Global Extrema of a Trigonometric Function
In summary, we have shown that $f(x,y)=\sin^2(x)\cdot \cos^2(y)$ has a strictly local maximum at $\left (\frac{\pi}{2}, 0\right )$ and that this is also a global maximum. We can also deduce that the function has a global minimum at all points where $\sin^2(x)$ and $\cos^2(y)$ are both equal to $-1$ in a sufficiently small neighborhood. This can be proven by showing that the functions $\sin$ and $\cos$ have a strict local minimum at $0$ and $\frac{\pi}{2}$, respectively, and that their squares and product are also less than $1$ in a
mathmari
MHB
5,049
Hey ! :giggle:
Let $f:\mathbb{R}^2\rightarrow \mathbb{R}^2$, $f(x,y)=\sin^2(x)\cdot \cos^2(y)$.
- Show that $f$ has at $\left (\frac{\pi}{2}, 0\right )$ a strictly local maximum and that is also a global maximum.
- Determine all points at which $f$ gets its global minimum.
I have sone the following :
It holds that $|\sin (x)|\leq 1$ so $\sin^2(x)\leq 1$ and also that $|\cos (x)|\leq 1$ so $\cos^2(x)\leq 1$.
From that we get that $f(x,y)\leq 1$, that means that $1$ is a maximum of $f$.
At the point $\left (\frac{\pi}{2}, 0\right )$ the function gets the value $1$, that means that $f$ has at $\left (\frac{\pi}{2}, 0\right )$ a strictly local maximum.
Is that correct so far? :unsure:
Hey mathmari!
At this stage we don't know yet if $1$ is an actual maximum of the function.
We only know that $1$ is an upper bound of the function. 🤔
We now have a point where we achieve the upper bound, which implies that $1$ is indeed a maximum of the function.
However, at this stage we don't know yet, if it is a strictly local maximum. 🤔
Do we have to show that in the neighbourhood of the point the function achieves only at this point the value $1$ ? Or how do we show that? :unsure:
Yes. That is what it means that a local maximum is strict. (Nod)
The function $\sin x$ has a strict local maximum at $x=\frac\pi 2$, doesn't it? 🤔
So we have that for each other $x$ it holds that $\sin(x)<1$ and so we get that $\sin^2 (x)\cdot \cos^2 (y)<1$ for $x\neq \frac{\pi}{2}$, right?
So can we say that this means that at $\left (\frac{\pi}{2}, 0\right )$ the function has a strictly local maximum?
:unsure:
Only in a small enough neighborhood of $(\frac\pi 2,0)$. 🧐
We still have the case that we are in a small enough neighborhood with $x= \frac{\pi}{2}$.
Can we deduce in that case as well that the function value is strictly less than $1$? (Wondering)
In a small neighborhood of $0$ the function $\cos^2(y)$ is only $1$ at $y=0$ and in a small neighborhood of $\frac{\pi}{2}$ the function $\sin^2(x)$ is only $1$ at $x=\frac{\pi}{2}$, that means that in a small neighborhood of $(\frac\pi 2,0)$ the function $f$ is less than $1$.
Ia that correct so far? :unsure:
Yep. (Nod)
Yep. (Nod)
So we get that $f$ has at this point a strictly local maximum , right?
To show that this is also a global maximum do we say that it cannot be greater than $1$ ?
Also can we just mention the parts with the small neighborhoods at #7 or do we have to prove that?
:unsure:
Indeed.
Suppose it was not a global maximum. Then there would have to be another point where $f$ is greater than $1$.
But we already established that $1$ is an upper bound, leading to a contradiction.
So it is indeed also a global maximum. (Nod)
The functions $\sin$ and $\cos$ are well known to have a strict local maximum at $\frac\pi 2$ respectively $0$.
So they are less than $1$ in a sufficiently small neighborhood around those points.
Consequently their squares and product are also less than $1$ in a sufficiently small neighborhood.
I believe that is sufficient to serve as proof. 🤔
Indeed.
So it is indeed also a global maximum. (Nod)The functions $\sin$ and $\cos$ are well known to have a strict local maximum at $\frac\pi 2$ respectively $0$.
Ok! I see! :geek:
At the second part,where we have to determine all points at which $f$ gets its global minimum, do we have to do the same as in the first part just for minimum instead of maximum ? :unsure:
Yep. (Nod)
Yep. (Nod)
Ah the minimum in this case is $0$ because of the square, right? :unsure:
Indeed. (Nod)
Indeed. (Nod)
So we have that $\sin^2(x)\cdot \cos^2(y)\geq0$ and at all points with $x=n\pi$ and all points with $ y=(2k-1)\frac{\pi}{2}$ the function achieves that minimum, which is a global minimum because there is no other lower value of the function.
Is that correct and complete? Or do we have to prove something more?
:unsure:
Correct and complete. :geek:
Great! Thank you very much! 🤩
FAQ: Global Extrema of a Trigonometric Function
What is a local extremum of a function?
A local extremum of a function is a point where the function reaches either a maximum or minimum value within a small neighborhood of that point. This means that the function is either increasing or decreasing on either side of the point.
How is a local extremum different from a global extremum?
A global extremum is the absolute maximum or minimum value of a function over its entire domain, while a local extremum only applies to a small neighborhood around a specific point. A global extremum may also be a local extremum, but a local extremum is not necessarily a global extremum.
How can I determine if a function has a local extremum?
To determine if a function has a local extremum, you can use the first derivative test. This involves finding the critical points of the function, which are points where the derivative is equal to zero or does not exist. Then, you can evaluate the second derivative at these points to determine if they are local maxima or minima.
Can a function have more than one local extremum?
Yes, a function can have multiple local extrema. This can occur when the function has multiple critical points, or when there are multiple points where the derivative is equal to zero or does not exist. These points can be either local maxima or minima.
How do global extrema relate to local extrema?
Global extrema are the absolute maximum or minimum values of a function over its entire domain. Local extrema, on the other hand, only apply to a small neighborhood around a specific point. However, global extrema can also be local extrema, as they are the largest or smallest values in that neighborhood. In other words, all global extrema are local extrema, but not all local extrema are global extrema.
