Gradient vs. Directional Derivative
In summary, the conversation discussed the relationship between the gradient and directional derivative. While the gradient is a vector that points towards the maximum rate of change, the directional derivative is a scalar value given a specific direction. It was concluded that the magnitude of the gradient can be considered a specific example of a directional derivative. Additionally, it was noted that the gradient is a 1-form, not a vector, and is the dual of the differential operator with respect to a metric. The conversation also mentioned that the idea of a gradient can be applied to spaces without an inner product, as it only requires a linear/affine structure.
1MileCrash
1,342
41
On a quiz, a true/false statement was given along the lines of:
"The gradient is a specific example of a directional derivative."
I marked "true" and got it wrong. I see why, I think, since the gradient is an actual "guide," a vector, towards the max rate of change, while the directional derivative is a scalar value given some direction.
However, would it be correct to say that the magnitude of the gradient IS a specific example of a directional derivative?
Likes Delta2
You don't take the gradient of a function f in a particular direction, you simply take its gradient, df. On the other hand, given a vector v, you can find the rate a which f changes along that vector: df(v).
The object df contains information about the rate of change of f in all directions.
"The gradient is a specific example of a directional derivative."I marked "true" and got it wrong. I see why, I think, since the gradient is an actual "guide," a vector, towards the max rate of change, while the directional derivative is a scalar value given some direction.
yes. it is is the directional derivative in the direction of the vector that is gradient divided by its length, i.e. in the direction of the unit vector that points in the same direction as the gradient vector.
The definition of the gradient is df(X) = <gradf,X>
The unit vector is gradf/|gradf| so the directional derivative is <gradf,gradf/|gradf|>
= (1/|gradf|)<gradf,gradf> = |gradf|.BTW: df, the differential of f, is not the gradient of f. It is not even a vector. It is a 1 form.
When you have a metric, i.e. an inner product, then there is always a vector,Y, that satisfies the equation df(X) = <Y,X> for all X. Y is the gradient of f with respect to this metric.
If you think about it, it will be clear that you do not need the idea of an inner product to take a directional derivative.
Likes Delta2
The gradient is not a vector. In three dimensional vector calculus, the gradient of a function is represented by a vector perpendicular to the level surfaces of the function at that point, but this is not possible on a general manifold, where there is no notion of perpendicularity. The gradient is in fact a 1-form.
This is really a semantic point but in all of the books I have ever read the gradient requires an inner product on the tangent space as do other operators such as the Laplacian of a function.
The differential df of a function does not require an inner product. So for each df there is a different gradient for each different inner product. Otherwise put, the graident is the dual of the differential with respect to the inner product.
A function defined on a smooth manifold has a gradient, even though the tangent spaces of the manifold have no inner product. The gradient of f in coordinate representation is
df = f,i dXi
where dXi are the gradients of the coordinate functions p → Xi(p). This object contains information about how f varies in all directions. Given a vector v, the directional derivative of f in the direction v is given by the action of the 1-form df on the vector v.
df = f,i dXi
In all of the books I have read,df ,what you are calling the gradient, they call the differential.
The gradient is the vector which is dual to the differential with respect to a metric.
I will be happy to send you some differential geometry books that go over this.BTW: what do you call the dual of the differential if you do not call it the gradient?
Yes it is called the differential too, also exterior derivative. But the fact remains, it is the generalization of the gradient operator of vector calculus to general spaces which do not necessarily have an inner product. The idea of a gradient of a function makes sense in spaces that have no metric. It only requires the linear/affine structure.
http://en.wikipedia.org/wiki/Gradient
here is the first sentence of the link.
"In vector calculus, the gradient of a scalar field is a vector field that points in the direction of the greatest rate of increase of the scalar field, and whose magnitude is that rate of increase."
Note that the gradient is a vector field and has a magnitude.
Yes, in vector calculus. My point is simply that vector calculus is a formalism that only works in three dimensional euclidean space. The notion of gradient is more general.
The concepts are the same on any manifold. In Euclidean space, the domain of vector analysis, the gradient is the dual of the differential of a function with respect to the standard metric.
I'd be more inclined to say that the directional derivative is a specific example of the gradient, grad . n
Related to Gradient vs. Directional Derivative
1. What is the difference between gradient and directional derivative?
The gradient is a vector that represents the direction of the steepest increase in a function. The directional derivative is a scalar value that measures the rate of change of a function in a specific direction.
2. How do you calculate the gradient and directional derivative?
The gradient is calculated by taking the partial derivatives of a function with respect to each variable and combining them into a vector. The directional derivative is calculated by taking the dot product of the gradient and the unit vector in the desired direction.
3. Can the gradient and directional derivative have different values at the same point?
Yes, the gradient and directional derivative can have different values at the same point. The gradient represents the overall direction of steepest increase, while the directional derivative only measures the rate of change in a specific direction.
4. What is the significance of the direction in directional derivative?
The direction in directional derivative represents the direction in which we want to measure the rate of change of a function. It allows us to see how the function changes along a specific path or trajectory.
5. How can gradient and directional derivative be used in real-world applications?
Gradient and directional derivative are used in many fields of science and engineering, such as physics, economics, and computer graphics. They can help us understand the behavior of a system, optimize functions, and predict the behavior of physical systems. For example, in physics, the gradient and directional derivative can be used to calculate the force and acceleration of an object in a specific direction.
  • Calculus
  • Calculus
  • Differential Geometry
