GPS receiver data transfer using RF transmission
A user is developing a miniature GPS system to transmit location data from a buoy to a remote location using RF transmission. They are seeking affordable alternatives to high-cost options like Conexant’s Jupiter GPS receiver and FreeWave’s ZumLink Ethernet Radio. Suggestions include considering personal locator devices like Garmin Inreach for satellite tracking and using Starlink for remote Internet access. It is noted that satellite solutions may be more cost-effective than traditional RF transmitters. The discussion also references successful implementations in projects like Ardupilot and SP9UOB's ballooning activities.
nauman
Hi all
I want to develop a miniature system using GPS receiver, a micro-controller, an RF transmitter and its receiver. The idea is to acquire lat/long of buoy dropped in sea which is equipped with miniature GPS receiver (with associated circuitry) which can send its position (lat/long data) to a remote location 10-20 Km away using some type of RF transmission. During initial search, i came across a "Conexant’s Jupiter Low Power (LP) Global Positioning System (GPS) receiver" and FreeWave’s ZumLink 900 Series Ethernet Radio for RF transmission but i think these are bit costly and overkill for this task.
Kindly help me for selection of low cost commercially available items for this task.
Thanks & Regards
The transmitter part is the most difficult.
Have you heard of personal locator devices such as Garmin Inreach? It can transmit your position to a satellite, so that you can be tracked over the Intenet.
If the tracking receiver is too remote for ordinary Internet, it could use a Starlink dish to get Internet from satellites. Starlink coverage is nearly (but not totally) global.
Surprising as it sounds, satellites and Internet may be less expensive than old fashioned radio transmitters and receivers.
Likes Klystron and berkeman
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
