Gradient of scalar field is zero everywhere given boundary conditions
In summary, the conversation discusses a problem involving a surface and a scalar field, and explains how using certain conditions allows for the deduction that the field is constant along the surface. The conversation also introduces an integral equation and discusses its relation to Green's First Identity.
etotheipi
I'm struggling with a few steps of this argument. It's given that we have a surface ##S## bounding a volume ##V##, and a scalar field ##\phi## such that ##\nabla^2 \phi = 0## everywhere inside ##S##, and that ##\nabla \phi## is orthogonal to ##S## at all points on the surface.
They say this is sufficient to deduce that ##\phi## equals a constant ##k## everywhere along the surface ##S## (I guess this is because it constrains the gradient vector to always be orthogonal to ##S##... is there a more mathematical way of putting that?) Then they perform a shift ##\phi' = \phi - k## so that ##\phi' = 0## everywhere on ##S##, and immediately write down the relation$$\int_{V} (\nabla \phi') \cdot (\nabla \phi') \propto \int_S \mathbf{n} \cdot (\phi' \nabla \phi')$$Since ##\phi' = 0## everywhere on ##S## the RHS is zero, and because the integrand on the LHS is non-negative it must be the case that ##\nabla \phi' = 0## everywhere inside ##V##, and consequently that ##\nabla \phi = 0## everywhere inside ##V##.
But I was wondering how they came up with that integral equation? Thanks
Mathematics news on Phys.org
This is the 3D equivalent of integration by parts, or Green's First Identity.
Likes etotheipi
Cool, I wasn't aware of this. Since ##\triangle \phi' = 0## the identity that you quoted does reduce to their statement (I suppose they were being a little sloppy by leaving out the ##dV## and ##dS##, and making up for it with a ##\propto## sign, but they are easy enough to re-insert). Thanks!
Yes, especially when you are learning this stuff it pays to keep track of things like that.
Likes etotheipi
Related to Gradient of scalar field is zero everywhere given boundary conditions
1. What is a scalar field?
A scalar field is a mathematical function that assigns a scalar value (such as temperature, pressure, or density) to every point in space.
2. What does it mean for the gradient of a scalar field to be zero everywhere?
When the gradient of a scalar field is zero everywhere, it means that the rate of change of the scalar field at any point is zero. In other words, the scalar field is constant at every point.
3. Why is it important for the gradient of a scalar field to be zero everywhere?
It is important for the gradient of a scalar field to be zero everywhere because it indicates that the scalar field is in equilibrium and there are no changes or variations in its value. This can be useful in many scientific and engineering applications, such as in fluid dynamics or heat transfer problems.
4. What are boundary conditions in relation to the gradient of a scalar field?
Boundary conditions are specific constraints or values that are imposed on the scalar field at the boundaries of the system or region of interest. These conditions help determine the behavior and characteristics of the scalar field within the given boundaries.
5. How is the fact that the gradient of a scalar field is zero everywhere given boundary conditions used in practical applications?
This fact is used in many practical applications, such as in solving partial differential equations, optimizing systems, and analyzing physical phenomena. It can also be used to determine the steady-state behavior of a system and to make predictions about the behavior of the scalar field in different scenarios.
  • Classical Physics
  • General Math
