tommyers
- 58
Hi,
I am teaching myself electrostatics – something which seems to have been ‘skipped’ over in my electronics degree. I am working from the book: Fudamentals of engineering electromagnetics’ by David K. Cheng.
My particular interest is electrostatics – more specifically the study of capacitance and capacitor geometry.
My studies have brought me to the gradient, divergence and curl. Below are my queries / observations for each:
Gradient
The term ‘space-rate’ of a scalar field seems to appear often. Does this just relate to the x,y,z and time of the scalar field? i.e the x,y,z relate to the space and the time part to the rate?
A diagram on P39 of the book shows two parallel surfaces. The lower surface is labelled, V and the upper V + dV, where dv indicates a small change in V. A point p1 is shown on the lower surface and point p2 is shown on the upper, normal, dn, to p1. p3 is shown close to p2 along a line, dl, however dl not equal to dn.
It states the ‘space-rate’ change dv/dl is greatest when along dn i.e the shortest distance between the two surfaces. Since the magnitude of dv/dl depends on the direction of dl, therefore it is a directional derivative.
It then states: “we define the vector that represents both magnitude and direction of the maximum space rate of increase of a scalar as the gradient of that scalar.”
They then give: grad V = an (dv/dl)
But what does this really tell me? That the gradient between points indicates the field strength between the two? In actually calculations would you have to include charge quantities?
Does anyone have any ‘real life’ examples with in depth maths to show how I can use this in my understanding and utilisation of electrostatics? Any good websites? Etc…
Divergence
The section on divergence discusses flux lines and there densities in relation to the field strength and direction….
… if an enclosed surface contains a source or sink then there will be an inward or outward flux flow. A positive net divergence indicates a source inside the volume and a net negative flow indicates a sink.
This then leads onto solutions using the ‘taylor series’.
What does the divergence tell us? Again any worked examples etc.. further description / discussion.
I have only just started on ‘curl’ but already it has begun talking about a ‘vortex source’!
I thought that some discursive explanation of the mathematics and concepts behind these 3 theorems may give me some better understanding.
Regards
Tom
Gradient
Divergence
Regards
Tom
