Why is the Gradient of Displacement Vector Parallel to \( \vec{r} - \vec{r'} \)?
In summary, the conversation discusses the direction of the gradient of a quantity defined as the distance between two vectors, given by |r-r'|. While the gradient is typically taken with respect to the ordinary vector, r, it is noted that the direction of the gradient is actually in the direction parallel to r-r' rather than just r. This is supported by an intuitive argument and can also be seen mathematically through the inclusion of an angle between r and r'.
TheCanadian
367
I have a quantity defined as ## r =
\left|\vec{r} - \vec{r'}
\right|
## and am trying to take the gradient of this quantity. Now the gradient is with respect to the ordinary vector, ## \vec{r}##, and not ## \vec{r'} ##. But after looking at a solution, it says the direction of the gradient is in the direction parallel to ## \vec{r} - \vec{r'} ## and not ## \vec{r} ##. My apologies for being a bit vague here, but shouldn't the direction of the gradient be pointing in the direction in which the derivative is being taken (assuming only a radial component exists)? So if I am taking the derivative with respect to ## r ##, then it points in a direction parallel to ## \vec{r}##, while a derivative wrt to ##r - r' ## would point in ## \vec{r} - \vec{r'} ##?
No, you are wrong. I suggest actually doing the math rather than trying to reason your way forward.
If you definitely want to reason, you should use a translation argument from the gradient of the distance from the origin.
you should write out the equation in Cartesian coordinate
If you want to see why direction of the gradient does not have to be in the direction in which derivative is taken, here is an intuitive argument:
Gradient of a scalar function means that the direction in which the function changes most. So when you change r infinitesimally the change in the magnitude of the displacement vector cannot be independent of the direction of the r' because it affects the displacement vector.
Also, if you write it mathematically you will encounter a term like rr'cosa where a is the angle between r and r'. So you cannot assume there is no angular dependency.
Related to Why is the Gradient of Displacement Vector Parallel to \( \vec{r} - \vec{r'} \)?
What is the gradient of displacement vector?
The gradient of displacement vector is a vector that represents the rate of change of displacement at a particular point in a given direction. It is a measure of the steepness of a displacement curve at a given point.
How is the gradient of displacement vector calculated?
The gradient of displacement vector is calculated by taking the derivative of the displacement function with respect to the relevant variables. In other words, it is the slope of the tangent line to the displacement curve at a specific point.
What does a positive gradient of displacement vector indicate?
A positive gradient of displacement vector indicates that the displacement is increasing with respect to the relevant variable. This means that the object is moving in the direction of the positive axis.
What does a negative gradient of displacement vector indicate?
A negative gradient of displacement vector indicates that the displacement is decreasing with respect to the relevant variable. This means that the object is moving in the direction of the negative axis.
How is the gradient of displacement vector used in physics?
The gradient of displacement vector is used in physics to calculate the velocity and acceleration of an object at a specific point in time. It is also used to study the motion of objects and to analyze the changes in their position over time.
  • Classical Physics
  • Linear and Abstract Algebra
