Given three random numbers between 0 and 1, how to evenly populate a sphere?
In summary, the conversation discusses how to evenly populate a sphere of a given radius using three random numbers between 0 and 1. It is suggested to rotate coordinates along X, Y, and Z axes using the random numbers, with one point representing the polar angle, one representing the azimuthal angle, and the last representing the radius. However, it is noted that this method may not result in a uniform distribution over the surface of the sphere. Other methods are also discussed, such as choosing a solid cube with a diagonal of 2R and rotating the axes with three random angles to obtain a solid sphere. It is mentioned that this is a common exercise for job interviews.
member 428835
Hi PF!
Given three random numbers between 0 and 1, how to evenly populate a sphere of radius ##R## (assuming we use every point). I think it's similar to the 2D circle equivalent described here. Does this imply the PDF is ##4 x^2##, where the remaining analysis holds? Then one point is the polar angle, one is the azimuthal angle, and the last is the radius, which I guess is ##(3/4x)^{1/3}## where ##x## is the third random number generated.
The easiest and most intuitive way is to generate random points in a cube with coordinates from three random numbers between ##-R## and ##R## and reject those that are not inside the sphere. (I am assuming that you are including the interior and not talking only about points on the surface of a sphere.) It keeps everything simple.
Yea for sure, but I specified we must use every point (no rejections)
Sorry, I missed that. Then this sounds more like an academic exercise. I can't imagine why else that would be a requirement. I think your adjustment for the radius is right.
I'm applying for jobs that have weird interview questions, and so I am going through books and online question banks. I found one regarding circles, where the pdf was ##2x## and was hoping I could extrapolate to the 3D question. So academic in nature, but not actually for a class.
Likes FactChecker
Would not a sphere encompassing a cube with the same center simply have a radius equal to the length of a line from the cube's center to it's corner?
It would. But not sure this is relevant.
joshmccraney said:
Hi PF!
I don't know if you only want to just its surface or solid sphere.
1. If surface, you can choose a point with R distance from coordinate (0,0,0). Then three random numbers are three angles. You can rotate coordinates along X, Y, and Z axes using randomly generated three angles. If you keep doing it, you will get the full surface of a sphere.
2. Solid sphere: choose a solid cube with a diagonal is 2R. The center of the cure is at (0, 0, 0). Again, you can rotate X, Y, Z axis with three random angles. You will get a solid sphere with a radius of R.
Of course, if the condition requires you can not start with a point or a cube, then these methods are not fit for you.
Yes, and you have done this correctly for the distance from the centre. The next step is to distribute uniformly over the surface of the sphere with radius at that distance; this is more complicated than uniform distribution of ## \theta \text { and } \varphi ## (note that on Earth the area enclosed by 1 degree of latitude and longitude is not uniform).
Sorry, I'm not seeing how either approach works, though I like the situation 1) you've posed for getting the surface of a sphere; haven't thought of this one, so I should try solving it.
Are you sure? Perhaps I'm missing something big here. I am thinking for the asimuthal angle ##\theta \in [0,2\pi]## each degree is symmetric, so it doesn't seem like we'd be denser in the west than the east. Isn't the same tru for the polar angle ##\phi\in [0,\pi]##? It doesn't seem like you'd populate more of the northern than southern hemisphere.
EDIT: okay, nevermind, I see your point. Letting ##\phi=10^\circ## implies the ##\theta## "ring" is much smaller, and therefore denser than ##\phi=90^\circ##. But how do we account for this? I'm trying to think surface metrics here: given ##r## and ##\phi##, we have a circumference of length ##2\pi (r\sin\phi)## where ##\theta## then selects the specific location on. We somehow want to normalize the distribution of ##\phi## such that ##2\pi (r\sin\phi)## receives the same average points per length for all ##\phi##. So we want the distribution of ##\phi## to be more concentrated around ##\phi=90^\circ## and less concentrated around ##\phi = 0^\circ,180^\circ##.
I don't know why, but intuitively I'm thinking perhaps we distribute ##\phi## like a circle, so that ##\phi = 90^\circ - \sqrt{90^2-x^2}## if ##x \in [0^\circ,90^\circ]## and ##\phi = 90^\circ - \sqrt{90^2-(x-180)^2}## if ##x \in [90^\circ,180^\circ]## where ##x## is the random number normalized from 0 to ##2\pi##.
The surface of a sphere is ##4\pi r^2##. Then if the radius is given by ##\sqrt[3] x R## and the other 2 x's are angles, the density of points in ONLY radius as variablespace is ##dx/d\sqrt[3] x = 3\sqrt[3] x^2/R## at radius ##r=\sqrt[3] x R##. Thus the density of points at radius r is ##3r^2 /R^3 \sim 4\pi r^2##. Then if we take angles from the other 2 random points such that a sphere's surface is covered homogeneously, the density at a point ##(r,\phi,\psi)## is the density ##3r^2 /R^3## calculated earlier divided by the surface of a sphere ##4\pi r^2## which is constant.
