GPE Between the Moon and the Earth?
In summary, when determining the gravitational potential energy between the moon and earth, you cannot use the formula mgh as the gravitational field is not homogeneous. Instead, you must use Newton's expression for the gravitational potential, -(GMm/R), with R being the distance between the two objects. The total energy includes the kinetic energy of the moon and the gravitational potential energy between the two objects. However, when calculating the potential energy, be sure not to square the distance in the denominator.
isukatphysics69
453
How to determine GPE between moon and earth?
mgh
I know that gpe near Earth's surface is mgh, but at larger distances is there a specific way to calculate?
You can only use mgh when your gravitational field can be well approximated by a homogeneous one. This is not the case for the Earth-Moon system. You need to use Newton’s expression for the gravitational potential.
Likes isukatphysics69
so -(GMm/R^2) = Gravitational energy
so i will need the R to be sqrt(x^2+y^2) with the Earth centered at 0,0
Energy mechaninc will be the kinetic from the moon plus the gravitational energy at each time dt
also the velocity will be sqrt(x^2+y^2)
That's a lot of energy
I have my Earth at 0,0 so the kinetic energy from Earth is 0, kinetic energy of moon is .5mv^2 and potential energy is -GMm/R^2 and that is all of the energies i can think of. do those energy values look about right? id love to go to sleep so tired
No, you don't square the R in the denominator when calculating gravitational PE. When you do square it you're calculating the gravitational force instead (Newton's Law of Universal Gravitation).
Related to GPE Between the Moon and the Earth?
1. What is GPE Between the Moon and the Earth?
The GPE, or gravitational potential energy, between the Moon and the Earth refers to the potential energy that results from the gravitational pull between these two celestial bodies. It is a measure of the work that would be needed to move an object from one of these bodies to the other against their gravitational attraction.
2. How is GPE Between the Moon and the Earth calculated?
The GPE between the Moon and the Earth is calculated using the formula: GPE = (G * m1 * m2) / r, where G is the gravitational constant, m1 and m2 are the masses of the Moon and Earth respectively, and r is the distance between them.
3. What factors affect GPE Between the Moon and the Earth?
The GPE between the Moon and the Earth is affected by the masses of the two bodies and the distance between them. The larger the masses and the smaller the distance, the greater the GPE will be.
4. How does GPE Between the Moon and the Earth impact the Moon's orbit?
The GPE between the Moon and the Earth is one of the factors that determine the Moon's orbit around the Earth. As the Moon moves closer to the Earth, the GPE decreases, causing the Moon to speed up and move towards the Earth. On the other hand, as the Moon moves farther away, the GPE increases, causing the Moon to slow down and move away from the Earth.
5. Can GPE Between the Moon and the Earth be converted into other forms of energy?
Yes, GPE between the Moon and the Earth can be converted into other forms of energy, such as kinetic energy, when the Moon moves in its orbit. This energy transfer is what keeps the Moon in a stable orbit around the Earth.
