Good dayQuestion: Determine whether the series is convergent or
In summary, the conversation is about determining whether the given series is convergent or divergent. The suggestion of using the Integral test is mentioned, as well as comparing it to a p-series. The comparison test is then discussed and used to show that the series converges.
dangish
75
Good day..
Question: Determine whether the series is convergent or divergent:
Series starts at n=1 and goes to infinity.. Of 2/(n*4throot(2n+2))
What I mean is.. 2/(n*(2n+2)^(1/4))
Can someone tell me which test to try? I can't get it in the form of a p-series.. so I think maybe the Integral test would be worth a shot?
Can you compare it to a p-series?
Well it sort of looks like it but I can't get it in a form to be confident with an answer
Hint:
[tex]\sum_{n=1}^{\infty} \frac{1}{n*(n)^{1/4}}[/tex]
is a p-series. Does it converge? Can you compare your series to it?
In your example you would get 1/n^(5/4) where p = 5/4 >1 so that would converge.. correct?
I realize mine could be similar... Ʃ[ 2/(n*(2n+2)^(1/4))] But I can't combine the n's on the bottom because the +2 is messing with me.
Correct.
How does [itex]1/(2n+2)^{1/4}[/itex] compare with [itex]1/n^{1/4}[/itex]? Which one is bigger?
I would like to this 1/(2n+2)^(1/4) is bigger.
Well actually 1/(2n+2)^(1/4) would go to zero faster so I suppose it's smaller?
Right. So can you use this fact to apply the comparison test, and conclude that the series converges?
FAQ: Good dayQuestion: Determine whether the series is convergent or
What does it mean for a series to be convergent?
A convergent series is one in which the sum of the terms approaches a finite value as the number of terms increases. In other words, the series has a finite limit and does not continue to grow infinitely.
How do you determine if a series is convergent or divergent?
There are several tests that can be used to determine the convergence or divergence of a series, including the comparison test, the ratio test, and the integral test. These tests involve evaluating the behavior of the terms in the series and can help determine if the series approaches a finite value or diverges to infinity.
Can a series be both convergent and divergent?
No, a series can only be either convergent or divergent. If a series is convergent, it means that the sum of its terms approaches a finite value. If a series is divergent, it means that the sum of its terms does not approach a finite value and may grow infinitely.
What is the significance of determining if a series is convergent or divergent?
Determining the convergence or divergence of a series is important in mathematics and science because it allows us to understand the behavior of the series and make predictions about its future values. It also helps us determine the accuracy and validity of mathematical models and calculations.
Are there real-life applications of convergent and divergent series?
Yes, convergent and divergent series have many real-life applications in fields such as physics, engineering, and economics. For example, in physics, series are used to model physical phenomena such as sound waves and electrical currents. In economics, series are used to analyze trends and forecast future values in financial markets.
