Given the concurrent forces, Determine the resultant
In summary: To find the resultant of all 4 of these forces, add the respective components.In summary,Homework statement:F1 = 10N at 37 N of WF2 = 15N NorthF3 = 14 N toward the negative z-axisF4 = (8i + 12j + 4k)NThe resultant is 14.9666 Newtons.
hiineko
63
F2 = 15N North
Find the resultant
I use 10cos37/sin37 for F1
I use 15cos0/sin0 for F2[/B]
But I don't how to use F3
and F4
Please help thankyou guys!
Write all three as ## \ \ a \; {\bf \hat\imath} + b\; {\bf \hat \jmath} + c\;{ \hat k}\ \ ## and add up the components.
Make a sketch.
Likes hiineko
Make a sketch.
hmmm I'll get the magnitude of it?
I got 14.9666
Help pls thankyouuuu
I got 14.9666
Not right.
Please follow the suggestion of BvU.
Show your work.
SammyS said:
Not right.
Show your work.
Can you please guide me in understanding f3 and f4? Thankyou!
I assume the unit vectors are aligned as follows:
## \hat{i} \ ## points East.
## \hat{j} \ ## points North.
## \hat{k} \ ## points upward.
Is that what is meant for F3 & F4?
Soooooo I'll just
hiineko said:
Soooooo I'll just
That's a rather incomplete description of what to do.
Add all the vectors component by component.
What form should you use for the resultant?
Okay wait
SammyS said:
Waiting ...
Btw how could I get the component of F3 and F4 that is my question , I know how to get the compnent of F1 and F2 you use xcosΘ and xsinΘ.
They are already given.
So you mean to say
i = x component
j = y component
k = z component
hiineko said:
So you mean to say
i = x component
j = y component
k = z component
Yes
SammyS said:
Yes
F3 = 14 N toward the negative z-axis what about this? Can you please translate this to me
What would be your interpretation of 5N to the West?, for example.
I say it as 5N 0 degrees from the x-axis
How about 180° ?
In other words, that's 5N in the direction of -x . that is to say, toward the negative x axis.
SammyS said:
How about 180° ?
Okay so "F3 = 14 N toward the negative z-axis" - What degree? Bc I'm aware of x-axis and y-axis. But I have problems dealing with z-axis
Like you said in post #13:
## \hat{i} \ ## is in h x direction, etc.
The vector ##\displaystyle \ (5\hat i-7\hat j+3\hat k\, )\text N\ ## has an x-component of 5N, a y-component of -7N, and a z-component of 3N .
So you mean to say that F3 has x-component of 0, y-component of 0, z-component of -14?
Yes, -14 Newtons.
SammyS said:
Yes, -14 Newtons.
Okay I will put the components of F1 F2 F3 F4 before I add it all
F1 = Σx = 10cos37 = 7.99; Σy = 10sin37 = 6.018
F2 = Σx = 15cos90 = 0; Σy = 15sin90 = 15
F3 = sqrt(0^2+0^2+(-14)^2) = 14
F4 = sqrt(8^2+12^2+4^2) = 14.9666
right?
right?
You have found the x & y components of F1 and F2. the z component of each being 0.
The magnitudes of F3 and F4 are correct, but hardly needed.
I presume you are to leave the result in the form with i, j, k unit vectors.
I got it right? :) Means I just have to add of these and that is the final answer the resultant?
That sentence is kind of garbled, but I gather that you have gotten the answer.
I hope you understand it.
Related to Given the concurrent forces, Determine the resultant
What is meant by concurrent forces?
Concurrent forces are forces that act on a single point, but have different directions and magnitudes.
How do you determine the resultant of concurrent forces?
To determine the resultant, you must first draw a vector diagram to scale. Then, you can use the parallelogram method or the triangle method to find the resultant vector.
What factors affect the resultant of concurrent forces?
The resultant of concurrent forces is affected by the magnitude and direction of each individual force, as well as the angle between them.
Can the resultant of concurrent forces be zero?
Yes, if the sum of all the forces acting on an object is zero, the resultant will also be zero. This means that the forces are balanced and the object will remain at rest or continue to move at a constant velocity.
What are some real-life examples of concurrent forces?
Some examples of concurrent forces in real life include a tug-of-war, a person pushing a shopping cart, and a bird flying in the air while experiencing wind resistance.
