zoe101
- 3
Are there someones know about gold's index of refraction in micro-onde, for exemple in frequency 10GHz? Or a book in which I may find the value. Thanks a lot.
Claude Bile said:
Gold's index of refraction in micro-onde refers to the measure of how much a micro-onde (microwave) radiation is bent when it passes through a piece of gold. It is a dimensionless quantity that is typically represented by the symbol "n".
Gold's index of refraction in micro-onde is typically measured using a spectrophotometer, which measures the amount of light that is reflected, transmitted, or absorbed by a sample of gold. The index of refraction is then calculated using the ratio of the speed of light in a vacuum to the speed of light in the gold sample.
Gold's index of refraction in micro-onde is important in scientific research as it can provide valuable information about the physical and chemical properties of gold, such as its density, purity, and crystal structure. It is also used in the design and development of various optical and electronic devices.
Yes, Gold's index of refraction in micro-onde can change with varying temperatures. This is because the index of refraction is influenced by the density of the material, which can change with temperature. In general, the index of refraction decreases as temperature increases.
Yes, there are several factors that can affect Gold's index of refraction in micro-onde, including the purity and composition of the gold sample, the wavelength of the micro-onde radiation, and the angle at which the radiation passes through the sample. The index of refraction can also be affected by external factors such as pressure and magnetic fields.
