Governing force and Neutron elastic scattering
In summary, the neutron elastic scattering and capture reactions are governed by the strong nuclear force.
oksuz_
70
Hi,
Which force does govern the neutron elastic scattering and capture reactions? It seems to me it is the strong nuclear force, but I am not sure about that.Thanks.
Sure. No electric charge involved, and the weak interaction is negligible if the strong interaction plays a role.
Likes oksuz_
Thanks mfb,
Do you have any resources in mind that you can suggest to me about the theory behind these interactions? I want to get some theoretical understanding of calculating these reactions' interaction cross-sections.
Elastic scattering is an ordinary collision. Inelastic scattering and capture involve the strong force,
In the macroscopic world, ordinary elastic scattering is governed by the electromagnetic force. Since neutron is an uncharged particle, it cannot be the electromagnetic force. It cannot the gravitational force either. It should be either the strong or weak nuclear force. So, which one?
Yes, mediated by the strong interaction.
Likes ORF and Vanadium 50
It's not primarily the EM force, yes, but that argument is not valid. The neutron has a magnetic moment and can interact electromagnetically that way.
Likes oksuz_
Thanks! I missed that part.
Can you tell quantitatively what is the fraction of the interaction level that comes from the EM force compared to the strong force?
When two billiard balls collide, none of the four forces are at work. Neutron elastic scattering is basically the same process.
Do billiard balls collide by electromagnetic force or by exchange force?
Neutrons can undergo elastic scattering by strong force (off hadrons).
There are particles not subject to strong force (and not identical to neutrons, so no exchange force either).
Photons are subject to neither strong nor weak forces. But they have electromagnetic forces. Neutron has no electric monopole charge. But does have a nonzero magnetic dipole moment. Therefore photons should have a nonzero but modest cross-section of elastic scattering from neutrons.
Gravitons are subject to gravitational forces alone, but neutrons have mass, therefore elastic scattering of gravitons off neutrons must have a nonzero but modest cross-section.
Neutrinos are subject to neither strong nor electromagnetic forces, but do have weak forces. Therefore elastic scattering of neutrinos off neutrons must have a nonzero but modest cross-section.
Electrons are not subject to strong forces but have both electromagnetic and weak forces. Therefore both electromagnetic interaction between electron charge and neutron magnetic dipole moment and weak interaction must contribute to cross-section of elastic scattering between neutrons and electrons.
Exchange force is a microscopic idea, not applying to macroscopic collisions. Billiard balls are neutral so e-m does not apply
Atoms are microscopic and neutral. What force causes two neutral hydrogen atoms to collide? Assume they are different isotopes so no exchange forces between nuclei or atoms - only electrons are identical. The outcome depends on whether the electrons´ spins are same or different - so it must be exchange force, not just electromagnetic.
Related to Governing force and Neutron elastic scattering
1. What is the governing force in neutron elastic scattering?
The governing force in neutron elastic scattering is the strong nuclear force. This force is responsible for holding the nucleus of an atom together and is much stronger than the electromagnetic force.
2. How does neutron elastic scattering occur?
Neutron elastic scattering occurs when a neutron collides with a nucleus and bounces off without losing any energy. This process is similar to billiard balls colliding and bouncing off each other.
3. What is the significance of neutron elastic scattering in nuclear reactors?
Neutron elastic scattering plays a crucial role in nuclear reactors as it is the main mechanism by which neutrons are slowed down and controlled. This allows for a sustained nuclear chain reaction to occur, producing energy in the form of heat.
4. How does the energy of the neutron affect its scattering behavior?
The energy of the neutron has a significant impact on its scattering behavior. At higher energies, the neutron is more likely to undergo inelastic scattering, where it loses energy and changes direction. At lower energies, the neutron is more likely to undergo elastic scattering, where it bounces off without losing any energy.
5. Can neutron elastic scattering be used for imaging purposes?
Yes, neutron elastic scattering can be used for imaging purposes, similar to X-rays. Neutrons have a different scattering behavior than X-rays, allowing for different types of materials to be imaged. This technique is commonly used in materials science and medical imaging applications.
