Gr. 12 Dynamics -- A performer being lifted up by two ropes
  • Thread starter danielsmith123123
  • Tags
    Dynamics Gr
In summary, the conversation discusses the breakdown of a force of 430N [Up 35* L] into its x and y components using trigonometry. The net force is then determined using the Pythagorean theorem and the angle of the force is found using tan. There is a question regarding the notation used and the correct method for finding the x and y components. The expert advises constructing a triangle and using trigonometry to find the components.
danielsmith123123
Performer has a gravity force of 440N and is being pulled up by 2 ropes. One rope has a tension of 430N [Up 35* L] and the other exerts a force of 280N [Up]
F= ma
Fg= mg
1. break down 430N [Up 35* L] into components
430 cos 35 = 352.2N [L]
430 sin 35 = 246.6N
2.
ΣFx= 352.2N [L]
ΣFy= 246.6N + 280N - 430N
ΣFy = 86.6
3.
Pythagorean theorem with the two will give you a magnitude of 362.7N
Then using tan you can find the angle of [L 76 U]
This method was the one I was taught but it doesn't work for this question as the answer is 310N [U 38 L]
Can anybody help me?
Does this mean that the rope makes an angle of 35o with respect to the y-axis, or does the rope make an angle of 35o with respect to the negative x-axis?
What is the actual question ?
"Determine the net force"
I think the y axis.
If it was the negative x-axis wouldn't it be [Left 65 Up]
I think the y axis.
This is somewhat of a nonstandard notation. But, yes, I would tend to think that [Up 35o L] would mean "from the upward direction, tilt 35o toward the left". So, the tension force of the rope makes an angle of 35o to the y-axis. This means that you did not calculate the x and y components of the tension force correctly. Check your work. Draw an appropriate right triangle for this force showing the force as the hypotenuse and the legs as the x and y components. Label the angles inside the triangle. Use trig to find the legs.
Likes Lnewqban
Oh, ok thank you. Just this morning my teacher told me that cos will always give you the "x" component, an d sin will always give you the "y" component is that wrong?
cos will give you the x-component if the angle is measured relative to the x-axis. But, in this problem, the 35 degrees is measured from the y-axis. If you want to use cos to get the x-component, then you would need to use the angle that the force makes to the x-axis, rather than the y-axis.
It's best to construct your own triangle and just use trig.
Likes Lnewqban
Oh ok, thank you for all your help
You are welcome. Hope you enjoy your course.
