ 2√((u^p)(v^q))
= 2√((uv)^p)
= 2(uv)^p/q
= 2(uv)^1
= 2uv
Since 2 ≥ 2uv, we can conclude that:
1/p + 1/q ≥ (u^p)/p + (v^q)/q
which means that:
uv ≤ (u^p)/p + (v^q)/q
This shows that for any two positive real numbers u and v, if 1/p + 1/q = 1, then uv is less than or equal to (u^p)/p + (v^q)/q. Therefore, the given statement is true.
FAQ: Given p and q are positve real numbers and 1/p +1/q = 1..
What is the relationship between p and q?
The relationship between p and q is that they are reciprocals of each other. This means that when one value is multiplied by the other, the result is always 1.
How can this equation be solved?
This equation can be solved by using algebraic manipulation. By rearranging the equation, we can find the value of one variable in terms of the other.
What is the significance of this equation in mathematics?
This equation is known as the harmonic mean and has many applications in statistics and geometry. It is also used in the proof of the arithmetic-geometric mean inequality.
Can this equation be generalized for more than two variables?
Yes, this equation can be generalized to n variables. The general form is 1/x1 + 1/x2 + ... + 1/xn = 1, where x1, x2, ..., xn are positive real numbers.
What implications does this equation have in real world problems?
This equation can be used to solve various real world problems, such as finding the average speed of a moving object when given the distance and time, or calculating the equivalent resistance in a parallel circuit.
