Undergrad GR: Attractors & Liouville's Theorem
Liouville's theorem states that the volume of phase space is preserved in classical Hamiltonian mechanics, implying that attractors do not exist in this framework. In general relativity (GR), while the Raychaudhuri equation suggests shrinking volumes, it does not directly address phase space dynamics. GR adheres to Liouville's theorem, but the phase space in field theories is infinite-dimensional, complicating the relationship between 3-dimensional volume and phase space volume. The discussion also touches on the implications of time reversal invariance in GR, with expanding solutions like white holes often dismissed due to unrealistic initial conditions. Overall, the connection between Liouville's theorem and GR remains complex and not fully rigorous due to the infinite degrees of freedom in field theories.
atyy
TL;DR
Does GR have attractors?
In classical Hamiltonian mechanics, because of Liouville's theorem about the volume of phase space being preserved by time evolution, there are no attractors.
Naively, I think of the Raychaudhuri equation in GR as showing a shrinking volume. However, I guess Raychaudhri's equation does not deal with the phase space of GR.
Is there something like the Liouville theorem in GR, especially since GR has a Hamiltonian formulation?
Likes Demystifier and vanhees71
Just a guess, but given that very little is known about the global properties of solutions to the initial value problem, I would say that it is a very hard question.
Likes atyy and vanhees71
Every Hamiltonian system obeys the Liouville theorem. GR is not an exception. Note, however, that the phase space in field theories is infinite dimensional. In particular, the 3-dimensional volume of a lump of matter (which may shrink due to gravitational collapse) has nothing to do with the infinite-dimensional phase-space volume.
GR is invariant under the time reversal. Raychaudhuri equation can describe also the expansion. In the black-hole context, such an expanding solution is called a white hole. Such solutions are usually discarded because they require unrealistic initial conditions, or equivalently, because for such solutions entropy decreases with time.
Are you sure the theorem holds in field theories?
Formally yes, but I guess it's not fully rigorous due to the infinite number of degrees of freedom.
MOVING CLOCKS In this section, we show that clocks moving at high speeds run slowly. We construct a clock, called a light clock, using a stick of proper lenght ##L_0##, and two mirrors. The two mirrors face each other, and a pulse of light bounces back and forth betweem them. Each time the light pulse strikes one of the mirrors, say the lower mirror, the clock is said to tick. Between successive ticks the light pulse travels a distance ##2L_0## in the proper reference of frame of the clock...
  • · Replies 55 ·
  • · Replies 28 ·
  • · Replies 42 ·
  • · Replies 22 ·
  • · Replies 27 ·