Checking that the volume of the sphere is ##(4/3)\pi R^3##, indeed multiplied by this constant it becomes 1: ##(4/3)\pi R^3 3r^2 /(R^3 4\pi r^2) = 1##.
The key is to consider the exponentials ##x=e^{-y}## and ##r/R = e^{-z}##. Now the fraction of volumes up to r versus R equals ##e^{-3z}##. You want to choose r such that this equals x, since that's the chance to get below x. Then of course ##y=3z## giving ##r/R=\sqrt[3]{x}##
Yes that's right.
I don't think intuition will help here*, not compared to either working it out properly or searching for a solution that already exists for a uniform distribution on the surface of a sphere.
Mathworld calls this Sphere Point Picking.
* I have noticed before that you tend to rely on what you call intuition too much: I would call this guessing. Guessing is OK, but once you have made a guess you need to try it to see if it works, not just throw it out there on a forum and expect someone else to try it for you.
You don't know what work I've put into each problem before hand. If you don't like me posting, just don't answer. I have appreciated your help in the past; after reading your perspective, I can do without it.
First, let's look at the general situation where we have a random variable ##x## with pdf ##p(x)## mapped onto a second r.v. by ##y = g(x)##. What is the pdf for ##y##? Call it ##f(y)##?
First, the probability that ##y## lies between ##y## and ##y + dy## is ##f(y)dy##.
This is the same as the probability that ##x## lies between ##x + dx##, where ##y = g(x)## and ##y + dy = g(x + dx)##.
Using a Taylor expansion to linear order we see that:
$$dy = g(x + dx) - g(x) = g'(x)dx$$Which is just the usual "differential" equation.
This gives us$$f(y)g'(x)dx = p(x)dx$$Hence $$f(y) = f(g(x)) = \frac{p(x)}{g'(x)}$$To see how this works, for the circle we need probability of a point lying inside radius ##r## to be proportional to the area of that smaller circle. As area is proportional to ##r^2##, we need:
$$p(r \le a) \sim a^2$$And, as the cdf is the integral of the pdf, this means that the pdf for ##r## must be linear. For a circle of radius ##R## this gives:
$$f(r) = \frac{2r}{R^2}$$Now, if we have ##x## uniformly distributed on ##[0,1]##, then ##p(x) = 1## and we have an equation for ##r = g(x)##:
$$f(r) = f(g(x)) = \frac{2g(x)}{R^2} = \frac{1}{g'(x)}$$This gives us:
$$g(x)g'(x) = \frac{R^2}{2}$$Hence:
$$\frac d {dx} \big (g(x)^2 \big ) = 2g(x)g'(x) = R^2$$And this gives us the required mapping from ##x## to ##r##:$$r = g(x) = R\sqrt x$$We can also confirm this by calculating the probability of choosing a point in a more general area of the circle, between ##r_1## and ##r_2## and ##\varphi_1## and ##\varphi_2##:
$$A = \int_{r_1}^{r_2} \int_{\varphi_1}^{\varphi_2} r \ d\varphi \ dr = \frac 1 2 (r_2^2 - r_1^2)(\varphi_2 - \varphi_1)$$Now, we use the mappings from ##x,y## which are uniform on ##[0,1]##:
$$\varphi = 2\pi y, \ r = R\sqrt x \ \ \text{hence} \ \ y = \frac{\varphi}{2\pi}, \ x = \frac{r^2}{R^2}$$And:
$$p(A) = p(\frac{\varphi_1}{2\pi} \le y \le \frac{\varphi_2}{2\pi})p(\frac{r_1^2}{R^2} \le x \le \frac{r_2^2}{R^2}) = \frac{1}{2\pi R^2}(\varphi_2 - \varphi_1)(r_2^2 - r_1^2) = \frac{A}{\pi R^2}$$So, the probability of choosing a point in such an area is indeed proportional to the area.
For the sphere, we can have simply ##\varphi = 2\pi y##, but we need to map ##x## and ##z## to ##r## and ##\theta## taking account of the factors in the spherical volume element.
FAQ: Given three random numbers between 0 and 1, how to evenly populate a sphere?
How can I evenly populate a sphere using three random numbers between 0 and 1?
To evenly populate a sphere using three random numbers between 0 and 1, you can use the Monte Carlo method. This involves randomly selecting points within the sphere and checking if they are evenly distributed. If not, the process is repeated until an even distribution is achieved.
Can I use any other method besides the Monte Carlo method?
Yes, there are other methods that can be used to evenly populate a sphere using three random numbers between 0 and 1. One example is the Icosahedral Method, which involves dividing the sphere into smaller triangles and randomly selecting points within each triangle.
How many points do I need to evenly populate a sphere?
The number of points needed to evenly populate a sphere depends on the desired level of accuracy and the method used. Generally, a higher number of points will result in a more even distribution.
Can I use this method for spheres of any size?
Yes, the Monte Carlo method and other methods can be used for spheres of any size. However, the number of points needed may vary depending on the size of the sphere.
Is this method applicable to other shapes besides spheres?
Yes, the Monte Carlo method and other methods can be adapted to evenly populate other shapes besides spheres. However, the process may be more complex and the number of points needed may vary depending on the shape.
