Grade 12 Planes in Air question, help
In summary, the flight from Toronto to Pittsburgh will have a heading of 9° E of S and will take a total of 3 hours, with a layover of 0.5 hours. The pilot of plane B must wait for 2.25 hours before leaving Toronto in order to arrive at the same time as plane A.
IQmissing
Two planes fly from Toronto to Philadelphia (To. - Philly). Plane A flies via Pittsburgh whereas passengers on plane B have a direct flight. Pitts. is 350km due south of To. and 390km due West of Philly. The airspeed of both planes is 400km/h and a steady wind is blowing from the east at 60.0km/h.
a) what direction must the pilot take for the plane flying from To. to Pitts?
I drew a vector diagram with a line directly south, then a vector to the west connecting it to make a ninety degress angle. The hypoteneuse was the course required, so I found the angle between the hypoteneuse and vector going south using sin(angle) = 60.0km/h divided by 400.0km/h . I got a heading of 400 km/h (9° E of S) sound good?
b) How long will the entire flight take for plane A assuming a 0.50-h layover in Pittsburgh? Don't know how to account for airspeed
Please Help, then question c) How much time must the pilot of plane B wait before leaving Toronto if she is to arrive in Philly at the same time plane A arrives?
Thanks for your help
! For part b) the time taken for plane A would be (350 km + 390 km) ÷ 400 km/h = 2.5 h + 0.5 h for the layover = 3 h. For part c) the time the pilot of plane B must wait before leaving Toronto is 3 h - (390 km ÷ 400 km/h) = 2.25 h.
a) Yes, your heading of 9° E of S is correct for the plane flying from Toronto to Pittsburgh. This means the pilot should fly in a direction that is 9° east of south to reach Pittsburgh.
b) To calculate the total time for the entire flight for plane A, we need to consider the distance and speed for each segment of the journey. The distance from Toronto to Pittsburgh is 350km and the distance from Pittsburgh to Philadelphia is 390km. The airspeed is 400km/h for both segments. So the total time for the entire flight would be (350km/400km/h) + (390km/400km/h) + 0.50h = 0.875h + 0.975h + 0.50h = 2.35 hours.
c) To arrive at the same time as plane A, plane B would need to make up for the 0.50 hour layover in Pittsburgh. This means the pilot of plane B would need to wait 0.50 hour less than the total flight time of 2.35 hours, which is 1.85 hours. So the pilot of plane B should leave Toronto 1.85 hours after plane A leaves to arrive in Philadelphia at the same time.
Related to Grade 12 Planes in Air question, help
1. What are the four forces acting on an airplane in flight?
The four forces are lift, weight, thrust, and drag. Lift is generated by the wings and allows the plane to stay airborne. Weight is the force of gravity pulling the plane towards the ground. Thrust is created by the engines and propels the plane forward. Drag is the force that opposes the motion of the plane through the air.
2. How do airplanes maintain their altitude?
Airplanes maintain their altitude by balancing the forces of lift and weight. If the lift force is greater than the weight force, the plane will climb. If the weight force is greater than the lift force, the plane will descend. Pilots use the elevators and flaps to control the lift force and maintain altitude.
3. What is the relationship between air pressure and altitude in a plane?
As altitude increases, air pressure decreases. This is because the air becomes less dense at higher altitudes, meaning there are fewer air molecules in a given space. This decrease in air pressure affects the aerodynamics of the plane and must be taken into account by pilots when flying at high altitudes.
4. How does the shape of an airplane's wings affect its flight?
The shape of an airplane's wings, also known as the airfoil, is crucial to its flight. A curved or cambered airfoil creates a pressure difference between the top and bottom of the wing, resulting in lift. The angle of the wing, known as the angle of attack, also plays a role in lift generation. The shape of the wings can also impact the amount of drag the plane experiences during flight.
5. What factors affect the range and endurance of an airplane?
The range and endurance of an airplane are affected by several factors, including the amount of fuel carried, the weight of the plane, and the aerodynamic efficiency of the aircraft. Other factors such as weather conditions, altitude, and air temperature can also impact the range and endurance of a plane. Pilots must carefully calculate and consider these factors when planning a flight to ensure a safe and successful journey.
