Good explanation of aeroelastic flutter
In summary: Theoretically, the newer design may have a bit more or less safety margin, depending on how close the theoretical predictions are to the real-world results.In summary, Aeorelastic flutter is a self-feeding and potentially destructive vibration where aerodynamic forces on an object couple with a structure's natural mode of vibration to produce rapid periodic motion. The phenomenon can be observed in aircraft wings, bridges, and other structures with two vibration modes. It is important to design structures to avoid having vibration modes with similar frequencies, and to ensure that energy is not lost when the structure rotates in the opposite direction of the force.
dEdt
288
After looking into the Tacoma Narrows Bridge collapse, I tried to find out what this thing called aeorelastic flutter is and what causes it. Unfortunately, I didn't get a very good answer for either question, especially the latter one, and was hoping someone could help me out.
There is a fairly clear description of “aeorelastic flutter” on Wikipedia:
“Flutter is a self-feeding and potentially destructive vibration where aerodynamic forces on an object couple with a structure's natural mode of vibration to produce rapid periodic motion.”
It continues with more detailed descriptions of how it works.
http://en.wikipedia.org/wiki/Aeroelasticity
Here are two videos, both by NASA. The introduction gives an excellent explanation of the phenomenon. The first is of an aircraft’s horizontal tail section undergoing aeorelastic flutter. The second video is of the famous bridge you have already mentioned.
If memory serves, it was one of the major hurdles on the way to supersonic flight.
One way to understand the basic idea is to think about paddling a canoe. Suppose you keep the paddle in the water all the time, but you "feather" the blade on the return strokes to propel the canoe in one direction.
You can think of the motion of the paddle as two oscillations (one forwards and backwards, and the other rotating it to feather the blade) which are at the same frequency but 90 degrees out of phase with each other.
Now think about an aircraft wing that has two vibration modes, flapping up and down and twisting. If the vibration freqencies of the two modes are almost the same, it is possible for the air flowing over the wing to behave like the canoe paddle but "in reverse", with the driving force coming from the air and making the wing vibrate.
Of course in real life you try to design aircraft wings, turbine blades, etc, so they don't have vibration modes with similar frequences, and this can't happen!
If you look at videos of the Tacoma bridge, you can see the motion is a combination of vertical oscillation and twisting, though it's not so easy to separate out the two components as in the examples I gave.
Likes markkrebs
Thanks for the answers guys! Two more questions though about the Tacoma Narrows bridge:
1) Why/how does the air add more energy each cycle? I imagine that the wind adds energy by pushing it (sort of like it's explained here: ), but wouldn't this also remove energy when the bridge rotates in the opposite direction of the force?
2) Is there a simple reason why that particular torsional mode was excited, rather than the simpler one where the bridge as a whole twists in phase?
The ley thing is the coupling effect between two different modes of vibration. Think about the plane wing again. If the wing twists a bit for some reason, the angle of attack changes. That changes the lift force on the wing, which makes it start to flap up or down. But the up and down motion also changes the airflow over the wing, which can create a force causing it to twist.
To get flutter, the vibration frequencies of the two modes have to be similar, and the transfer of energy between the modes has to be such that it makes the amplitude of the motion increase rather than decrease. This is similar to pushing a child's swing. It's no use pushing at the wrong frequency (you need to push once per cycle, otherwise sone pushes will add energy to the swing and some will remove it) and you have to push at the right point in each cycle, otherwise you will tend to stop the swing rather than make it swing higher.
Every vibration mode of the bridge will be excited by random fluctuations in the wind to some degree, but unless there is a feedback mechanism, those random motions won't increase in amplitude. Probably the "simpler" torsional mode would have a different vibration frequency, and there were no other vibration modes at that frequency for it to interact with.
Predicting theoretically whether flutter will occur is difficult. It is possible to get a fairly reliable estimate of which pair(s) of vibration modes are the most likely to flutter, but getting an absolute "yes or no" answer to whether they WILL flutter is a much harder question to answer. Usually, you use theoretical predictions as a measure of the amount of "safety margin" and compare a new design with similar structures that have already been built, or with models tested in wind tunnels.
Likes markkrebs
FAQ: Good explanation of aeroelastic flutter
What is aeroelastic flutter and why is it important to study?
Aeroelastic flutter is a phenomenon in which an object experiences rapid, self-excited oscillations due to the interaction between aerodynamic forces and structural elasticity. It is important to study because it can lead to instability and failure in aircraft, bridges, and other structures, posing a safety risk.
What causes aeroelastic flutter?
Aeroelastic flutter is caused by the coupling between aerodynamic forces and structural flexibility. When the aerodynamic forces act on a flexible structure, it can cause structural vibrations that, in turn, affect the aerodynamic forces, creating a feedback loop that can lead to flutter.
What are the different types of aeroelastic flutter?
The two main types of aeroelastic flutter are torsional flutter and bending flutter. Torsional flutter occurs when the structure twists and oscillates around its longitudinal axis, while bending flutter occurs when the structure bends and oscillates around its transverse axis.
How is aeroelastic flutter analyzed and mitigated?
Aeroelastic flutter is analyzed using mathematical models and simulations, which take into account the aerodynamic and structural properties of the object. To mitigate aeroelastic flutter, engineers can make design modifications to reduce the flexibility of the structure, add damping mechanisms, or use control systems to actively counteract flutter.
What are some real-world examples of aeroelastic flutter?
Aeroelastic flutter has been observed in various structures, including bridges, wind turbines, and aircraft. One notable example is the Tacoma Narrows Bridge collapse in 1940, where torsional flutter caused the bridge to twist and collapse due to strong winds.
