Going Crazy Exploding Projectiles
  • Thread starter jessicak
  • Tags
    Projectiles
In summary, a projectile is launched at an angle with respect to the horizontal. At its peak, it explodes into two pieces of equal mass that continue to move in the original plane of motion. One piece strikes the ground a distance D farther from the launch point than the point directly below the explosion at a time t<v0sin/g. The other piece reaches a height of h=(v02sin2-2gtv0sin+gt2)/g.
jessicak
1. Homework Statement
A projectile is launched with speed v0 at an angle with respect to the horizontal. At the peak of its motion, it explodes into two pieces of equal mass, which continue to move in the original plane of motion. One piece strikes the ground a horizontal distance D farther from the launch point than the point directly below the explosion at a time t<v0sin/g. How high does the other piece go? Answer in terms of v0, , g, and t.
2. Homework Equations
m1v1=m2v2
h=v02sin2(/g
3. The Attempt at a Solution
I know I should be doing a momentum balance in the vertical direction before and after the collision, but I'm struggling to get the right equation. Any help would be appreciated
. Let v1 be the vertical velocity of the piece that reaches the ground and v2 be the vertical velocity of the piece that goes higher. Before the collision:m1v1sin=m2v2sinAfter the collision:m1(v1sin-gt)=m2(v2sin)Solve for v2sin:v2sin=m1(v1sin-gt)/m2Now plug in for v2sin to find h:h=(v02sin2-2gtv0sin+gt2)/g
FAQ: Going Crazy Exploding Projectiles
What are "Going Crazy Exploding Projectiles"?
"Going Crazy Exploding Projectiles" is a term used to describe projectiles that have unpredictable and chaotic movements, often causing them to explode unexpectedly.
What causes projectiles to "go crazy" and explode?
There can be a variety of factors that contribute to projectiles "going crazy" and exploding. Some common causes include defects in the projectile's design or manufacturing, improper storage or handling, or external factors such as extreme temperatures or impacts.
Can "going crazy" projectiles be dangerous?
Yes, "going crazy" projectiles can be very dangerous. Their unpredictable movements and explosions can cause harm to people, animals, and property. It is important to handle and store projectiles properly to minimize the risk of accidents.
How can scientists study "going crazy" projectiles?
Scientists can study "going crazy" projectiles by conducting experiments in controlled environments, such as laboratories or testing facilities. They can also use computer simulations to model and analyze the behavior of these projectiles.
What can be done to prevent projectiles from "going crazy" and exploding?
To prevent projectiles from "going crazy" and exploding, it is essential to follow proper safety protocols and handle them with caution. Regular maintenance and inspection of projectiles can also help identify potential issues before they become dangerous. Additionally, rigorous testing and quality control during the manufacturing process can help prevent defects that can lead to unpredictable behaviors.
