Given the following values of x, g(x) and g'(x), what is h'(2/3) if h(x)=g(2/x)?
  • Thread starter Thread starter BifSlamkovich
BifSlamkovich
1. Homework Statement
x g(x) g'(x)
-2 -2 2
-1 0 1
0 1 2
1 3 4
2 7 3
3 9 2
2. Homework Equations
chain rule
3. The Attempt at a Solution
differentiate (2/x) and multiply that times g'(2/x). Plug in 2/3 into -2/(x^2), and one obtains -9/2. g'(2/((2/3)))= 2. The two multiplied together yields -9. Is that correct?
Please, Don't double-post questions.
Where's the problem statement? ... Oh! It's there in the title line. (It's a good idea to repeat the question in the main text.)
Yes, d/dx (g(2/x)) evaluated at x = 2/3 is g'(2/(2/3))∙(-2/(2/3)2).
Sorry about not posting the problem statement in the main text. And I double-posted because it was first in the wrong category. This is calc., not pre-calc.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
