Grade 12 Electromagnetic Problem
In summary, the question is asking for the current needed in the bottom wire to repel and support the top wire that is held in place by frictionless guide plates. Using the Lorentz force law and Newton's Second Law, we can determine that the current in the bottom wire must be equal to the linear mass density of the top wire multiplied by its distance from the bottom wire, divided by the magnetic constant and the current in the top wire.
Dan17
A wire, whose linear mass density is 150g/m, carries a current of 40A (supplied by a flexible negligible weight). This wire lies parallel to, and on top of, another horizontal wire on a table. What current must flow through the bottom wire in order to repel and support the top wire at a height of 4.0 cm above it? The top wire is held in place by frictionless guide plates.
Thanks,
...Dan
The field due to a wire is
[tex]B=\frac{\mu_{0}I}{2\pi r}[/tex]
and the direction can be determined by use of the right hand rule. The force associated with these fields is given by the lorentz force law
[tex]F_{mag}=qvB[/tex]
when the field and the motion are perpendicular. Let's look at this another way... let's say that the lorentz force law read
[tex]F_{mag}=\frac{qLB}{\Delta t}[/tex]
we can then move that [tex]\Delta t[/tex] over to [tex]q[/tex] and get somthing that looks like this
[tex]F_{mag}=ILB=\frac{\mu_{0}I_{1}I_{2}}{2\pi r}L[/tex]
Utilizing Newton's Second law, in order for one wire to repel and support the other the forces must be equal.
[tex]0=F_{mag}-F_{grav}[/tex]
so we set the forces equal. ([tex]\mu[/tex] and [tex]\mu_{0}[/tex] are not related in any kind of way,[tex]\mu[/tex] is the linear mass density)
[tex]\mu gL=\frac{\mu_{0}I_{1}I_{2}}{2\pi r}L[/tex]
and we get a result that is only dependant on the second current
[tex]I_{2}=\frac{\mu 2\pi rg}{\mu_{0}I_{1}}[/tex]
Before you start putting numbers in make sure you understand what I have said here. And remember to give the current the proper polarity as indicated by the right hand rule.
Thanks for the help
FAQ: Grade 12 Electromagnetic Problem
What is Grade 12 Electromagnetic Problem?
Grade 12 Electromagnetic Problem is a topic in the science of physics that focuses on the study of electromagnetic waves and their properties. It is usually taught in the 12th grade of high school as part of the physics curriculum.
What are some examples of electromagnetic problems?
Examples of electromagnetic problems include calculating the speed of light, determining the energy of a photon, and analyzing the behavior of charged particles in electric and magnetic fields.
How is Grade 12 Electromagnetic Problem different from other topics in physics?
Grade 12 Electromagnetic Problem is unique in that it combines concepts from both electricity and magnetism. It also involves the study of waves, which is not typically covered in other physics topics.
What are some real-world applications of Grade 12 Electromagnetic Problem?
Electromagnetic problem solving is essential in many fields, including telecommunications, electronics, and medical imaging. It is also used in the development of technologies such as wireless communication, satellite navigation, and computer memory.
How can I improve my understanding of Grade 12 Electromagnetic Problem?
To improve your understanding of Grade 12 Electromagnetic Problem, it is important to practice solving problems and to seek help from a teacher or tutor if needed. Additionally, reading and studying from reputable sources and using visual aids, such as diagrams and animations, can also aid in understanding the concepts.
